Author Topic: MCUs  (Read 434 times)
Connecticut
RTFD (Datasheet in our case)
I found these two inside an old keyboard.
80C49AP6-- Toshiba MCU
tc4515bp-- Hexadecimal converter
Before I desolder them, anyone know exactly how I could use them? Could I use the first one like an arduino, or is it closed source?
Thanks
I'm not kidding. If I am asking a question whose answer is found within the concerned product's datasheet, shame on me. If I am answering a similar question, shame on you!
Austin, TX
CMiYC
Depends on what you mean "like an Arduino."  It is a microprocessor.  If you can find a suitable development environment, then you can use it.
www.cmiyc.com - A guide to being an Enginerd
Connecticut
Is there one?
Left Coast, CA (USA)
Measurement changes behavior
80C49AP6
Most likely a rom based programmed microcontroller that can't be erased and reused.
Lefty
Connecticut
Oh well. Thanks anyway (and thanks for the MOSFET help, too.)
what?
Most of the time yes, OTP is cheap, but if you have a OTP chip with 2k of memory for example and the pre burnt code is only 1k then you still have 1k to play with, i have reused suposed OTP PIC12c508's by setting the ORG (code start address) to the next available address after the pre urnt code and it works
Boston area, metrowest
Did you find a datasheet for the 2nd part?
http://www.datasheetarchive.com/pdf/getfile.php?dir=Datasheets-39&file=DSA-761486.pdf&scan=
Latched 1 of 16 selecter - you give it 4 address bits, it will create a low on 1 of 16 outputs, and can latch it with another control line. Nice part. Cannot sink or source much current, so is really limited to connecting to other logic devices.
ਪੰਜਾਬ
WANTED! A Girl with LOVE for me and Arduino!
You have to get the IDE which can support the MCU you are using like we have avrdude for that of the AVR MCU's and then have a good programmer to load Software to it and set various bits and as such any chip can be reprogrammed but Firslty,Look for the Lock bits as if they are fused to make the chip Nonprogrammable then you can't reprogram it.
"Real Men can Accomplish  Anything"
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
