Topic: NewSoftSerial - Pololu micro serial controller baud rate too high (Read 1 time) previous topic - next topic
william2256
If on a Duemilanove I use either the standard UART or SoftwareSerial, I can successfully command the servo.
However, if I use the NewSoftSerial library, the LED's on the Pololu serial controller indicate the baud rate is too high.
I have tried it even with baud 2400, with no success.
Any comments or suggestions would be appreciated.
Using this code:
Code: [Select]
#include "NewSoftSerial.h"
#define rxPin 8
#define txPin 9
unsigned int pos = 0;
NewSoftSerial swserial(rxPin, txPin);
    pinMode(rxPin, INPUT);
    // Keep Pololu board from getting spurious signal
    digitalWrite(txPin, HIGH);
    pinMode(txPin, OUTPUT);
    swserial.begin(9600);
void put(int servo, unsigned int angle)
    unsigned char buff[6];
    unsigned int temp;
    unsigned char pos_hi;
    unsigned char pos_low;
    temp = angle & 0x1f80;
    pos_hi = temp >> 7;
    pos_low = angle & 0x7f;
    buff[0] = 0x80; // start byte
    buff[1] = 0x01; // device id
    buff[2] = 0x04; // command number
    buff[3] = servo; // servo number
    buff[4] = pos_hi; // data1
    buff[5] = pos_low; // data2
    for (int  i = 0; i < 6; i++){
        swserial.print(buff[i], BYTE);
// Pololu pos = standard servo usec * 2, 3000 is pos 0
    for (pos = 2530; pos <= 3475; pos += 1 )
        put(0, pos);
        delay(10);
    for (pos = 3475; pos > 2530; pos -= 1)
        put(0, pos);
        delay(10);
william2256
In case it helps someone.
Found the answer on the Pololu forum.
There is noise on the line, and resetting the Pololu serial micro servo controller solves the problem.
Code: [Select]
    pinMode(rstPin, OUTPUT);
    delay(10);
    pinMode(rstPin, INPUT);
    delay(10);
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
