Topic: Fast serial output for multiple Ping )) Ultrasonic Sensors (Read 4511 times) previous topic - next topic
ygreq
Jul 05, 2011, 10:06 pm Last Edit: Jul 05, 2011, 10:40 pm by ygreq Reason: 1
Hi folks,
I am trying desperately to get 4 Ultrasonic Sensors to output to serial as fast as possible. The thing is when I use a single Ultrasonic Sensor I can output "in real time" once every 10ms with the first patch I will copy here.
After trying to multiply the code lines from this first sketch to adapt it to 4 sensors, I found a thread which suggested using arrays for multiple sensors (that I will copy here as a second sketch).
Well I tried multiplying the code lines, I tried the sketch with arrays, I tried stripping this second sketch, I even deleted the delays which I know is not such a good idea, all with no luck!
Is there a fix somewhere so as an arduino with multiple sensors would output to serial as fast as an arduino with only one sensor?
This is the typical sketch for outputing to serial from a single Ultrasonic Sensor
Code: [Select]
/* Ping))) Sensor
   This sketch reads a PING))) ultrasonic rangefinder and returns the
   distance to the closest object in range. To do this, it sends a pulse
   to the sensor to initiate a reading, then listens for a pulse
   to return.  The length of the returning pulse is proportional to
   the distance of the object from the sensor.
   The circuit:
    * +V connection of the PING))) attached to +5V
    * GND connection of the PING))) attached to ground
    * SIG connection of the PING))) attached to digital pin 7
   http://www.arduino.cc/en/Tutorial/Ping
   created 3 Nov 2008
   by David A. Mellis
   modified 30 Jun 2009
   by Tom Igoe
   This example code is in the public domain.
// this constant won't change.  It's the pin number
// of the sensor's output:
const int pingPin = 7;
  // initialize serial communication:
  // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, cm;
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  cm = microsecondsToCentimeters(duration);
  Serial.print(cm);
  Serial.print(" cm");
  delay(10);
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
This is the second sketch which is skipping a few "beats" even though I tried everything I could! It's for multiple Ultrasonic Sensors
Code: [Select]
//http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1236272388
int ultraSoundSignalPins[] = {7,8,9,12}; // Front Left,Front, Front Right, Rear Ultrasound signal pins
char *pingString[] = {"a "," b ", " c ", " d "}; // just something to print to indicate direction
  unsigned long ultrasoundValue;
  for(int i=0; i < 4; i++)
    ultrasoundValue = ping(i);
    Serial.print(pingString[i]);
    Serial.print(ultrasoundValue);
    delay(10);
  delay(10);
//Ping function
unsigned long ping(int i)
  unsigned long echo;
  pinMode(ultraSoundSignalPins[i], OUTPUT); // Switch signalpin to output
  digitalWrite(ultraSoundSignalPins[i], LOW); // Send low pulse
  delayMicroseconds(2); // Wait for 2 microseconds
  digitalWrite(ultraSoundSignalPins[i], HIGH); // Send high pulse
  delayMicroseconds(5); // Wait for 5 microseconds
  digitalWrite(ultraSoundSignalPins[i], LOW); // Holdoff
  pinMode(ultraSoundSignalPins[i], INPUT); // Switch signalpin to input
  digitalWrite(ultraSoundSignalPins[i], HIGH); // Turn on pullup resistor
  echo = pulseIn(ultraSoundSignalPins[i], HIGH); //Listen for echo
  return (echo / 58.138); //convert to CM
As I said, I tried many things to make it work faster (but it still skips a few readings):
- deleted char *pingString[] = {"a ","b ", "c ", "d "}; and anything related
- changed return (echo / 58.138); to return (echo); as to not convert to centimeters on the arduino and even deleted it
- decreased the two delays in the void loop (even lower than 10 each) and even deleted the two delays
Nothing seems to work!
Any solutions are truly appreciated!
ygreq
robtillaart
use Serial.begin(115200)  that makes the serial output 12 times as fast
Code: [Select]
should not be used,  just use :   cm = duration/58; in your main code. It is not the main overhead but definitely faster...
Have you timed your ping(i) function, how many millis it takes?
Please try ping(i) as below : // just one lookup instead of looking it up every line of code
Code: [Select]
  uint8_t pin = ultraSoundSignalPins[i];
  pinMode(pin, OUTPUT);
  digitalWrite(pin, LOW);
  digitalWrite(pin, HIGH);
  pinMode(pin, INPUT);
  return pulseIn(pin, HIGH) /58.138;  //Listen for echo && convert to CM
2 cents,
Rob
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
ygreq
#2
Jul 06, 2011, 12:04 pm Last Edit: Jul 06, 2011, 12:06 pm by ygreq Reason: 1
Hey Rob,
Thank you for your input.
