Topic: Need some help!! (Read 977 times) previous topic - next topic
I went trying out my LED by connecting it to the 5V and the ground pin ( 2k ohm resistor is also present ). Suddenly, the LED was just flickering and died out. I was running one of my self-programmed 'reset' mode below. But how come this could happen?
arduino-freelancer.blogspot.com
AWOL
jackrae
led plus resistor across 5 volt supply must glow unless :-
a) no 5 volts
b) resistor defective
c) led defective
d) led connected wrong way round
e) you just dreamt it
f) you just went blind
dshay
Whats your Forward Voltage and Nominal Current rating on your LED?
What led you to choose a 2K Ohm Resistor?
I have a feeling your LED might not be dead, you're just giving it only 1.4 milliAmps.
Grumpy_Mike
My money is on faulty wiring. Are you using solder less bread board? If so rattle the wires.
#6
Jul 06, 2011, 12:53 pm Last Edit: Jul 06, 2011, 12:55 pm by low5545 Reason: 1
Now I knew why, I was trying to save my time. So I had connected it on a breadboard through the power pins ( most left and right side ) with a 2K ohm resistor. As we know, the breadboard connects power and ground vertically. Therefore adding a resistor is useless. I think this should be the reason why the led had died out ( supplying a voltage of 5V directly although there is a 2k ohm resistor present ). By the way, thank all of you for the replies!!!!    ' v '
AWOL
I want to use a good quality 9v battery
If you ever find one, be sure to let us know.
(if you have a specific question, it is best to start a new thread, rather than hijacking someone else's unrelated thread)
trendski
My error. Just finding my way around here.
Craig Turner, blog: http://gampageek.blogspot.co.uk/ It helps with my learning if I write things down, esp. for others to follow (constructive comments welcomed to improve)
