Pages: [1] 2   Go Down
Author Topic: Bootloader Uploading using Parallel or UNO?  (Read 1111 times)
ਪੰਜਾਬ
WANTED! A Girl with LOVE for me and Arduino!
I have an Arduino UNO and also prepared a Parallel programmer from the http://arduino.cc/en/Hacking/ParallelProgrammer place and bought 2 ATmega 168 available here, so wanted to put a Bootloader into it so that after the Bootloader is in i could put the 168 in the space for 328 on UNO and put sketches into it,will it happen? ,Any guidlines would be much appreciated!
also is it possible to directly connect pins( absolutely nothing in between) with the atmega168 of the parallel programmer to put bootloader or sketches into it?
« Last Edit: January 16, 2011, 02:39:31 am by Nishant_Sood » Logged
"Real Men can Accomplish  Anything"
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
Dallas
Shannon Member
This might be a bit less work...
http://arduino.cc/en/Tutorial/ArduinoToBreadboard
http://arduino.cc/en/Tutorial/ArduinoISP
ਪੰਜਾਬ
But these are not for UNO ,in these tutorials they say UNO is not able.
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
Dallas
Shannon Member
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1289761852/5#5
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1267120897/16#16
ਪੰਜਾਬ
getting offline to try (into windows ,i use linux for internet as no antivirus overhead is there) will revert back in some time.
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
ਪੰਜਾਬ
ArduinoISP software sketch loaded successfully seems no problem as showed "Done-Uploading"
« Last Edit: January 16, 2011, 04:38:17 am by Nishant_Sood » Logged
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
ਪੰਜਾਬ
Failed!,
used the instruction's @ http://arduino.cc/en/uploads/Tutorial/SimpleBreadboardAVR.png
 Got the Following Error's :
Error no.1 for the first time :
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Error no.2 after exiting the arduino IDE and unplugging and replugging Arduino into USB :
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
         Double check chip, or use -F to override this check.
Error 3 after again unplugging and replugging the Arduino from USB :
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
Using UNO i'm seeing such problem's,[glow]Any HELP![/glow]
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
Dallas
Shannon Member
Unfortunately, I don't have anything to suggest.  Hopefully, someone else can offer help.
...actually, there is one thing...
I think the auto-reset has to be disabled for the Arduino ISP to work correctly.  Have you determined that auto-reset needs to be disabled?  Have you disabled auto-reset?
« Last Edit: January 16, 2011, 06:19:20 pm by bcook » Logged
ਪੰਜਾਬ
No i haven't disabled the auto-reset!, The thread here shows that just insert a resistor 120ohm in the reset and 5volt pins and you have clogged auto reset but then how the 5v to the chip will be flowing should i give it external power then?.
« Last Edit: January 17, 2011, 04:48:04 am by Nishant_Sood » Logged
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
Dallas
Shannon Member
When RESET is high, the processor runs.  The resistor ensures the RESET line stays high when the reset circuitry fires.
No.
ਪੰਜਾਬ
Special thanks then, i mean't to say that the breadboard atmega would be needing power the UNO one would be ensured with power through resitor but the other atmega will need it !
« Last Edit: January 17, 2011, 02:10:13 pm by Nishant_Sood » Logged
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
Denver
Inactive - PM
If you have a TTL serial cable (~MAX232) you might try that and bypass the FTDI chip when loading. This works for me. Just connect Tx, Rx, Gnd, and VCC. You won't get a reset that way. It might be better than trying to cluge the reset pin.
It's a shame that this reset issue isn't mentioned in the Arduino ISP docs or sketch. It's essential that a reset shouldn't take place when loading a sketch using the Arduino ISP. /rant
« Last Edit: January 17, 2011, 02:10:21 pm by BroHogan » Logged
"Data is not information, information is not knowledge, knowledge is not understanding, understanding is not wisdom."
~ Clifford Stoll
ਪੰਜਾਬ
thank you !, I'll try it
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
ਪੰਜਾਬ
one thing more , I now will be inserting a 120 ohm resistor in the 5v and reset place  and POWERING the bread board Atmega168 with the external power source will it be OK?
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
Dallas
Shannon Member
Grounds must be connected.  I think the target (breadboard in you case) is supposed to be within 0.5 volts of the programmer (ArduinoISP in your case).
Pages: [1] 2   Go Up
