I've been playing with the Ethernet Shield and created a fairly straightforward code that can be easily modified for your next Ethernet project. In the demo I used a web browser, but the Arduino Data Web Server would respond equally well when hit by a Windows Application, PHP page, or even an iPhone app. You can easily support any number of commands and parameters to control the arduino pins, perform calculators, and/or return values back to the web client. Enjoy!
http://g33k.blogspot.com/2010/09/arduino-data-webserver-sample-web.htmlDemo
[media]http://www.youtube.com/v/FK_t6UlJBr8[/media]
Code explained
[media]http://www.youtube.com/watch?v=d_6iieogLbM[/media]
Code explained continued (too long for YouTube)
[media]http://www.youtube.com/watch?v=FKGNCANXGj4[/media]
Performs actions on Arduino and/or returns data from Arduino to a webbrowser request URL:
- To turn on LED on pin 8, use web browser to visit your Arduino via: http://x.x.x.x/digitalWrite/7/1
- To turn it off send: http://x.x.x.x/digitalWrite/7/0
- To read analog0 value, send: http://x.x.x.x/analogRead/0
IMPORTANT:
Commands are case sensitive, but I wrote this as simple as possible so it can be easily adapted to your needs.
Have fun!
created Sept 17, 2010
by Hari Wiguna, g33k.blogspot.com
#include <SPI.h>
#include <Ethernet.h>
#include <string.h>
// MAC address can be anything that is unique within your network.
// IP is the address the Arduino Ethernet Card would respond to. It needs to be an unused address within your network.
byte mac[] = {0x00, 0x1E, 0x2A, 0x77, 0x24, 0x02 };
byte ip[] = {192,168,7,12 }; // This is typically 10.0.0.x
Server server(80); // Port 80 is http.
//-- Commands and parameters (sent by browser) --
char cmd[15]; // Nothing magical about 15, increase these if you need longer commands/parameters
char param1[15];
char param2[15];
//-- Sample Ports ---
void SetupSamplePorts()
// To illustrate how to use this, I have an LED and a Potentiometer.
// The 10K potentiometer left lead is connected to GND, right lead to +5V, and middle lead to Analog 0.
// The LED cathode is on digital pin 7 and anode is on pin 8.
pinMode(7,OUTPUT); digitalWrite(7,LOW); // I use this pin as GND for the LED.
pinMode(8,OUTPUT); // Sample output, unable to use built-in LED at pin 13 because Ethernet Shield uses pins 10,11,12,13.
Ethernet.begin(mac, ip);
server.begin();
Serial.begin(57600);
SetupSamplePorts();
#define bufferMax 128
int bufferSize;
char buffer[bufferMax];
Client client = server.available();
if (client)
WaitForRequest(client);
ParseReceivedRequest();
PerformRequestedCommands();
client.stop();
void WaitForRequest(Client client) // Sets buffer[] and bufferSize
bufferSize = 0;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (c == '\n')
if (bufferSize < bufferMax)
buffer[bufferSize++] = c;
PrintNumber("bufferSize", bufferSize);
void ParseReceivedRequest()
Serial.println("in ParseReceivedRequest");
Serial.println(buffer);
//Received buffer contains "GET /cmd/param1/param2 HTTP/1.1". Break it up.
char* slash1;
char* slash2;
char* slash3;
char* space2;
slash1 = strstr(buffer, "/") + 1; // Look for first slash
slash2 = strstr(slash1, "/") + 1; // second slash
slash3 = strstr(slash2, "/") + 1; // third slash
space2 = strstr(slash2, " ") + 1; // space after second slash (in case there is no third slash)
if (slash3 > space2) slash3=slash2;
PrintString("slash1",slash1);
PrintString("slash2",slash2);
PrintString("slash3",slash3);
PrintString("space2",space2);
// strncpy does not automatically add terminating zero, but strncat does! So start with blank string and concatenate.
cmd[0] = 0;
param1[0] = 0;
param2[0] = 0;
strncat(cmd, slash1, slash2-slash1-1);
strncat(param1, slash2, slash3-slash2-1);
strncat(param2, slash3, space2-slash3-1);
PrintString("cmd",cmd);
PrintString("param1",param1);
PrintString("param2",param2);
void PerformRequestedCommands()
if ( strcmp(cmd,"digitalWrite") == 0 ) RemoteDigitalWrite();
if ( strcmp(cmd,"analogRead") == 0 ) RemoteAnalogRead();
void RemoteDigitalWrite()
int ledPin = param1[0] - '0'; // Param1 should be one digit port
int ledState = param2[0] - '0'; // Param2 should be either 1 or 0
digitalWrite(ledPin, ledState);
//-- Send response back to browser --
server.print("D");
server.print(ledPin, DEC);
server.print(" is ");
server.print( (ledState==1) ? "ON" : "off" );
//-- Send debug message to serial port --
Serial.println("RemoteDigitalWrite");
PrintNumber("ledPin", ledPin);
PrintNumber("ledState", ledState);
void RemoteAnalogRead()
// If desired, use more server.print() to send http header instead of just sending the analog value.
int analogPin = param1[0] - '0'; // Param1 should be one digit analog port
int analogValue = analogRead(analogPin);
server.print("A");
server.print(analogPin, DEC);
server.print(analogValue,DEC);
Serial.println("RemoteAnalogRead");
PrintNumber("analogPin", analogPin);
PrintNumber("analogValue", analogValue);
void PrintString(char* label, char* str)
Serial.print(label);
Serial.print("=");
Serial.println(str);
void PrintNumber(char* label, int number)
Serial.print("=");
Serial.println(number, DEC);