1. The thing is changing the Serial.begin doesn't help at all. I tried. It seems there is a limitation from within arduino and how it reads more than one sensor.
2. About
Quote
. Thank you! I think it helps when using the sketch for the single sensor, but still I need speed improvements when using multiple sensors (so this doesn't help unfortunately with the second sketch).
3. About
Quote
, I think what you are suggesting here is already in the second sketch I posted, the one using arrays.
I stripped the second sketch for multiple sensors even more. It outputs "duration" values, not distance. Still no results!
Code: [Select]
int ultraSoundSignalPins[] = {7,8,9,10}; // Front Left,Front, Front Right, Rear Ultrasound signal pins
    Serial.print(" ");
    delay(10);
  delay(10);
//Ping function
  unsigned long echo;
I still need desperate help!
ygreq
I am looking at how fast the TX LED blinks when I have the first sketch for a single sensor and it blinks so fast that I can not see it go LOW. On the other hand, when I have the second sketch (for 4 sensors) .. well.. Let me just say, I see it blink! :)
I think a solution would be for the arduino to send to serial one sensor info while calculating the second one and so on.
Any suggestions on how I can achieve this?
Thank you kindly!
ygreq
ygreq
I did it!!
Real time, baby! :P
Anyone wanting to improve the code, please do! But for now all I can say is IT WORKS! It is based on the first sketch I posted. It outputs duration and you have to do the calculations to find the distance in another program or just add the calculations yourselves! In this configuration, use routing in max 5 for example to check each sensor.
Code: [Select]
const int pingPin1 = 7;
const int pingPin2 = 8;
const int pingPin3 = 9;
const int pingPin4 = 10;
  long duration1;
  pinMode(pingPin1, OUTPUT);
  digitalWrite(pingPin1, LOW);
  digitalWrite(pingPin1, HIGH);
  pinMode(pingPin1, INPUT);
  duration1 = pulseIn(pingPin1, HIGH);
  Serial.print("A ");
  Serial.println(duration1);
  long duration2;
  pinMode(pingPin2, OUTPUT);
  digitalWrite(pingPin2, LOW);
  digitalWrite(pingPin2, HIGH);
  pinMode(pingPin2, INPUT);
  duration2 = pulseIn(pingPin2, HIGH);
  Serial.print("B ");
  Serial.println(duration2);
  long duration3;
  pinMode(pingPin3, OUTPUT);
  digitalWrite(pingPin3, LOW);
  digitalWrite(pingPin3, HIGH);
  pinMode(pingPin3, INPUT);
  duration3 = pulseIn(pingPin3, HIGH);
  Serial.print("C ");
  Serial.println(duration3);
  long duration4;
  pinMode(pingPin4, OUTPUT);
  digitalWrite(pingPin4, LOW);
  digitalWrite(pingPin4, HIGH);
  pinMode(pingPin4, INPUT);
  duration4 = pulseIn(pingPin4, HIGH);
  Serial.print("D ");
  Serial.println(duration4);
delay(10);
timlee
Hi, your code worked, but the readings that I get are jumping all around, from high to low, low to high every second. Is there anyway way to make it more stable or did you add a capacitor or something?
I added a 0.47uF capacitor in parallel to +5V and GND, a 100ohm resistor to +5V. Readings seems more stable but increases delay, making the readings inaccurate. Please advise.
timlee
I did it!!
Real time, baby! :P
Code: [Select]
  long duration1;
  Serial.print("A ");
  long duration2;
  Serial.print("B ");
  long duration3;
  Serial.print("C ");
  long duration4;
  Serial.print("D ");
delay(10);
Hi I tried your code. Only the last sensor gave an accurate reading. The first two is way off. Any advice on this? Here is my modified code:
Code: [Select]
const int pingPin1 = 2;
const int pingPin2 = 7;
const int pingPin3 = 8;
//const int pingPin4 = 10;
  long duration1, cm;
    cm = microsecondsToCentimeters(duration1);
  Serial.print("A ");
  Serial.print(cm);
    Serial.print("\t");    // prints a tab
  long duration2, cm2;
    cm2 = microsecondsToCentimeters(duration2);
  Serial.print("B ");
  Serial.print(cm2);
  long duration3, cm3;
    cm3 = microsecondsToCentimeters(duration3);
  Serial.print("C ");
  Serial.println(cm3);
/* long duration4;
  Serial.print("D ");
delay(100);
ygreq
Sorry timlee!
I just saw your replies.
@timlee and everyone else interested. I did not add any capacitors. The code just works for me. I just take the output coming out of the serial and use it in Max.
