Topic: Extending CapSense Inputs (Read 1 time) previous topic - next topic
asuryan
Jul 09, 2011, 03:37 am Last Edit: Jul 09, 2011, 02:32 pm by asuryan Reason: 1
Hi!
Is there a way to extend the maximum number of capacitive sensors controlled by the
Capsense Library? Because one needs always 2 digital Pins which mades a maximum of
5 Sensors... but nothing else... :( Im thinking of something like the 74hc595 which enables
one to control a nearly infinit number of LEDs!
If it is possible using a certain chip do I have to write my own Capsense Lib when
changing the hardware?
As a base I would like to use the UNO!
Thanks in advance!! :)
Visit my blog! http://electronics.scriblab.de
tkbyd
You might find useful stuff in....
http://sheepdogguides.com/arduino/art3capsen.htm
In particular, look at the circuit diagram near the bottom... for, say, 4 cap-sense inputs, you only need 5 digital lines. Maybe I mis-understood your post, but if you thihnk you need two lines per input, no, not so.
I hope that's good news?
asuryan
Thanks for your answer!
1. Does that mean that I only need one signal pin and add lets say 8 reciever pins?
2. It would be even more cool, when using only 3 pins and read as many
capacitive sensors as I like! Eg. as I mentiond like the 74hc595 but for inputs. Is there
a chip for extendting inputs and is able to read capacitive sensors?
tkbyd
Quote
1. Does that mean that I only need one signal pin and add lets say 8 reciever pins?...
With 9 pins dedicated, you could monitor 8 touchpads.
Quote
capacitive sensors as I like...
Ummm... not sure how to do this!
You COULD probably multiplex the inputs somehow, but then you will have complex polling software to write. Buy a Mega, and have more inputs than you can use!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
