Topic: TVout Colors (Read 15550 times) previous topic - next topic
nootropic
I know about this demo and it is very impressive.  It takes advantage of a particular feature of PAL, but is not possible with NTSC (North American TV standard).  The memory constraints associated with storing an actual frame buffer (like if you were writing a game or something) are still real constraints.  There are only 2K of SRAM in the Arduino.
Baum, if you think you can use these techniques to make a color version of TVout, then PLEASE do so!  We'd all be very grateful!  We aren't telling you not to try -- we are just informing you of the technology constraints that have made color frame buffer based composite output not possible.  Prove us wrong by doing it!
baum
Quote
Please elaborate.
What is the difference between PAL and NTSC that makes color output possible?
cr0sh
Craft (his earlier demo) does color VGA and 4-channel sound on the 88:
http://www.linusakesson.net/scene/craft/index.php
I think the real answer for this is that to pull off color video -and- sound at the same time - you have to be an uber-demo coder like Mr. Akesson; this isn't going to happen on a 328 without pure AVR assembler coding, and lots of cycle counting (and code rearranging, etc). He likely isn't even using a frame buffer, for that matter (maybe a line buffer, like the Atari 2600 video chip).
Now - if somebody could build that code and burn a 328 (running at 20 MHz) and add some kind of interface to control it (then throw it all on a shield, of course) - then you'd have a good beginning of a nice video interface for the Arduino that went beyond the TVOut library...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
cr0sh
Heh - just saw this one:
http://www.linusakesson.net/scene/bitbanger/index.php
ATtiny15 @ 1.6 MHz, 1K of flash, and 32 bytes of RAM!
VGA output (ok, 3 x 8 pixels - LOL - also "glitch video"), plus multi-channel sound...
I love the demoscene!
nootropic
Quote
Please elaborate.
Read about the project -- he explains it!
http://www.linusakesson.net/scene/phasor/index.php
baum
OK. So without the coding know-how of Linus, I can not make TVout Color at stand. resolutions. but how about his ATtiny demo, for example 5 by 5 resolution with the Arduino? would this work? I would have much more time to render the frame.
gijs
would it be possible/difficult to convert the TVout lib into the VGAout lib?
it could be like this:
00 = R
01 = G
10 = B
11 = ?
baum
Maybe. But I don't have any VGA monitors! :) So is VERY small color resolution possible using a parallel DAC?
AWOL
Quote
Would any one who told me it was impossible like to comment on Linus' phasor?
Did you look at the source?
Did it look much like an Arduino project?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
baum
No. But surely the arduino can do something low res, i.e. 5x5, using standard arduino programming?
AWOL
Quote
He used a crystal chosen to be four times the colour sub-carrier frequency, and careful cycle-counted assembler to allow him to set the colours - why do you think lowering the resolution makes setting the colour any simpler?
baum
Lowering the resolution would give more actual pixels per rendered pixel, thus allowing more time for color rendering.
AWOL
The colour is "rendered" cycle-by-cycle of a carrier frequency of 3.57MHz (NTSC) or 4.43MHz (PAL) on top of the luminance signal.
Lowering the spatial resolution makes no difference, you still have to do this modulation at the specified frequency for the width along the scan line of that block of colour.
The Phasor makes use of a trick in PAL where the colour resolution vertically is halved.
baum
So I should just give up.
AWOL
No, don't give up.
Just be aware of the big differences between component (e.g. VGA) and composite (e.g. PAL  or NTSC), and take with a pinch of salt an assertion that someone can generate NTSC or PAL video - more often than not they really mean RS170 and CCIR, respectively.
