Topic: help with serial (Read 588 times) previous topic - next topic
flyboy
I'm trying to get my arduino to respond to serial commands so that I can then progress toward implementing a remote control home automation-esque application later on.  The problem is that I can't get it to switch between states.  Can someone please review my code and give me some input?  I'm getting tripped up somewhere, but I'm not sure where.
int ledPin = 13;
int number_in = 0;
int state = 0;
#define BLINK   0
#define NO_BLINK   1
      pinMode(ledPin, OUTPUT);
      readSerial();
      switch(state) {
        case BLINK:
           digitalWrite(ledPin, HIGH);
           digitalWrite(ledPin, LOW);
           delay(300);
           readSerial();
           if(number_in == 1)
                state = NO_BLINK;
        break;
        case NO_BLINK:
           readSerial();
           if(number_in == 0)
                    state = BLINK;
         break;
    void readSerial() {
        if (Serial.available() > 0) {
          number_in = Serial.read();
wildbill
I'd guess that this:
           if(number_in == 1)
should be this:
           if(number_in == '1')
and the same for the similar test below. I assume you're typing 1 and 0 into the serial monitor, not somehow sending ascii char 1 and 0?
robtillaart
try it with char's first
int ledPin = 13;
char char_in = '';
int state = 0;
#define BLINK   0
#define NO_BLINK   1
 char_in = readSerial();
 switch(state)
   case BLINK:
     delay(300);
     if (char_in == '1')
       state = NO_BLINK;
     break;
   case NO_BLINK:
     if(char_in == '0')
       state = BLINK;
     break;
char readSerial()
 if (Serial.available() > 0) return Serial.read();
 return '';  // empty char
Rob Tillaart
flyboy
That did it!  I figured it was something simple.  Thanks guys.