You can see a video of the installation where I used the sensors here. They were detecting how much the drawers were opened: http://kotkivisuals.com/site/lafarge-interactive-video-installation/
notoriou5
Good Evening together,
I have the exact problem like discussed above with the sensors, the reading is just to slow...
I build this code using Port Manipulation, but somehow I only get a 0 back.
long laenge;
long cm;
void setup ()
 DDRC = B00000010;
 PORTC = B00000000;
 PORTC = B00000010;
 delayMicroseconds(10);
 PORTC = B00000000;
 PINC = B00000001;
 laenge = PINC;
 cm = (laenge*34)/2000;
 Serial.print(cm);
 Serial.print("/n");
Do you guys know about that? Maybe someone has an idea to solve this problem?
Thanks
notoriou5
robtillaart
I think I know how to solve this but ut is not trivial.
You should start the ping ))) on all pins, preferably with direct port manipulation as
notoriou5 proposed.
but you should not use pulseIN for the receiving part as that is blocking code.
Instead you should use pinChangeInterrupts to get the timing of the 4 return signals.
if all 4 are set then one can convert timing to distance
in pseudocode
Code: [Select]
volatile uint32_t timing[4];
  // clear timing;
  for (int i=0; i< 4; i++) timing[i] = 0UL;
  initializePCI( <pins> ); // to be investigated
  PORTC = pinMask;
  delayMicroseconds(s);
  // WAIT UNTIL READY
  bool ready = false;
  while (!ready)
     ready = true;
     for (int i=0; i<4; i++) ready = ready && timing[i] != 0);
    distance[i] = timing[i] /58;
    Serial.println(distance[i]);
void PCinterrupt()
  pin = ....somecode...
  if (pin == HIGH) return; // wait for the LOW
  timing[pin] = micros();
something like that.
read this thread - http://forum.arduino.cc/index.php?topic=87195.0 -
latest code - https://code.google.com/p/arduino-pinchangeint/  - 2.30 beta
Rob Tillaart
notoriou5
Hi robtillaart,
I was trying to work with your code but I couldn't understand completely. So I was trying my own one on the base of yours and the Internet. But somehow I my EventTime is Counting up instead of giving me the time of the pinchange. Is it possible to maybe only trigger High?? And how?? Would be great if you could look over this code of mine.
I only connected the Trigger to A0 and the Echo to A14.
_________
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
volatile long unsigned eventTime;
volatile long unsigned previousEventTime;
volatile long unsigned timeSinceLastEvent;
volatile long unsigned Abstand;
volatile byte portKstatus;
volatile byte eventFlag;
void setup ()
 DDRK = B00000000; //A8-15 INPUT
 PORTK = B11111111; //HIGH
 DDRF = B11111111; //A0-7 Output
 sbi (PCICR,PCIE2);
 sbi (PCMSK2, PCINT23);
 sbi (PCMSK2, PCINT22);
 sbi (PCMSK2, PCINT21);
 sbi (PCMSK2, PCINT20);
  PINK = B00000000;
  PORTF = B11111111;
  PORTF = 00000000;
  if (eventFlag == 1 && (eventTime-previousEventTime>100))
    Abstand = (eventTime*34)/2000;
    timeSinceLastEvent = eventTime - previousEventTime;
    previousEventTime = eventTime;
    Serial.print(eventTime);
    Serial.print("ms");
    Serial.print('\t');
    Serial.print(timeSinceLastEvent);
    Serial.print("ms");
    Serial.print('\t');
    Serial.print("Abstand:");
    Serial.print(Abstand);
    Serial.print('\t');
    Serial.print(portKstatus,BIN);
    Serial.print('\n');
    eventFlag = 0;
    eventTime = 0;
ISR (PCINT2_vect)
  portKstatus=PINK;
  eventTime=millis();
  eventFlag=1;
___________
And thats the output:
___________
101ms   101ms   Abstand:1           10111111
1102ms   1001ms   Abstand:18   11111111
2104ms   1002ms   Abstand:35   11111111
3105ms   1001ms   Abstand:52   11111111
4108ms   1003ms   Abstand:69   11111111
5109ms   1001ms   Abstand:86   11111111
6111ms   1002ms   Abstand:103   11111111
7112ms   1001ms   Abstand:120   11111111
8115ms   1003ms   Abstand:137   11111111
9116ms   1001ms   Abstand:154   11111111
10118ms   1002ms   Abstand:172   11111111
11120ms   1002ms   Abstand:189   10111111
12122ms   1002ms   Abstand:206   11111111
13123ms   1001ms   Abstand:223   11111111
14126ms   1003ms   Abstand:240   11111111
15127ms   1001ms   Abstand:257   11111111
16129ms   1002ms   Abstand:274   11111111
______
Thanks a lot for your help :)
