Topic: Won't work as library (Read 596 times) previous topic - next topic
Delta_G
Hello,
This is my first post on this forum, I would appreciate any help you could give.
I have a class that points one of a union of pointers at a variable from the program and updates it during an interrupt service routine.  I have to use the pointer because the ISR can take no arguments and I do not know until run-time which variable will be attached.  I am using a union because I don't know until run-time which type the variable will be.
The code attached to this post works.  It works great for what I want on Arduino.  But when I put the header and program in separate files and make a library, it still compiles, but the variable doesn't get updated.  I have done some debugging and I know the ISR is being fired.  For some reason the pointer is not being dereferenced to my variable.  But again, if I copy out all the parts from .h and .cpp files and put them back into the sketch, things work fine.
I'm sure I'm missing an #include in this header or something.
If at first you don't succeed, up - home - sudo - enter.
Delta_G
Written this way, all in one sketch, the program works.  I am not seeing any errors either way, only the number doesn't change.
