Loading...
Pages: [1]   Go Down
Author Topic: Need some help!!  (Read 398 times)
Kuala Lumpur, Malaysia
Offline Offline
Full Member
View Profile
WWW
I went trying out my LED by connecting it to the 5V and the ground pin ( 2k ohm resistor is also present ). Suddenly, the LED was just flickering and died out. I was running one of my self-programmed 'reset' mode below. But how come this could happen?
Quote
Logged
arduino-freelancer.blogspot.com
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Defective LED (?)
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Full Member
View Profile
WWW
I dont think so
Logged
SW Scotland
Offline Offline
Edison Member
Arduino rocks
View Profile
led plus resistor across 5 volt supply must glow unless :-
a) no 5 volts
b) resistor defective
c) led defective
d) led connected wrong way round
e) you just dreamt it
f) you just went blind
Logged
Minnesota, USA
Offline Offline
Jr. Member
Arduino rocks
View Profile
Whats your Forward Voltage and Nominal Current rating on your LED?
What led you to choose a 2K Ohm Resistor?
I have a feeling your LED might not be dead, you're just giving it only 1.4 milliAmps.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
My money is on faulty wiring. Are you using solder less bread board? If so rattle the wires.
Logged
Offline Offline
Full Member
View Profile
WWW
Now I knew why, I was trying to save my time. So I had connected it on a breadboard through the power pins ( most left and right side ) with a 2K ohm resistor. As we know, the breadboard connects power and ground vertically. Therefore adding a resistor is useless. I think this should be the reason why the led had died out ( supplying a voltage of 5V directly although there is a 2k ohm resistor present ). By the way, thank all of you for the replies!!!!    ' v '
« Last Edit: July 06, 2011, 05:55:13 am by low5545 » Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Quote
I want to use a good quality 9v battery
If you ever find one, be sure to let us know.
(if you have a specific question, it is best to start a new thread, rather than hijacking someone else's unrelated thread)
Logged
Durham UK
Offline Offline
Full Member
aka Craig Turner
View Profile
WWW
My error. Just finding my way around here.
Logged
Craig Turner, blog: http://gampageek.blogspot.co.uk/ It helps with my learning if I write things down, esp. for others to follow (constructive comments welcomed to improve)
Pages: [1]   Go Up
Print
Jump to:
