Topic: M2TKLIB - A User-Interface-Toolkit for the Arduino Hardware (Read 24494 times) previous topic - next topic
olikraus
Hi
Quote
Is there a signed flavour of uint8_t?
This should be "int8_t".
Quote
Also, what is the purpose of calling "m2.checkKey();" multiple times within the main loop?
A call to "checkKey()" polls the values of the rotary encoder and the other keys. There is no interrupt based check of the rotary encoder, instead M2tklib requires as much calls to "checkKey()" as possible.
Quote
I'm also confused about how i pass a value back through the callback procedure. I was looking at the example code and i'm unsure how i would use that. Say for example i wanted to do a Serial.print(); of the current S8NUM value for el_u1.
You need to use global variables to pass values to a callback procedure (as you did correctly in the second code example).
This will do the print for each changed value:
Code: [Select]
uint8_t global_value = 0;
uint8_t u8_cb(m2_rom_void_p element, uint8_t msg, uint8_t val)
  if ( msg == M2_U8_MSG_SET_VALUE )
    global_value = val;
    Serial.print(global_value);
  return global_value;
Oliver
marijn
For a project I use an old loran C navigator box with intergrated keypad. It has 20 keys in a 5x8 matrix, yes very inefficient.
How should I modify the library to be able to use a matrix keypad?
So if I look deeper into the code I should change m2_arduino_get_key in m2esarduino.c to return the messages on result of a keypress on my matrix keypad. Is that the only place where I should change the code?
Would it be possible to make extra messages for the numbers 0...9?
Cheers,
Marijn
olikraus
Hi
1) Extend the event source to generate the new events (M2_EP_MSG_KEY_1, M2_EP_MSG_KEY_2, ...)
2)  Introduce a new (corresponding) element msg, e.g. M2_EL_MSG_KEY_1
Extend one of the event handlers to process the new key event, for example extend
Code: [Select]
uint8_t m2_eh_4bs(m2_p ep, uint8_t msg, uint8_t arg1, uint8_t arg2)
Then add this code to the event handler (for each event):
Code: [Select]
  case M2_EP_MSG_KEY_1:
    m2_nav_prepare_fn_arg_parent_element(nav);
    m2_fn_arg_call(M2_EL_MSG_KEY_1); // assign the char
    return m2_nav_user_next(nav); // go to next position
3) Next step is to make the elements aware about the new element messages.
For example M2_TEXT would make sense here (m2eltext.c):
Extend the char processing function: M2_EL_FN_DEF(m2_el_char_fn)
Code: [Select]
  case M2_EL_MSG_KEY_1:
      cp = m2_get_char_ptr(fn_arg->nav);
      *cp = '1';
      return 1;
Of course: not tested...
Oliver
marijn
Thanks Oliver,
I will try to extend the lib that way.
The matrix keypad question was a RTFM problem   :smiley-red:
I used m2.SetKey to store the result of the matrix into the que.
I'm still amazed about this lib...
Cheers,
Jelbert
olikraus
Yes, it should be possible to use setKey() if you do not want to rewrite the event source.
Oliver
olikraus
Hi Jelbert
I have added the mentioned code for the keypad support. See http://code.google.com/p/m2tklib/issues/detail?id=108.
Instead of extending the existing handlers, i have introduced m2_eh_4bks and m2_eh_6bks (and extended m2_eh_4bsts and m2_eh_6bsts) to support the keypad values.
Just for reference, the new code in the event handler was wrong. Correct code is:
Code: [Select]
    m2_nav_prepare_fn_arg_current_element(nav);
I have introduced the following constants (which can be used with setKey or as return value of the event source):
#define M2_KEY_HASH 35
#define M2_KEY_STAR 42
#define M2_KEY_0 48
#define M2_KEY_1 49
#define M2_KEY_2 50
#define M2_KEY_3 51
#define M2_KEY_4 52
#define M2_KEY_5 53
#define M2_KEY_6 54
#define M2_KEY_7 55
#define M2_KEY_8 56
#define M2_KEY_9 57
Additionally you can use any other ASCII code like 'a', 'b', 'c', etc.., so m2.setKey('B') will send the ASCII B to the element. At the moment only M2_TEXT will be able to handle these new codes.
Let me know your variant of m2tklib, then i will upload a prerelease of m2tklib including keypad support.
Oliver
marijn
Hi Oliver and others,
Based on the 2L example I went on with my  code. And made some modifications in oa the used font to create a space on the top of the display for a status line.
At frst I had troubles with the display suddenly blanking but the arduino kept on running.
That was fixed with a buffer that was too long in the drawStatus routine and moving the fontsetting to setup.
After that everything ran fine for a long while.
But now, when just waiting in the main menu, the display blanks again after 8 hours or so.
Is there a way to reset the display system (software part), without resetting the arduino?
Besides the drawstatus routine I included most of the rest for completeness sake.
here is the drawStatus routine
Code: [Select]
    void drawStatus(void)
  static long bmpTime=0;
  static char StatBuf[26];
  static float temprature;
  static float pressure;
  static int hi, lo;
     hi=int(RATemp.getAverage());
    lo=(RATemp.getAverage()-float(hi))*100;
  String line =  String(rtc.getTimeStr());// + bmp.readPressure() + " " + bmp.readTemperature()+" C");
  line += " ";
  line +=  (int(RADruk.getAverage())); //
  if(statMsgStat==1 && m2.getRoot() == &m2_null_element)
    switch (Step)
    case 1:
      line += " 12u  ";
    case 2:
      line += " 1d   ";
    case 3:
      line += " 1.5d ";
    case 4:
      line += " 2d   ";
    case 5:
      line += " 2.5d ";
    case 6:
      line += " 3d   ";
    case 7:
      line += " 3.5d ";
    case 8:
      line += " 4d   ";
    default:
      line += "      ";
    line += "      ";
  line.concat(hi);
  line += '.';
  line.concat(lo);
  if(lo<10)
    line +='0';
  line += "C";
  line.toCharArray(StatBuf,26);
  u8g.drawStr(0,7, StatBuf);
The menu side. The stuff from the example has been cut out because the post exeded the maximum length.
Code: [Select]
U8GLIB_KS0108_128 u8g(27, 28, 29, 30, 31, 32, 33, 34, 26, 35, 36, 24, 25,37); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, cs1=14, cs2=15,di=17,rw=16
// Forward declaration of the toplevel element
M2_EXTERN_ALIGN(top_el_expandable_menu);
/*Create empty screen for graph barrograaf*/
M2_ROOT(el_barrograaf_goto_top, NULL, "t ",&top_el_expandable_menu);
//here very much code has been deleted to fit forum post
//these were modifications of the demo routines to do my menu things
menus call the toplevel element again
m2_menu_entry m2_2lmenu_data[] =
//  { "Menu",  NULL },
  { "Show Graph", &m2_null_element },  //disable menu system
//  { "Show Graph", &list_element },  //disable menu system
  { "Navtex", &top_el_expandable_menu },
  { ". Allerts", &top_el_expandable_menu },
  { ". All msgs", &top_el_expandable_menu },
  { "Navtex Setup", &top_el_expandable_menu },
  { ". Set Area", &top_el_muse },
  { ". Set MSG", &top_el_muse1 },
  { "WIFI Setup", &top_el_expandable_menu },
  { ". Radio", &el_rb_grid },
  { ". Combo", &el_top_combo },
  { "Serial setup", &el_setspeed_top_combo},
  { "Serial Monitor", NULL },
  { ". COM1", NULL },
  { ". COM2", NULL },
  { ". COM3", NULL },
  { ". COM4", NULL },
  { "Set Date", &el_top_date_menu },
  { "Set Time", &el_top_time_menu },
  { "Numbers ", &el_top_num_menu },
  { NULL, NULL },
// The first visible line and the total number of visible lines.
// Both values are written by M2_2LMENU and read by M2_VSB
uint8_t m2_2lmenu_first;
uint8_t m2_2lmenu_cnt;
M2_2LMENU(el_2lmenu,"l5F1e0W43",&m2_2lmenu_first,&m2_2lmenu_cnt, m2_2lmenu_data,65,102,'\0');
M2_SPACE(el_space, "W1h1");
M2_VSB(el_vsb, "l5W2r1", &m2_2lmenu_first, &m2_2lmenu_cnt);
M2_LIST(list_2lmenu) = { &el_2lmenu, &el_space, &el_vsb };
M2_HLIST(el_hlist, NULL, list_2lmenu);
M2_ALIGN(top_el_expandable_menu, "-1|0W64H64", &el_hlist);
// m2 object and constructor
M2tk m2(&top_el_expandable_menu, m2_es_arduino, m2_eh_4bs, m2_gh_u8g_ffs);
//key matrix
byte key_rows[] = {
  40,38,42,43,44,45,46,47};
byte key_cols[] = {
  10,11,12,41,39};
SPISRAM myRAM(7); // CS pin
char buffer[128];
long Pressure;
   //enable 5V dc/dc converter
  pinMode(DC5V, OUTPUT);
  digitalWrite(DC5V,LOW);
  pinMode(CSRAM, OUTPUT);
  pinMode(Backlight, OUTPUT);
  analogWrite(Backlight,128);
  //setup keypad
  for(int i=0;i<8;i++)
    //    Serial.println(key_rows[i]);
    pinMode(key_rows[i],OUTPUT);
    digitalWrite(i,HIGH);
  for(int i=0;i<5;i++)
    //    Serial.println(key_cols[i]);
    pinMode(key_cols[i],INPUT);
    digitalWrite(key_cols[i],HIGH);
    if ( u8g.getMode() == U8G_MODE_R3G3B2 )
    u8g.setColorIndex(255);     // white
  else if ( u8g.getMode() == U8G_MODE_GRAY2BIT )
    u8g.setColorIndex(3);         // max intensity
  else if ( u8g.getMode() == U8G_MODE_BW )
    u8g.setColorIndex(1);         // pixel on
  // Connect u8glib with m2tklib
  m2_SetU8g(u8g.getU8g(), m2_u8g_box_icon);
  // Assign u8g font to index 0
  m2.setFont(0, u8g_font_5x8r);
  // Assign icon font to index 3
  m2.setFont(3, u8g_font_m2icon_7);
  u8g.setFont(u8g_font_5x7r);
  Wire.begin();
  if (!bmp.begin())
    Serial.println("Could not find a valid BMP085 sensor, check wiring!");
    while (1) {
//Setup SPI for SRAM
  SPI.begin();
  SPI.setBitOrder(MSBFIRST);
  SPI.setClockDivider(SPI_CLOCK_DIV2);
  SPI.setDataMode(SPI_MODE0);
//some test on the RTC for rome unresolved error
Serial.println(rtc.getTimeStr());  //deze tijd is onjuist. Meestal 00:00:00
Serial.println(rtc.getDateStr());
Serial.println(rtc.getTimeStr()); //deze tijd is juist
//init Flagspace
  getFlagSpace();
  if(flagSpace.regs.dataPointer<START_DATA||flagSpace.regs.dataPointer>END_DATA)
    flagSpace.regs.dataPointer=START_DATA;
//fat starts on 0x0000 so no check needed for msgPointer
//  Timeadjust(DateTime(__DATE__, __TIME__));
// Draw procedure, Arduino Setup & Loop
void draw(void) {
  drawStatus();
  drawGraphics();
  m2.draw();
void loop(){
  long r,timer=0;
// float temp;
  while(1)
    scheduler();
    KeyMatrix();
    m2.checkKey();
    if ( m2.handleKey() != 0 || millis()>timer )
      timer=millis()+1000;
      u8g.firstPage();
      do
        KeyMatrix();
        m2.checkKey();
          draw();
      while( u8g.nextPage() );
And for completeness here is the head of my code.
Code: [Select]
#include <Wire.h>
#include <SPI.h>
#include "U8glib.h"
#include <Adafruit_BMP085.h>
#include <SPISRAM.h>
#include <stdlib.h> // for itoa
#include "M2tk.h"
#include "utility/m2ghu8g.h"
#include <DS1302.h>
#include <DateTime.h>
#include "RunningAverage.h"
#define END_FAT         0x00BBF
#define START_DATA      0x00BC0
#define END_DATA        0x02BBF
#define MSG_BUF_START   0x02BC0
#define MSG_BUF_END     0x03CAF
#define MSG_START       0x03CB0
#define MSG_LAST        0x1EFFF
#define MSG_STOP        0x1EFFF
#define FLAGSPACE       0xFFF0
#define DC5V 22
#define CSRAM 7
#define Backlight 8
#define M2_KEY_0 20
#define M2_KEY_1 21
#define M2_KEY_2 22
#define M2_KEY_3 23
#define M2_KEY_4 24
#define M2_KEY_5 25
#define M2_KEY_6 26
#define M2_KEY_7 27
#define M2_KEY_8 28
#define M2_KEY_9 29
#define BARROGRAAF 1
#define THERMOGRAAF 2
#define PT_GRAPH 3
long currMsg=MSG_START;
long nu;
int sampleTime=5;
byte drawFunction=0;
byte Step=8; //Geeft de stap grootte aan voor het tekenen van het grafiek max END_DATA-START_DATA/128=65
char tMaxBuf[8];
char tMinBuf[8];
char dMaxBuf[8];
char dMinBuf[8];
char statMsgStat=1;
  float maxTempDraw;
  float minTempDraw;
  float maxDrukDraw;
  float minDrukDraw;
  long minMaxTimeout=0;
#define FLAGSPACE_UNION_SIZE 16
union bla{
  struct blie{
  unsigned int dataPointer; //2bytes
  unsigned int msgFATPointer;  //2bytes
  byte maxTemp;  //
  byte minTemp;
  byte test3;
  byte test4;
  int maxDruk;
  int minDruk;
  byte test5;
  byte test6;
  regs;
  byte flagMap[FLAGSPACE_UNION_SIZE-1];
flagSpace;  //regU
#define REG_UNION_SIZE 8
union regUnion {
  struct regStruct{
    float temp;
    float druk;
  regs;
  byte registerMap[REG_UNION_SIZE-1];
dataUnion;  //regU
#define EEPROM_UNION_SIZE 8
union{
  struct{
   unsigned int com1Baud;
   unsigned int com2Baud;
   unsigned int com3Baud;
   unsigned int com4Baud;
  regs;
  byte PROM[EEPROM_UNION_SIZE-1];
EE;
olikraus
Quote
There is the procedure "begin" (http://code.google.com/p/u8glib/wiki/userreference#begin) which does a reset of the display for newer versions of U8glib.
