Topic: 1-Wire Slave (Read 76048 times) previous topic - next topic
Adam84
Hi guys,
Can anyone give any guidance on using this library to make an Uno a 1-wire slave. I can get the "DS18B20_Slave_Interrupt_universal_analogread_fulllib.ino" example sketch to compile and upload fine by changing the  dsslavepin (does this number refer to the actual pin or the interrupt no.?) I have another arduino with another DS18B20 and using the wire library example to get the addresses of the devices on the bus i only find the actual DS18B20. Has anyone had it working on an Uno and knows where i'm going wrong?
wongsm7
Hi Markus,
Does your library work with Arduino Uno?
Youen
#92
Aug 09, 2015, 10:44 am Last Edit: Aug 09, 2015, 10:46 am by Youen
I just released my library to make an Arduino board act as a 1-wire slave. You can download it here: https://github.com/neuoy/OneWireArduinoSlave
It's implemented using interrupts (everything is asynchronous, user code is notified by callbacks when bytes are received, etc.)
I've only tested it with an Arduino Uno and a DS9490R master (connected by USB to a laptop that acts as my home automation server). Works flawlessly so far in this setup, but let me know if you find bugs or can test it with other hardware setups (wether it works or not, I'm interested to know in both cases).
I was surprised how developing this kind of library is tricky, timings are sometimes as short as 3 microseconds or the master can miss bits, so debugging through Serial is not really an option, I acquired an USB oscilloscope for the occasion (very interesting project though).
-dev
Very nice!  It's great to see a real C++ design and clean implementation that's easy-to-read.  I've been helping someone over here, and had recently come to the conclusion that interrupts will have to be used for the exact reasons you state: 3us events.
As you said, this is definitely something that requires a 'scope or Logic Analyzer.  The nice thing about the 'scope is that you can distinguish between active highs, input mode and multiple devices driving low.  The user I am trying to help doesn't have either, and isn't very advanced in Arduino nor embedded techniques.  It has been slow going.
While I've been reluctant to dive in and implement this, I have started on something.  After looking at the timings and existing implementations, I was just starting to look at External Interrupts, Pin Change Interrupts and even the Input Capture.  So thanks a million for this very "timely" post.  ;)
Were you thinking about extending this to other types/numbers of 1-wire devices, or are you at the "good enough for me" stage?
BTW, have you seen Cosa?  There are a few stylistic similarities, and I mean that as a compliment.
Cheers,
/dev
Really, I used to be /dev.  :(
Youen
Nice to see it can be useful to others :-)
Right now, it is indeed in a "good enough for me" stage. The goal was to provide a low level implementation only, because high level considerations (emulating specific devices such as temperature sensors or whatever) have a much larger scope, beyond what I can provide and support as a hobby, and also these are (somewhat) less difficult problems to solve. But it's open source, so anyone can expand on it. Also, that doesn't mean I won't try to fix the bugs that are reported, if any :-)
I didn't heard of Cosa, but it seems interesting, I'll take a look, thanks.
About timing issues, I also tried with an active wait, and it was just a little bit slower, but I think it can work too. However, you really have to use 100% of the CPU to do just that, poll the pin state in a loop, and pull low as soon as you detect the edge (so you need to know if you're going to pull low before starting the loop, to avoid too many instructions in between). So in my experience, interrupts are indeed more adequate to the task (a bit faster, and also less risk to miss an edge since the edge detection is hardware). Not sure how all these things will work (or not) on other boards though.
milimilo
Hello Youen
Thank you very much for your lib.
My project is this one, and of course doesn't work:
I have an home automation zwave device that can read DS18B20 1Wire sensors. I would like to use my Arduino UNO to send some value through this zwave module.
May you give me a simple example of code that sends a value when pressing a simple button?
I'm blocked trying to give your library a value to send (using your demo .ino ...).
Sorry for my completely noob question (i am really new to Arduino and totally off the computing universe) and thank you very much for your help!
