Loading...
Pages: [1]   Go Down
Author Topic: [solved] Help reading data sheet  (Read 301 times)
Offline Offline
God Member
a, b = b, a+b
View Profile
WWW
Hi everyone
I need some help figureing out this data-sheet:
http://www.fairchildsemi.com/ds/QR/QRE1113.GR.pdf
The component I am interested in is a sensor generally used for line-tracking. It has an IR led and a photodiode. The photodiode measures the amount of reflected IR light, giving information on reflectence / or distance of objects.
I want to build a small array of them, similar to this sensor-array by pololu http://www.pololu.com/catalog/product/960/pictures
I cannot figure out the voltage and current consumption of the LEDs. I have no experience with reading datasheets, I am sure its in there somewhere, but I just cant figure it out.
If someone could take a look at it for me and tell me what the current & voltage rating of the LED in the sensor is, that would be really helpfull. (I would also apreceate if someone told me *how* to find this information.
The closest I can find to current & voltage are from the absolute Maximum Ratings:
Continuous Forward Current - 50mA
Reverse Voltage - 5V
however, I am quite sure that these are not the values I am interested in.
I would really apreceate some help
Thanks
p.
edit: here are two schematics of breakout boards for this sensor. I guess it might be possible to reverse engeneer the information I am interested in from them:
http://www.sparkfun.com/datasheets/Robotics/QRE1113-Analog-Breakout-v11.pdf
http://www.pololu.com/picture/view/0J614
However, the sparkfun breakoutboard tends to get fairly warm - maybe its becouse of something else which is dodgy in my prototype - but still, I would rather figure out the actual specs, before reverse engeneering something...
« Last Edit: July 09, 2011, 04:50:29 pm by fkeel » Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Page 3, "Input diode" Vf 1.2 to 1.6V at 20mA.
Suggest you take 1.4V.
« Last Edit: July 09, 2011, 04:20:43 pm by AWOL » Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Leighton Buzzard, UK
Offline Offline
Edison Member
View Profile
the analog breakout schematic has a 10k resistor for each diode
so that's 0.5mA each (ignoring voltage drop across the device)
the array however has 47k for the receiver - so that's 0.1mA (ignoring voltage drop across the device)
the transmitter array - I'm not surprised it gets warm!
that's 8 * 33 ohm resistors in parallel = 4 ohms
current is going to be up round an amp or so!!!
I'd go with 20mA for each, as that's where the data sheet shows "typical" values
Logged
there are only 10 types of people
them that understands binary
and them that doesn't
Offline Offline
God Member
a, b = b, a+b
View Profile
WWW
Thanks guys. I thought that "input diode" referred to the light sensing element.
Anyway, thanks, this gets me a step forward... I am way out of my waters :-) ... I might be back with more questions.
p.
Logged
Pages: [1]   Go Up
Print
Jump to:
