Topic: Learning eagle (Read 10294 times) previous topic - next topic
bld
One problem left... With the polygons, I am getting a "Width" error on the first line I draw on them, when I check it against the dru file.
What can cause that?
captain-slow.dk | non contagious!
CrossRoads
Ok, just post the schematic one more time please.
Also, please check the Tab of the 7805 - that will sit on the plane on the board. If the Tab is not ground, you will need to place a rectangle under it that will let the tab be isolated from the ground plane.
If you are bringing in >5V, you would bring in GND also - I stil suggest making that 3rd pin GND.
bld
Got the problem fixed... Was a with in the polygons that caused the error.
For future reference, did "Info" on the polygons, and selected a larger width.
Think I got it isolated and all... and if not... I still got some small isolation things exactly for that purpose, even with special washers to isolate the bolt too.
CrossRoads
Did  you decide not to add the FTDI connections?
Is pretty simple, follow the pinout used on a Promini.
http://arduino.cc/en/uploads/Main/Arduino-Pro-Mini-schematic.pdf
Need to add a 0.1uF (100nF) cap from the DTR pin to the reset line so PC software can create a reset.  Some people don't like that, so can make the cap connection jumperable as well.
bld
Yeah, skipped the FTDI, got no need for it anyways... got another test thing where I can upload the sketch and test everything before putting the chip into the other device, and when it is in, I won't be able to get to it easily anyways, plus it is pretty simple what it is going to to too, so not much changing when it works. :)
Tried to order them now... And will then learn from the problems when I get the boards ;)
CrossRoads
Sounds like you have a plan then.
bld
Yeah, I just hope it wont lead to total failure. ;)
But thanks for all the help! :D
mmcp42
I'm impressed
just a few days ago "what's this EAGLE then?"
today "I've ordered the boards"
well done you!
there are only 10 types of people
them that understands binary
and them that doesn't
bld
I'm impressed
well done you!
Apparently I got just the info needed to "see the light" in it :)
JChristensen
Ok, now the tricky bit - draw a polygon (button looks like a piece of paper with top left corner torn off - click a corner follow the perimiter of the board, must finish up where started or will get "illegal poygon" error or similar), name it GND, on both sides of the board.  Your thru holes will connect them.
Click the Rubberband button, and let eagle connect everything up to GND.  May even be to "ripup" the ground traces.
Have been playing with ground planes/polygons, all seems well, but once everything is routed, I like to ripup the polygons to make everything else easier to see.  Interesting that running the CAM job on the board in this state (attached) works fine, and all the "unconnected" pads get connected to the ground plane just fine.
I added the ground planes last, and found that I could ripup previously routed ground traces as you said.  In fact, I'd suggest doing so.  Haven't tried it, but maybe adding the ground plane polygons first would be the way to go...
CrossRoads
Yes, I find if you don't have the ground plane, a lot of space is wasted with ground traces running around.
