Loading...
Pages: [1]   Go Down
Author Topic: Arduino Mega2560 not appearing in device manager  (Read 510 times)
Offline Offline
Newbie
View Profile
Hi, here's my situation.  My Arduino Mega2560 used to work just skippy.  The last program I put on it was a modified "Blink" that has the delay set to 5 seconds.
Now, when I plug it into my computer, my computer simply does not see it.  The arduino turns on and the blink program runs (the pin 13 led blinks on and off every 5 seconds) but my computer doesn't show it in the device manager and doesn't even seem to know that it exists.  I can't really upgrade the drivers if I can't see the arduino with the device manager.
Any idea why this would be happening?  Any idea how to fix it?  I've tried plugging in a Duemilanove and the computer sees it and it works wonderfully.  The Mega2560 just doesn't show up.
Logged
Offline Offline
Newbie
View Profile
it's possible that the FTDI chip is damaged, but before considering that possibility, I'd recommend you try to re-install the FT232 drivers (there is a copy in the arduino folder I believe, or you could get them from the FTDI website).
Logged
Left Coast, CA (USA)
Online Online
Brattain Member
Measurement changes behavior
View Profile
The problem with your advice is that the arduino mega2560 board does not use the FTDI device nor it's driver. This board like the Uno uses the atmel 8u2 microcontroller as a USB serial converter and uses a different software driver.
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
It is unlikely the FTDI chip is damaged since the Mega2560 doesn't have one.  It does, however, use an 8u2 programmed as a USB-to-Serial device.  Comparing the functionality of a Mega2560 and Duemilanove really doesn't tell you anything other than the USB ports work correctly.  It would be like saying "My Mega2560 doesn't work but my keyboard does."  In terms of USB device, the only thing the two Arduinos have in common is that they are USB devices.  They aren't the same kind of USB device.
Are you using the same cable to connect your Mega2560 and Duemilanove?  You'd be surprised how often the cable is the issue.
A trick to try is holding the ATmega in RESET while attaching the USB cable.  Press and hold the reset button, plug in the cable, see if Device Manager recognizes it.  The RESET button isn't connected to the 8u2, just the big microprocessor.
Logged
www.cmiyc.com - A guide to being an Enginerd
Offline Offline
Newbie
View Profile
Quote
That's why I mentioned that the Duemilanove worked, I used the same cable for both.  I also tried the trick with holding the reset button and plugging in the cable and that didn't seem to work.
Logged
Dallas, Texas
Offline Offline
Sr. Member
View Profile
WWW
An odd point of interest is, my mega2560 identified itself as an arduino uno until I updated the 8u2 firmware. Now it is properly identified as an arduino mega 2560. The upgrade also resolved my flashing timeouts. Special thanks to draythomp for making known a fix was readily available.
« Last Edit: July 15, 2011, 09:50:14 am by gerg » Logged
Offline Offline
Newbie
View Profile
@retrolefty and @James C4S
In that case, sorry about the misinforming post. I'm definitely planning to go through the Mega2560 schematic again tonight to see how the Atmega8U2 is used. Could be useful for my own design work
Logged
Pages: [1]   Go Up
Print
Jump to:
