Loading...
Pages: [1]   Go Down
Author Topic: 3V EL inverter - how to control directly from Arduino  (Read 829 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I got a 3V EL interver and 3m of blue EL wire. I found out the 3V output of the Arduino board is sufficient for it to light up.
It it possible (and a good idea) to control the EL inverter to the arduino power supply and control it with a digital pin?
Or, could it even be powered by the signal of a digital pin?
(Yes I am quite noobish with electronics, please type your answer loud and slowly...    smiley-wink)
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
How's this:
poooooooosssst aaaa liiiiinnnnkkkkk tooooooo theeeeeee paaaaarrrrrttttssssss.....
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
Newbie
Arduino rocks
View Profile
CrossRoa, I can read you loud and clear!
It is this 3V EL inverter: http://www.sparkfun.com/products/10201
Datasheet: http://www.sparkfun.com/datasheets/Components/LED/SPECIFICATION%20of%203V3M%20-%20%E5%89%AF%E6%9C%AC.pdf
And this 3m length EL wire: http://www.sparkfun.com/products/10195
Datasheet: http://www.sparkfun.com/datasheets/Components/LED/Technical%20Information%20of%20Flexible%20Neon%20wire.pdf
and an Arduino UNO
KE7GKP, the board is neither sweating nor smoking, and still alive. I have seen the EL Escudo and other EL shields but am wondering whether I can spare the expenses.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
KE7GKP, thanks a lot for your advice and explanation of the UNO board! This pretty much means I should have used relays/optoelectric couplers many times before  smiley-roll-blue
I'll have  close look at the UNO datasheet and get an ampmeter right away...
Logged
Pages: [1]   Go Up
Print
Jump to:
