Topic: TVout Colors (Read 12173 times) previous topic - next topic
baum
TVout is great, but two colors at 128x96 gets a bit small after a while. Through other posts, I realize that it is impossible with the arduino's current speed and memory to get full 8-bit color (RGB). But using a DAC such as this one and the helpful breakdown of the NTSC protocol here, would it be possible to get 8-bit B+W (256 colors from white to gray?) At a the resolution mentioned above (128*96), we would need a total of 12288 bytes for the frame buffer, so if my code is not too long, could it work? I may not even need TVout...
baum
baum
What if I used a smaller resolution, i.e. 30*40? How long is a "pixel time"?
AWOL
Assuming a visible line length of about 52us, and 720 pixels to the line, about 72ns, or just a little longer than one instruction cycle at 16MHz.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
nootropic
The Arduino only has 2K of SRAM, so you don't have nearly enough memory to store 8 bits per pixel.  Remember, the memory usage reported by the IDE when you upload is the flash memory for storing your program, not SRAM.
And as AWOL said, there's only so much time to read the pixel information and write to the DAC.  At 128 pixels horizontal, there are only 5 instruction cycles available to do this work, and the current 1-bit output uses 3 cycles (then does a NOP for 2 cycles).  In other words, there's not enough time to even do 2-bit video.
baum
So decrease the output resolution and store the frame buffer in Flash.
AWOL
Are you planning on using an external encoder for the colour information?
baum
Probably a DAC of some sort so I needn't deal with the pseudo-DAC resistor network.
AWOL
Quote
But how are you going to get the phasing of the sub-carrier correct?
nootropic
You can't store the frame buffer in flash memory -- it's read-only.
baum, generating color composite video is just not going to happen on a $3 microcontroller.
baum
Alright.
But how did those cheap plug-n-play pacman units do it?
AWOL
baum
So something like an FPGA would be the way to go if I really wanted to do it?
nootropic
Quote
Custom hardware
Yes, hardware designed for the purpose of generating video signals.  The ATmega328 is not designed for that.  It's a simple general purpose microcontroller.
gijs
there is this:
http://www.youtube.com/watch?v=sFCxV5PsusQ
http://www.linusakesson.net/scene/phasor/index.php
baum
OMG. That is awesome. Would any one who told me it was impossible like to comment on Linus' phasor?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