ColinR
The example does not seem to compile for ATTiny85:
In file included from ATTiny1WireSlave.ino:2:0:
E:\Docs\code\avr\arduino projects\libraries\OneWireArduinoSlave/LowLevel.h: In member function 'void Pin::attachInterrupt(void (*)(), int)':
E:\Docs\code\avr\arduino projects\libraries\OneWireArduinoSlave/LowLevel.h:113:3: error: 'EIFR' was not declared in this scope
   EIFR |= (1 << INTF0); // clear any pending interrupt (we want to call the handler only for interrupts happending after it is attached)
ColinR
I've gone through and replaced the offending items using the ATTiny85 and ATMega328 datasheets, namely:
EIFR --> GIFR
TCCR1B --> TCCR0B
WGM12 --> WGM02
TIMSK1 --> TIMSK
There may have been one more.
I don't know enough about the register functions to know where I have not gotten this right, but I definitely do not have a functioning example at the moment. The Tiny doesn't take down the bus, and have another device on there for a sanity check, so the bus and adapter are up. Just no ATTiny slave.
Colin
ColinR
I have finally got ATTiny85's working as 1-wire slaves but not using Markus' library, I used a modified version of the one wire library from Alexander Gordeev . I finally succeeded once I discovered I could run the ATTiny85 at 16Mhz, that was the big breakthrough.
I now have ATTiny85s as slaves for a rain gauge and another for a humidity sensor. I am using the  PinChange Interrupt Library so that the slaves only process one-wire commands once a One Wire Reset is detected. An LED flashes to provide visual feedback when the slave sends sensor data. Like the DS18B20 I use 0x44 as a request to calculate the sensor data and 0xBE to return the results.
<<snip>>
I could not get this to work. I had to all sorts of library moving, and eventually a type definition conflict with 'boolean'. I renamed all instances in the libraries to 'myboolean' and resolved the conflict, but still no device on the bus.
You did not mention how you set the clock to internal 16MHz. The typical ATTiny board profiles for the Arduino IDE do not have a 16MHz internal option. Instead, I set up the Adafruit Trinket 16MHz definition and enabled as described here: https://learn.adafruit.com/introducing-trinket/16mhz-vs-8mhz-clock
Still, no love.
Colin
milimilo
Would this project be possible? :
- a keypad identifies a user with a code
- the accepted user code is send through 1Wire (as a DS18B20) to a 1Wire receiver that can only read a DS18B20
All of this on an Arduino UNO.
Thank you for your help
Youen
Hello Youen
If I understand correctly, the zwave thing does not matter here, things would be exactly the same if you wanted to talk to a classical 1-wire master?
So what you want to do is emulate a DS18B20 sensor. For that, you need to understand the specific protocol of this device, you can look at this document for example : http://www.adafruit.com/datasheets/DS18B20.pdf, check the section "DS18B20 FUNCTION COMMANDS"
For a very basic operation, you'll need to understand the temperature conversion command, and how to send the response (which happens after the "read scratchpad" command, two bytes of the scratchpad are used to transmit the temperature). However, if your zwave device, which acts as a master, always sends configuration, or performs other operations, you might need to implement that part of the protocol as well.
Once you understand the protocol, implementing it with my library should be straightforward : as in the sample, you initialize the library with the device ROM (which may or may not be an official ROM number, but must have the correct family code), and register the event callback. This callback is a function that you write yourself, and will be called each time something happens (a byte is received, an error occurs, etc.). Then you'll need to react to the various commands that can be sent to a DS18B20 ("begin temperature conversion" and "read scratchpad" being the most important).
Communicating with your development PC using the serial port of the Arduino should help you in the process of understanding what happens in your program (so that you can see what command you have received, etc.)
aivs
Hi, if you show how to emulate the DS18B20, it will be great!
aivs
I'm trying to implement DS18B20 with OneWireArduinoSlave library.
First problem - I need to respond to the master reset. How to do it?
From documentation:
"When the DS18B20 detects
this rising edge, it waits 15µs to 60µs and then transmits a presence pulse by pulling the 1-Wire bus low
for 60µs to 240µs."
