Topic: progmem function (Read 652 times) previous topic - next topic
LittleDice
I am working on creating a function that reads strings from progmem and serial prints them.  I am not sure what I am doing wrong but my function is spitting out every string in progmem all at once without printing the variable that follows.
Code: [Select]
#include <avr/pgmspace.h>
#define line 1
#define no_line 0
//speak function
prog_char string_0[] PROGMEM = "Finished Initializing Ready for commands";   // "String 0" etc are strings to store - change to suit.
prog_char string_1[] PROGMEM = "Temp(C):";
prog_char string_2[] PROGMEM = "Pressure(Pa):";
prog_char string_3[] PROGMEM = "Humidity ";
prog_char string_4[] PROGMEM = "Compass Heading = ";
prog_char string_5[] PROGMEM = " degrees";
PROGMEM const char *string_table[] =    // change "string_table" name to suit
  string_0, string_1, string_2, string_3, string_4, string_5
  //speak(0,1,line);
  speak(1,1,no_line);
  Serial.println("21");
  speak(2,1,no_line);
  Serial.println("40000");
  speak(3,1,no_line);
  Serial.println("50");
  delay(3000);
void speak(int string_num, int num_strings, int ln)
  char write_buffer[44];
  if (ln = 0)
    for (string_num; string_num <= string_num + (num_strings - 1) ; string_num++)
      strcpy_P(write_buffer, (char*)pgm_read_word(&(string_table[string_num]))); // Necessary casts and dereferencing, just copy.
      Serial.print( write_buffer );
  if (ln = 1)
      Serial.println( write_buffer );
davekw7x
#1
Jul 01, 2011, 08:38 pm Last Edit: Jul 01, 2011, 10:33 pm by davekw7x Reason: 1
...is spitting out every string in progmem all at once...
If you want it to print one line, why are you calling a function that tells it to print not only a given line but all of the lines after that one?  (See Footnote.)
Maybe you can try:
Code: [Select]
   printPgmLine(1, no_line);
   printPgmLine(2, no_line);
   printPgmLine(3, no_line);
   delay(3000);
void printPgmLine(int string_num, int ln)
   strcpy_P(write_buffer, (char *)pgm_read_word(string_table + string_num));
   Serial.print(write_buffer);
   if (ln) {
Or some such thing.
Regards,
Dave
Footnote:
The "speak" function that you showed us has undefined behavior since the loops can try to access memory beyond the end of the array of strings.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