Oliver
olikraus
Today, I have released version 1.11 of M2tklib.
M2tklib is a menu/GUI library for graphics and character displays.
Projekt page: http://code.google.com/p/m2tklib/
The new version is available for download:
  @Google: http://code.google.com/p/m2tklib/downloads/list
  @Bintray: https://bintray.com/olikraus/M2tklib
From the ChangeLog:
   * Keypad Support for M2_TEXT and M2_U32NUM (Issue 108)
   * Fixed XBM code (Issues 110, 111)
   * Touch screen support for M2_STRLIST and M2_VSB (Issue 112)
   * New color graphics handler for U8glib (Issue 113)
   * Quick and Home keys (Issues 114 and 115)
   * Changed default behavioir for M2_ALGIN (Issue 121)
   * New element: M2_COMBOFN (Issue 122)
   * New tutorial on event sources (Issues  117 and 123)
Oliver
ArduinoDSP
Hi Oliver,
I like your work quite a lot, but I feel kinda lost now.
Is it possible to declare conditional elements and what is the best approach you'd recommend?
I'd like to create some menu entries, which are dependent on other settings entered in other menu points (global variables).
Menu A (something)
Menu B (something to change a global variable)
Menu C (only visible, if variable in Menu B == 1)
Menu D (only visible, if variable in Menu C == 1)
Menu E (something else)
I guess I should start around STRLIST, but I was wondering if there's a better solution.
Your insight is much appreciated.
olikraus
Hi
STRLIST is one option, but might be limited. Another option is to create several dialog boxes, which only differe in the visibility of some elements. Then use M2_BUTTON with conditoinal setRoot command in the callback action to jump to the one dialog, which has the intended visible elements. Note, that you can reuse elements (or complete element trees) in more than one dialog.
Then, finally, there is M2_HIDE(). I still did not document M2_HIDE, but i think there should be an example (HideS8Num).
https://code.google.com/p/m2tklib/source/browse/arduino/u8g/HideS8Num/HideS8Num.pde
Oliver
ArduinoDSP
Oliver, thank you so much for your prompt reply, it was most helpful!
M2_HIDE() seems to be perfect, it is the way to go. Wish I had found it sooner. :)
Are there any other notable undocumented functions?
olikraus
I think M2_HIDE is the only undocumented element.
Oliver
ArduinoDSP
M2_HIDE does what it says and only that, it hides an element, but it cannot remove the space it leaves behind and it does not work with U32NUMFN, so one needs to hide a V/H/GRIDLIST in that case.
STRLIST turned out to be the least hassle-free solution to hide some top level menu elements, if you need VSB.
Different strings are shown according to the state of some variables and lower menu entries are assigned with setRoot in the callback procedure.
I think creating different dialog boxes would have been way too over-complicated with Menu(X)2L.
Is there any way to adjust the vertical spacing in-between strings of STRLIST?
Mit freundlichen Grüßen
olikraus
I reviewed my own code.
M2_HIDE(element_name, fmt, &ctl_var, &child_name);
I think if ctl_var is 2 or higher, then the size will be reduced to zero.
So actually ctl_var can have three values:
0: child is visible
1: child is not visible, but space will be occupied
2: child is not visible and also no space is reserved for the child
The vertical spacing within STRLIST depends on the font only.
Oliver
