Topic: Time and TimeAlarms Libraries – Ask here for help or suggestions (Read 142286 times) previous topic - next topic
robtillaart
welcome,
surf one evening over the - http://www.nongnu.org/avr-libc/user-manual/group__avr__stdlib.html - site and you learn thousand new possibilities ;)
Rob Tillaart
copet_pitik
How to check alarm time on timeAlarm library?
it is possible to know the "alarm ID" is enable  or disable?
I got this code from the old forum
void checkAlarm(){
  showAlarmTime(ID1);
  showAlarmTime(ID2);
  showAlarmTime(ID3);
  showAlarmTime(ID4);
  showAlarmTime(ID5);
  showAlarmTime(ID6);
  Serial.println("----------------------------------------------------");
}//checkAlarm
void showAlarmTime(AlarmID_t id){
  time_t alarmTime = Alarm.read(id);
  if(alarmTime != 0)
    if( alarmTime <= SECS_PER_DAY)
      Serial.print(" repeat alarm with ID ");
      Serial.print(" once only alarm with ID  ");
    Serial.print(id, DEC);
    Serial.print(" set for ");
    digitalClockDisplay1(alarmTime);
}//showAlarmTime
but, i guess those code doesn't show the alarm is disabled or enabled.
thanks for any suggestions.
regards,
nug.
Program Studi Instrumentasi Medis
Politeknik Mekatronika Sanata Dharma
Yogyakarta Indonesia
PaulS
How does the alarm become enabled or disabled? Your code does that. Make your code remember that status it set the alarm to. You need to keep track of the alarm IDs, so a structure that linked alarm ID and status should be easy to implement.
struct alarmData
   int alarmID;
   bool armed;
typedef struct alarmData AlarmData;
AlarmData ad;
ad.alarmID = ?; // Assign the alarm ID
ad.armed = false; // It is not enabled
Whenever you change state, set the structure member, too.
bill2009
Hi, I've been using the Time library for a while just based on the arduinos timers. My sketch has functions to setTime() and uses now() to get it.  I sometimes want to set the time to something specific for testing but having the RTC time as default is best.
I've picked some code out of the examples to get the time from the RTC when the sketch starts.
 setSyncProvider(RTC.get);   // the function to get the time from the RTC
 if(timeStatus()!= timeSet) {
    Serial.println("Unable to sync with the RTC");
 else{
   Serial.println("RTC has set the system time");
 digitalClockDisplay(now());     cout<<endl;
If I later call setTime() with my test time it seems to stay set but I worry that some synch function might bite me when I call now() - will it?  what it i don't setSyncProvider - can i get the RTC time into the library without doing that?
Also, thank you for the library - it's been a great help.
tagalog88
I didn't find this thread until after I already posted here:
http://arduino.cc/forum/index.php/topic,71970.msg538464.html#msg538464
I'm trying to figure out how Time handles the situation when millis() rolls over but I'm not getting it.  I'd love a nudge in the right direction.
Cheers!
willem4ever
I'm trying to use the Time library with arduino 1.0-beta4  for OSX (library is located at ~willem/Documents/Arduino/Libraries/Time) when I compile I get
UdpNtpClient_WE.cpp:1:18: error: Time.h: No such file or directory
I guess something has changed for IDE 1.0 (beta) .... who knows the solution ?
Cheers, Willem.
tigro
Hi all,
I'm using the time library for my home energy monitoring project. In this project, I count the pulses coming from my electricity, gas and water meter. I also read out a  temp/humidity sensor (SHT15) located in my garage.
Each time a change in one of the "sensors" occurs (i.e pulse or value change from temp/humidity sensor) , a UDP message with a small XML string is sent to a monitoring system. Below is an example of such a message (when a value change occurs for the humidity sensor) :
<e>
<s id="6" vChMSRo="0" vChMS="1599330" vChDT="2011-09-15T10:06:01" val="487" />
</e>
Explanation :
id = sensor identification
vChMSRo = value change millis rollover (I count the number of times the millis() rolled over since start-up)
vChMS = number of milliseconds at which the value change occurred
vChDT = date/time at which the value change occurred
val = the actual value
And below is one for a pulse counter (I'm using interrupt service routines for counting pulses) :
<e>
<s id="1" pIDRo="0" pID="3" pStartMSRo="0" pStartMS="8162174" pStartDT="2011-09-15T11:55:27" pDurMS="138" pIntMS="0" state="0" />
</e>
Explanation :
pIDRo = number of times the pulse ID rolled over
pID = pulse ID
pStartMSRo = number of times the millis() rolled over at the time the pulse started
pStartMS = millis() value at the time the pulse started
pStartDT = date/time the pulse started
pDurMS = duration of the pulse in ms
pIntMS = interval between this pulse and the previous pulse (in ms)
state = current state of the pulse
The XML string contains - among other info - the date and time at which the event occurred.
