Topic: Tricks of the trade - Connecting projects to the Arduino boards 'reusably' (Read 5271 times) previous topic - next topic
Cylindric
Hello hello,
I was wondering what sort of insider "tricks of the trade" some of you might have.
Particularly right now, I'm working on two (my first two ;)) projects, and would rather not buy a second Uno, but was curious as to what methods you might be using to quickly connect and disconnect a semi-permanent breadboard mess of experimental components to an Arduino.
I was thinking of just having multiple small (or large) breadboards that bring all their pin and power leads to a single pin-header, then I can simply connect and disconnect a board without too much stress.
What sort of connectors?  I'm not thinking Mega here with dozens of pins, there will probably only be in the order of 8-16 pins to deal with.
What are the black connectors called like used on the Arduino board, and the bottom of Shields?  I think they might be cool if I can fix the wires into them.
Grumpy_Mike
Quote
0.1" single row header pins.
I just use them, there are some photos of this on this project:-
http://www.thebox.myzen.co.uk/Hardware/Crazy_People.html
Cylindric
justjed
Would this work? http://liudr.wordpress.com/gadget/phi-connect/
... it is poor civic hygiene to install technologies that could someday
facilitate a police state. -- Bruce Schneier
Bobnova
The easy way is to use a Bare Bones Board, Really Bare Bones Board, or Boarduino type clone, they plug into the breadboard directly.
The Bare Bones Board is my favorite, moderndevice.com sells 'em.
roypogi
My vote also goes to the boarduino from Adafruit. You can also build your own so you can tailor it to all your needs. About a year ago I did something like this(attached) with all the pins coming off on one side in a single line. Easy to use and consumes very little breadboard space. I have since modified its power supply and a smaller board.
CrossRoads
What's connected at the circled area near A1? Is that for a resonator?
roypogi
Yes, I have since replaced it with an SMD part as it sticks out a little bit.
CrossRoads
Did you make it easy to connect something like an FTDI Basic for easy downloading? Or does one just connect to the appropriate pins once plugged in the breadboard using flying leads off the USB/RS232 adapter?
roypogi
I have always used the ICSP for my projects but I guess if needed a 6 pin header can be placed on the board(or as you suggested using the breadboard). I actually gave it a name when I designed it. SAduino, short for Side Action Arduino. :-)
I'll look for the redesigned board files for those whore are interested, but the design is basic and straight forward.
CrossRoads
I had a little fun mimicking a Side-uino design using Duemilanove kind of parts, and watch Eagle go thru its paces laying it out.
Maybe will help it out a little tomorrow and neaten it up some.
roypogi
Nice!
Maybe we could spin this off as a community designed yet another arduino clone. I know the form factor works well because of its thin breadboard foot print
CrossRoads
I want to take a shot at putting the DIP part in there, give folks a chance to recover when they damage the 328.
Think I just need to move the big cap down under the regulator to make room.
retrolefty
Long live the DIP package. Oh and leave room for socket mounting the 328 8)
CrossRoads
