#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <TextFinder.h>
#include <SoftwareSerial.h>
#include <EthernetDNS.h>
#include <Twitter.h>
#include <NewSoftSerial.h>
#include "SparkSoftLCD.h"
// LCD transmit pin
#define LCD_TX 3
SparkSoftLCD lcd = SparkSoftLCD(LCD_TX);
NewSoftSerial Thermal(4, 5); //Soft RX from printer on D2, soft TX out to printer on D3
#define FALSE 0
#define TRUE 1
int printOnBlack = FALSE;
int printUpSideDown = FALSE;
int ledPin = 13;
int heatTime = 255; //80 is default from page 23 of datasheet. Controls speed of printing and darkness
int heatInterval = 255; //2 is default from page 23 of datasheet. Controls speed of printing and darkness
char printDensity = 15; //Not sure what the defaut is. Testing shows the max helps darken text. From page 23.
char printBreakTime = 15; //Not sure what the defaut is. Testing shows the max helps darken text. From page 23.
//Setup of pins as digital outputs (in this case with LED's attached to them, but intention is to use them to control things with)
#define LED3Pin 6
#define LED4Pin 7
#define DelayFlashPin 9 //this pin flashes while arduino is waiting 1 minute before looking for next tweet
//byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };//default ethernet shield MAC
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x20, 0x3B };//my particular ethernet shield MAC (this number is WRITTEN on a label on the Ethernet Shield)
//byte server[] = {128,242,240,20}; // Twitter...I found this did NOT work so googled to find current Twitter server IP
byte server[] = {199,59,148,10}; // Twitter server IP address (checked 29/3/11)
char myStringBuffer[80];
char tweet[140];
char tweetp[140];
char tweetpo[140];
const String tweold;
String twenew;
Client client(server, 80);
TextFinder finder( client );
char line1[] = " 01234567890ABCDE";
#define line1Length (sizeof(line1)-2)
int x = 15; // for scroll
int y = 0; // for scroll
//SETUP SOFTWARE SERIAL FOR LCD DISPLAY
#define rxlcdprintPin 2 //sets new software rx as pin2, from LCD serial-LCD display usnit
#define txlcdprintPin 8 //sets new software tx pin as pin 3 to LCD serial-LCD display usnit
SoftwareSerial lcdSerial = SoftwareSerial (rxlcdprintPin, txlcdprintPin); //define lcdSerial as rxlcdprintPin (2) and txlcdprintPin (3)
//END OF SOFTWARE SERIAL LCD DISPLAY SETUP
pinMode(ledPin, OUTPUT);
pinMode(LCD_TX, OUTPUT);
lcd.begin(9600);
lcd.clear();
Serial.begin(9600); //Use hardware serial for debugging
Thermal.begin(19200); //Setup soft serial for ThermalPrinter control
//Modify the print speed and heat
Thermal.print(27, BYTE);
Thermal.print(55, BYTE);
Thermal.print(7, BYTE); //Default 64 dots = 8*('7'+1)
Thermal.print(heatTime, BYTE); //Default 80 or 800us
Thermal.print(heatInterval, BYTE); //Default 2 or 20us
//Modify the print density and timeout
Thermal.print(18, BYTE);
Thermal.print(35, BYTE);
int printSetting = (printDensity<<4) | printBreakTime;
Thermal.print(printSetting, BYTE); //Combination of printDensity and printBreakTime
Serial.println("Parameters set");
delay(100);
//FOR LCD DISPLAY
pinMode (rxlcdprintPin, INPUT);
pinMode (txlcdprintPin, OUTPUT);
lcdSerial.begin(9600);// LCD serial out
//end of LCD setup
//For digital output pins (with LEDS on them, pins 4 5 6 7, also 13 which flashes as the one minute counter counts down)
pinMode(LED3Pin,OUTPUT);
pinMode(LED4Pin,OUTPUT);
pinMode(DelayFlashPin,OUTPUT);
Serial.println("Twitter2LCD");
delay(50);
//XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
lcdSerial.print(19, BYTE); //backlight on
delay(50);
lcdSerial.print(12, BYTE); //clears screen
delay(50);
lcdSerial.print("Twitter to LCD"); //lcd text
lcdSerial.print(13, BYTE); //newline
lcdSerial.print("and 4 control LED's"); //lcd text
delay(50);
lcdSerial.print("J.Dingley V1.1"); //lcd text
//lcdSerial.print(13, BYTE); //newline
EthernetDHCP.begin(mac);
//lcd.clear();
if (client.connect()) {
//XXXXXXXXXXXXXXX CHANGE THE 9 DIGITS IN STATEMENT BELOW TO THOSE OF YOUR OWN TWITTER RSS feed xxxxxxxxxxxxxxxxxxxxxxx
//XXXXXXXXXXXXXXX My instructable tells you how to get your twitter RSS feed number XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
client.println("GET http://www.twitter.com/statuses/user_timeline/20557892.rss HTTP/1.0"); // twitter rss for jddat2
client.println();
else {
Serial.println("Connection failed");
delay(200);
//XXXXXXXXXXX Display XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
delay(50);
lcdSerial.print("Connection"); //lcd text
lcdSerial.print("FAILED"); //lcd text
//XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
if (client.connected()) {
// get the last tweet by simply parsing the item and title tags
if((finder.find("<item>")&&(finder.getString("<title>wootoff: ","</title>",tweet,33)!=0)))
Serial.println(tweet);
delay(100);
//XXXXXXXXXXXX Display XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
delay(200);
lcd.print("tweet coming"); //lcd tweet text
else {
Serial.println("Could not find item field");
delay(100);
//XXXXXXXXXXXXX Display XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
delay(50);
lcdSerial.print("Could not find"); //lcd text
lcdSerial.print("item field"); //lcd text
//XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
else {
Serial.println("Disconnected");
delay(100);
delay(50);
lcdSerial.print("Disconnected"); //lcd text
client.stop();
//client.flush();
//XXXXXXXXXXXXXXXXput text tweet onto LCD XXXXXXXXXXXXXXXXXXXXXXXXX
lcd.clear(); //clears screen
Serial.println("TEXT TWEET COMING");
lcd.print("TEXT TWEET COMING"); //lcd tweet text
delay(2000);
lcd.clear();
delay(200);
Serial.print(tweet); //Serial viewer
lcd.print(tweet);
client.println("GET http://www.twitter.com/favorites/698823.rss HTTP/1.0"); // twitter rss for wootchatter 216522378
client.println();
if((finder.find("<item>")&&(finder.getString("<title>","</title>",tweetp,140)!=0)))
String twenew(tweetp);
Serial.println("tweetp");
Serial.println(tweetp);
Serial.println("twenew");
Serial.println(twenew);
Serial.println("tweold");
Serial.println(tweold);
if (twenew != tweold){
Serial.println("Favorite coming");
delay(100);
Thermal.print(tweetp);
delay(800);
Thermal.print(10, BYTE);
String tweold = twenew;
Serial.println("old");
else{
delay(6000); // delay 0.7 second