For each (pulse) sensor, the date/time is stored in a time object.
For reporting, I'm using the following function to convert the time object to a date/time string :
char* XMLDateTime(time_t t)
   char chrDT[21];
   PString strDT(chrDT, sizeof(chrDT));
   strDT.print(year(t));
   strDT.print("-");
   if (month(t) < 10)
      strDT.print("0");
   strDT.print(month(t));
   strDT.print("-");
   if (day(t) < 10)
      strDT.print("0");
   strDT.print(day(t));
   strDT.print("T");
   if (hour(t) < 10)
      strDT.print("0");
   strDT.print(hour(t));
   strDT.print(":");
   if (minute(t) < 10)
      strDT.print("0");
   strDT.print(minute(t));
   strDT.print(":");
   if (second(t) < 10)
      strDT.print("0");
   strDT.print(second(t));
   strDT.print("Z");
   return chrDT;
The problem :
Very frequently I get crappy output in the date/time string part, like this :
<s id="5" vChMSRo="0" vChMS="8462268" vChDT="2011-09-15 !Ó" val="243" />
<s id="6" vChMSRo="0" vChMS="8433906" vChDT="2011-09!ÓS" val="507" />
It seems that sometimes a kind of buffer overflow occurs. Initially, I used the String object, but that made it even worse! (PString is a buffer overflow save string object).
Could you please check what could be the reason for this strange output?
Kind regards,
Bart.
mem
Cheers, Willem.
Here is an NTP code for Arduino 1.0:
* Time_NTP sketch
* Example showing time sync to NTP time source
* This sketch uses the Time library
* and the Arduino 1.0 Ethernet library
#include <Time.h>
#include <SPI.h>         // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUDP.h>
byte ip[] = { 192, 168, 1, 44 }; // set this to a valid IP address (or use DHCP)
unsigned int localPort = 8888;      // local port to listen for UDP packets
IPAddress timeServer(192, 43, 244, 18); // time.nist.gov NTP server
const int NTP_PACKET_SIZE= 48; // NTP time stamp is in first 48 bytes of message
byte packetBuffer[ NTP_PACKET_SIZE]; // buffer to hold incoming/outgoing packets
time_t prevDisplay = 0;    // when the digital clock was displayed
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
  Ethernet.begin(mac,ip);
  Udp.begin(localPort);
  Serial.println("waiting for sync");
  setSyncProvider(getNtpTime);
  while(timeStatus()== timeNotSet)
     ; // wait until the time is set by the sync provider
  if( now() != prevDisplay)   //update the display only if the time has changed
    prevDisplay = now();
    digitalClockDisplay();
void digitalClockDisplay(){
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(dayStr(weekday()));
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(monthShortStr(month()));
  Serial.print(" ");
  Serial.print(year());
  Serial.println();
void printDigits(int digits){
  // utility function for digital clock display: prints preceding
  // colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
/*-------- NTP code ----------*/
unsigned long getNtpTime()
  sendNTPpacket(timeServer); // send an NTP packet to a time server
  if ( Udp.parsePacket() ) {
     Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read packet into buffer
     //the timestamp starts at byte 40, convert four bytes into a long integer
     unsigned long hi = word(packetBuffer[40], packetBuffer[41]);
     unsigned long low = word(packetBuffer[42], packetBuffer[43]);
     // this is NTP time (seconds since Jan 1 1900
     unsigned long secsSince1900 = hi << 16 | low;
     // Unix time starts on Jan 1 1970
     const unsigned long seventyYears = 2208988800UL;
     unsigned long epoch = secsSince1900 - seventyYears;  // subtract 70 years
     return epoch;
  return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(IPAddress address)
  memset(packetBuffer, 0, NTP_PACKET_SIZE);  // set all bytes in the buffer to 0
  // Initialize values needed to form NTP request
  packetBuffer[0] = B11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum
  packetBuffer[2] = 6;     // Max Interval between messages in seconds
  packetBuffer[3] = 0xEC;  // Clock Precision
  // bytes 4 - 11 are for Root Delay and Dispersion and were set to 0 by memset
  packetBuffer[12]  = 49;  // four-byte reference ID identifying
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  // send the packet requesting a timestamp:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  Udp.write(packetBuffer,NTP_PACKET_SIZE);
  Udp.endPacket();
mem
Hi all,
The problem :
Kind regards,
Bart.
Bart,
You can check if the problem is due to the chrDT buffer overflowing by testing with a hard coded string of the correct length for the date.
If you still have the problem this is probably not a Time library issue and if that is the case then best to move the discussion to a new thread.
viknet
hello there :-)
back from testing my code concerning a web enabled programmer you can try it here :
http://sprinkler.zapto.org/arduinoJqueryUI.html
user/password    viknet/viknet
mem,  there (as always I think) is two bug I had to correct in your library:
in the function updateNextTrigger,
I removed the check if next trigger is not yet in the future:
if the check is already in the future but you just changed the alarm to something else, the updatetrigger won't be effective immediately
I also change the write function to :
if(isAllocated(ID))
        Alarm[ID].value = value;
        Alarm[ID].Mode.alarmType=period;
        if (value!=dtINVALID_TIME)
          enable(ID);
          free(ID);
because trying to set the alarm to 0 was leaving alarm in a strange state before.
all in all I am more and more convinced that 0 should be treated as a valid alarm value meaning 0:00:00 today, the main reason for that when setting an alarm to 24:00:00 (which currently work) if you read the value and apply the usual hour() minute() second() it reply 00:00:00 which is kind of wrong.
To avoid this I disabled the possibility to set an alarm at midnight : 00:00:00 and 24:00:00 are not valid time in my project :-)
Redcap
Mem/Michael,
I wasn't 100% sure how to set the time, so much thanks for the code snippet/s :)
- Red
joe73
Hello
My name is Joe
I have made clock from this page  "http://www.vonnieda.org/tc18"  but it doesn't have alarm,so I would like to add it.
This is first time for me to do something with arduino,can someone add alarm part for clock sketch for me please.
Im attaching sketch file
Thanks
ninja2
I need to convert UTC time (from my LS00031 GPS unit) to local time (i.e +10.5 hours). Sure I could code this but I expect this has been done many times before. A pointer to existing code or library call would be much appreciated. TIA
tmdrake
Okay, it apears the GPS synch isn't working.
Looked like part of the sample code is not finished?
time_t gpsTimeSync(){
  //  returns time if avail from gps, else returns 0
  unsigned long fix_age = 0 ;
  gps.get_datetime(NULL, NULL, &fix_age);
  unsigned long time_since_last_fix;
  if(fix_age < 1000)
    return gpsTimeToArduinoTime(); // return time only if updated recently by gps
  return 0;
Always returns False.
After commenting out a few lines...
  //unsigned long time_since_last_fix;
  //if(fix_age < 1000)
  //return 0;
Seems to work...took a while before I got a synch....?
ninja2
#44
Dec 05, 2011, 11:59 am Last Edit: Dec 05, 2011, 12:02 pm by ninja2 Reason: 1
This is covering the exact issue I'm dealing with. I commented out the same code around "fix_age" and had some success, but not as much as you ... have a look here: http://arduino.cc/forum/index.php/topic,81175.msg612786.html#msg612786
I figured "fix_age" wasn't working, so commented it out, but now I'm getting same time reported every time it starts (7:37:12 8 Jan 2000 from memory). I know the GPS is working as I've got another program that reads from it just fine, so I'm pretty sure the problem is in the way I'm using timeGPS, or with timeGPS itself.
I'd really like to nail this one ...!
PS: you say it took a while before you got synch ... can you estimate how long that was (a few secs, or mins or longer?)
