Author Topic: Can't upload sketches that are greater than 28674 bytes on my Uno  (Read 759 times)
Hey folks.
I think i may have a bad chip or something, but i can't seem to upload my sketch when it grows to greater than 28674 bytes.  I'm using Arduino 022 on MacOS.
If the sketch is 28674 or fewer bytes, i see the normal upload message:
Binary sketch size: 28674 bytes (of a 32256 byte maximum)
and the code seems to work ok.
If the sketch grows to 28676 bytes, I see this:
Binary sketch size: 28676 bytes (of a 32256 byte maximum)
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x54
avrdude: failed to write flash memory, rc=-4
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x61
And the arduino doesn't run the code at all.
If the sketch gets much bigger than 28680, i see:
Binary sketch size: 28700 bytes (of a 32256 byte maximum)
I originally thought it was something in my code, but I can get this problem to occur by changing the length of strings (such as within a "Serial.print()" call).
For example, if i have a sketch that compiles to 28674 bytes (and works ok), changing:
Serial.print ( "12345" );
to
Serial.print ( "123456" );
Will cause the sketch size to be 28676 bytes, and the problem will occur.
The error message seems to indicate there's a problem with the Flash space on the chip, but i'm not sure.  Do I have any recourse here (other than to get a new board or chip?)
Thanks!
...tango...
Left Coast, CA (USA)
Measurement changes behavior
I suspect a $6 investment in a new 328p chip (with bootloader) is your best bet as I can't think of anything else on the board that could cause the symptom.
Lefty
Lefty
Thanks.  I thought that might be it, but i was hoping there'd be something else i could try.
OK, off to get a new chip it is.  It seems like this chip will work (http://www.sparkfun.com/products/10524), but i'm still a little fuzzy on the bootload aspect, so i'm not quite sure.
Thanks again.
...tango...
That's the correct chip/bootloader for a Uno board.
Lefty
Before you throw out the chip, I would check the fuse settings. If fuses are set to reserve a 4k boot section, addresses beyond 28672 (32k less 4k = 28672) would be write protected and so upload would fail.
Thanks.
One (super newbie) question though...how?
Thanks again.
Grand Blanc, MI, USA
"We're a proud service of the Lost Electricity Reclamation Agency"
I might try this beta bootloader:
http://arduino.cc/forum/index.php/topic,64105.msg466703.html#msg466703
One of the issues it fixes is:
380 optiboot has problems uploading sketches bigger than about 30 KB
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
AHA!
Thanks for that.  I didn't actually get the beta optiboot running, but i was able to get an older version (yet newer than the default optiboot that comes on the UNO) installed by using optifix (http://www.adafruit.com/forums/viewtopic.php?f=25&t=19260).
This seems to have fixed my issue.
Phew!
