Topic: Suggest a Breadboard Arduino,Please! (Read 1 time) previous topic - next topic
NI$HANT
Jan 17, 2011, 08:38 pm Last Edit: Jan 17, 2011, 08:40 pm by Nishant_Sood Reason: 1
i want a Arduino schematic which could be loaded(Bootloader/Sketch) with the parallel port programmer that i have made.for that it should have a dedicated fully compatible [glow]ICSP[/glow] port in schematic compatible with following Parallel programmer's schematic:
http://arduino.cc/en/Hacking/ParallelProgrammer
Regards,
Nishant Sood
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Grumpy_Mike
They are all compatible with this. It is only four pins you need to connect to.
westfw
well, for example, the MDC "Really Bare Bones Board" (and variants thereof) does not include an ISP connector.  if you want to connect it to a programmer, you have to stick it in a breadboard and plug in wires to the appropriate pins (not that that is so difficult...)
NI$HANT
can i directly connect the pins on the atmega168 with that of the parallel programmer ICSP one
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
pwillard
Look at an arduino schematic for a clue.
ICSP programmers and the process is basically designed to connect directly to the AVR chip's pins.
