Loading...
Pages: [1]   Go Down
Author Topic: Lilypad + bluetooth + C# communication problem  (Read 751 times)
Offline Offline
Newbie
View Profile
I'm trying to make a communication between Arduino Lilypad and my pc through a Bluetooth connection.
To make it, I bought a Bluetooth Silver Mate from Sparkfun and connected it to the Lilypad. I made a program in C# using 32Feet.com library like this:
class Program
        /// <summary>
        /// The bluetooth component used to discover devices.
        /// </summary>
        private static BluetoothComponent component = new BluetoothComponent();
        /// <summary>
        /// The bluetooth client.
        /// </summary>
        private static BluetoothClient bluetoothClient = new BluetoothClient();
        /// <summary>
        /// The stream to communicate with the device.
        /// </summary>
        private static NetworkStream stream;
        /// <summary>
        /// The stream writer used to communicate with the device.
        /// </summary>
        private static StreamWriter streamWriter;
        /// <summary>
        /// the stream reader used to receive messages from the device.
        /// </summary>
        private static StreamReader streamReader;
        /// <summary>
        /// The serial port.
        /// </summary>
        private static SerialPort serialPort;
        static void Main(string[] args)
            try
                var com9 = from port in SerialPort.GetPortNames() where port == "COM9" select port;
                if (com9.Count() == 0)
                    Console.WriteLine("Discovering...");
                    var devices = bluetoothClient.DiscoverDevices();
                    Console.WriteLine("Discovery finished.");
                    devices[0].SetServiceState(BluetoothService.SerialPort, true);
                serialPort = new SerialPort("COM9", 9600);
                serialPort.ErrorReceived += new SerialErrorReceivedEventHandler(serialPort_ErrorReceived);
                serialPort.DataReceived += new SerialDataReceivedEventHandler(sp_DataReceived);
                serialPort.Open();
                serialPort.WriteLine("L");
                Thread.Sleep(1000);
                serialPort.WriteLine("H");
                Thread.Sleep(1000);
            finally
                serialPort.Close();
        private static void serialPort_ErrorReceived(object sender, SerialErrorReceivedEventArgs e)
            throw new NotImplementedException();
        private static void sp_DataReceived(object sender, SerialDataReceivedEventArgs args)
            byte[] data = new byte[1];
            serialPort.Read(data, 0, 1);
            Console.WriteLine(new string(ToCharArray(data)));
        private static char[] ToCharArray(byte[] array)
            char[] result = new char[array.Length];
            for (int i = 0; i < array.Length; i++)
                result = (char)array;
            return result;
and using the following firmware for the Lilypad. It receives a data from bluetooth device and controls a led depending on the received value. If it is H the led is turned on, if L the led is turned off else the led starts blinking. The received value is also sent back to the sender.
int val;                       // variable to recv data from the serial port
int ledpin = 5;                 // LED connected to pin 5
int initialized = 0;
int H = 72;
int L = 76;
int debugEnabled = 1;
  pinMode(ledpin, OUTPUT);
  Serial.begin(9600);           // start serial communication at 9600bps
void Blink(int value)
  int i;
  delay(3000);
  if(value == 0)
    delay(5000);
  for(i = 0; i < value; i++)
    digitalWrite(ledpin, 1);
    digitalWrite(ledpin, 0);
  delay(3000);
  if(initialized == 0)
    val = H;
    initialized = 1;
  if( Serial.available() )     // if data is available to read
    val = Serial.read();       // read it and store it in 'val'
  if(val == H)              // if 'H' was received
    digitalWrite(ledpin, 1); // turn ON the LED
  else if(val == L)
    digitalWrite(ledpin, 0);  // otherwise turn it OFF
    if(debugEnabled)
        Blink(val);
  Serial.println(val);
  if(val != L && val != H)
    val = H; // Resetting...
  delay(100);                   // wait 100ms for next reading
Initially the C# program seems to  work: the connection to the Bluetooth Silver Mate is done correctly and data is received from the Lilypad but the received data are always 254 or 255, not depending if I send 'L' or 'H'. The same 'L' value is received from the device like 254 or 255. Furthermore no "acknowledgement" data is received from my pc.
I also connected a LCD display to display the received value and the behavior is confirmed.
I also tried to make a Java client using BlueCove library but it seems it's the same thing.
Can anyone help me to understand the problem?
Thank you in advance.
Matteo
Logged
Louisville, KY
Offline Offline
Newbie
Arduino rocks
View Profile
Sounds to me like a wrong baud rate or parity error.  Can you check that all your baud settings are similar for the bluetooth and arduino?
Logged
Offline Offline
Newbie
View Profile
Hi Jeremyvnc,
thank you for your answer.
I set the baud rate on the Arduino firmware to 9600 (coherently to the C# program), is it enough? How can I check the baud rate on the Bluetooth device?
Matteo
Logged
Offline Offline
Newbie
View Profile
Thank you Jeremyvnc!
I solved my problem. By default, the baud rate on the Bluetooth Silver Mate is 115200 (not working on Lilypad).
So, I tried to change the baud rate on Bluetooth Silver Mate (http://electronics.stackexchange.com/questions/15027/how-do-i-change-baud-rate-for-bluesmirf-without-connecting-to-pc, this is for BlueSmirf but works perfectly on Bluetooth Silver Mate too) to 9600 and all works correctly.
I also tried to set the baud rate to 115200 using an Arduino Uno instead of a Lilypad with the Silver Mate connected and it all works (updating C# program and firmware).
Thank you very much!
Matteo
Logged
Pages: [1]   Go Up
Print
Jump to:
