i have 2 problems... one is deleting a line from a file. the second is reading data into multiple arrays from sd card file.
i have created a device that reads and parses data from serial. so i get data, i convert it into floating point numbers, and save number (and more but not interfering with the problems), the user can hit a delete button that will get rid of the data from the array how should i go about getting it off the sd card? (i am currently using the tinyfat library from
http://henningkarlsen.com/electronics/a_l_tinyfat.php)
the next problem is every time the unit resets i have it add the line "reset". is there any way to get the file name to increment? (ex. "data1.txt, data2.txt, etc.) or is there a way to get it to scan for a line "reset" and split into array1, array2 etc.
the end result is i want the unit to take the history of data points (unknown number of both history and points) and graph each ?file? in a different color. say i have 5 "historys" 4 with 50 data points 1 with 25, i want them to be in 5 different colors all on the graph.
