Topic: Saving data from temperature sensor on microSD card (Read 3027 times) previous topic - next topic
drejcek
Hey everyone!
I am new here and new with using Arduino. Anyway, I am using 12-Bit + Sign Temperature Sensor and Thermal Window Comparator with Two-Wire Interface (http://www.national.com/mpf/LM/LM92.html#Overview), Arduino Uno with Ethernet Shield with microSD slot attached.
First I wanted just read data from sensor and then show results on Serial monitor. With that I didn't have no problem. I think results are good. But then I wanted to save this data on microSD card via Ethernet Shield.
I used one of the example on Arduino home page wich shows how to log data from three analog sensors to an SD card using the SD library. When I run program and then I see, that temperature data are not right.
If anybody knows where is problem or problems :) please help me!
Here is code:
#include <SD.h>
#include <Wire.h>
const int chipSelect = 4;
int msb,lsb;
  Wire.begin();
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  // make a string for assembling the data to log:
  String dataString = "";
  Wire.requestFrom(0x4b, 2);
  while(Wire.available())
  msb = Wire.receive();
  lsb = Wire.receive();
  float temp = (msb<<8|lsb);
  int a =(temp*50)/6400;
  dataString += String(a);
  dataString += ",";
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    Serial.print("temperature = ");
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
johnwasser
The problem is here:
You want to wait for TWO characters and then read them:
    while(Wire.available() == 0)
        /* WAITING FOR A CHARACTER */;
or
    while(Wire.available() < 2)
        /* WAITING FOR TWO CHARACTERS */;
drejcek
Hey hey!
First I would like to say thank you very much for your reply. I really don't know who to ask about it.
I tried like you suggest. I changed mine code with your suggestions. I tried both your suggestions but in both cases is the same result. On monitor serial I see output results 0. Why is that so??
The code is:
#include <SD.h>
#include <Wire.h>
int msb,lsb;
float tempt;
int a;
int dataString;
  Wire.begin();
    return;
  String dataString = "temperature= ";
  // read three sensors and append to the string:
      dataString += "";
  if (dataFile) {
    dataFile.close();
  else {
Please help me! I really want to solve this problem!
johnwasser
You still have the syntax wrong.
You wrote:
What I wrote was:
drejcek
Hello!
Sorry, I feel so ..... :D I am beginner with Arduino and I forget on this details. I repair code and is working great! It shows me the value in whole numbers, but I also want to see the decimal value. Is this because of function int??
Thanks a lot for your help and time! I appreciate your help!
VIKI
I got the same shield, how did you get the SD lib to compile? Or which version do you use? Tried 2 versions and all i get is 'SD.h:26: error: expected class-name before '{' token'.
drejcek
Hey!
I used the second option proposed by Johnwasser. At the end it was only problem because I forget to add ";" at the end of the line. After that it works fine for me. Now I wanted to see also decimal value. I need to make some more studies about it.
I don't know much about your code, but I think you have problem in 26 line and maybe is "{" missing or is too much.
Greetings,
Andrej
johnwasser
This should print out the temperature to three decimal places:
  int temperature = msb<<8 | lsb;
    dataString += String(temperature/128);
    temperature %= 128;  //  Strip off the integer degrees
    dataString += ".";  // Decimal point
    for (int i=0; i<3; i++)
       temperature *= 10;  // "shift" the number one digit to the left
       dataString += "0" + (temperature/128);  // Add that one digit to the string
       temperature %= 128;  // Strip off that digit
   dataString += "";
drejcek
Hey!
Thank you a lot johnwasser. Your information was very usefull! Thanks again!
bimbel
to drejcek
I'm a student and I wanted to ask if you can publish the project of 'interface between LM92 and ARDUINO UNO board.
I ask this because my professor asked me this task.
If you do me this favor, I would be very grateful.
Thanks