I do so, but it not works:
Code: [Select]
void owReceive(OneWireSlave::ReceiveEvent evt, byte data) {
switch (evt) {
   // Detect Reset on bus
   case OneWireSlave::RE_Reset:
       Serial.println("Reset");
       _delay_us(60);
       pinMode(2, OUTPUT);
       digitalWrite(2, HIGH);
       _delay_us(200);
       digitalWrite(2, LOW);
   case OneWireSlave::RE_Byte:
     // Read Scratchpad [BEh] command
     if (data == 0xBE) {
      Serial.println("Scratchpad command");
OneWire.write(&acknowledge, 1, NULL);
default:
Arduino slave receives Reset, so in console I see "Reset".
Youen
I've seen your message on github, and I think you've already solved this particular issue, but just in case I'll answer the question anyway: the library handles the reset procedure, so you don't have to implement that part of the DS18B20 protocol.
The library listens for the reset signal, then sends the presence, and responds to the search ROM procedure as well. This is entirely automatic, and performed as a background task. In fact, you can completely ignore the RE_Reset event, you probably don't need it in your case.
It will then receive bytes (automatic as well), and call owReceive for each byte received. Also, you don't need to read or set the pin mode directly, and that would probably interfere with what the library is doing.
Finally, as I said on github but it might be usefull for other readers here as well, you should avoid any long operation in owReceive, such as waiting, performing serial communication, etc. The default serial speed is 9600bps, which means to send "Reset" it will take 4167 micro seconds. At this point, you've probably already missed everything you hoped to receive.
What you can do, however, is store what you receive in a global variable, and when you detect that variable has changed in your main loop, write to the serial port from the main loop. This way, you don't block other background tasks. Don't forget to mark the variable as volatile, since it's going to be modified from an interrupt handler (owReceive is always called from an interrupt handler).
aivs
@Youen Big thanks for the library!
I created a DS18B20 Emulator based on OneWireArduinoSlave library, it's really very easy!
Code: [Select]
#include "Arduino.h"
#include "LowLevel.h"
#include "OneWireSlave.h"
// Defines to access to Low and High bytes
#define Lo(x)   ((x) & 0xFF)
#define Hi(x)   (((x)>>8) & 0xFF)
// This is the pin that will be used for one-wire data (depending on your arduino model, you are limited to a few choices, because some pins don't have complete interrupt support)
// On Arduino Uno, you can use pin 2 or pin 3
Pin oneWireData(2);
// This is the ROM the arduino will respond to, make sure it doesn't conflict with another device, 0x28 - DS18B20 identificator
const byte owROM[] = {0x28, 0xF2, 0x27, 0xD6, 0x04, 0x00, 0x00, 0x3D};
// 0 - Low Byte Temperature
// 1 - High Byte Temperature
// 2-7 - reserved
// 8 - CRC8
byte SCRATCHPAD[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0x00, 0x10, 0x00};
// This function will be called each time the OneWire library has an event to notify (reset, error, byte received)
void owReceive(OneWireSlave::ReceiveEvent evt, byte data);
// Setup the OneWire library
OneWire.setReceiveCallback(&owReceive);
OneWire.begin(owROM, oneWireData.getPinNumber());
delay(100);
  int temperature = 25;
  // Add temperature to the SCRATCHPAD
  if (temperature > 99)  temperature = 99;
  if (temperature < -55) temperature = -55;
  if (temperature >= 0) {
    SCRATCHPAD[0] = Lo(temperature*16);
    SCRATCHPAD[1] = Hi(temperature*16);
  else {
    SCRATCHPAD[1] = Hi(temperature*16) | 0xF8;
  // Add CRC8 to the SCRATCHPAD
  SCRATCHPAD[8] = OneWire.crc8(SCRATCHPAD,8);
cli();//disable interrupts
sei();//enable interrupts
switch (evt) {
      if (data == 0xBE) {
        // Send SCRATCHPAD 9 byte with temperature and CRC
        for (byte i = 8, j = 1; j<=9; i--, j++) {
          OneWire.write(&SCRATCHPAD[i], j, NULL);
          //Serial.print(5);
    case OneWireSlave::RE_Error:
  default:
