Hi
I am trying to use the DS3234 breakout board from sparkfun along with a sd card breakout board
The problem is that I can set the RTC by itself with the code provided by sparkfun and tronixstuff's tutorial and it works fine...
when I add code to log the time (part from the ladyadas' tutorial) to the sd the time I get to serial monitor is wrong (THE OUTPUT AT THE SERIAL MONITOR
Initializing SD card...card initialized.
Logging to: LOGGR021.CSV
0/12/40--4:0:21
0/12/120--4:0:22
0/12/120--4:0:23
0/12/120--4:0:24
0/12/120--4:0:28
If I download the ds3234 code again without setting the clock the time is correct...
I have set the chip select pins at the code the same as I did on breadboard and also set pin 10 as output....
Can you please propose a solution?
best regards
Gjango
#include <SPI.h>
#include <SD.h>
File logfile; // the logging file
const int cs=7; //chip select
const int chipSelect = 9; // chip select for SD
// ********************************** SAMPLING ********************************************
#define LOG_INTERVAL 2000 // mills between entries (reduce to take more/faster data)
#define SYNC_INTERVAL 2000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
// **************************** ECHO_TO_SERIAL ********************************************
#define ECHO_TO_SERIAL 1 // echo data to serial port
// ********************************** SETUP *************************************************
RTC_init();
pinMode(7, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
// initialize the SD card
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to output, even if you don't use it:
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
error("Card failed, or not present");
Serial.println("card initialized.");
// ***************** MAKE FILENAME WITH THREE DIGITS ****************************
char filename[] = "LOGGR000.CSV";
for (uint8_t i = 0; i < 1000; i++) {
uint8_t j=i/10;
filename[5] = j/10 + '0';
filename[6] = j%10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
error("couldnt create file");
Serial.print("Logging to: ");
Serial.println(filename);
// USE THE FOLLOWING LINE OF CODE TO SET TIME...UPLOAD...THEN COMMENT...UPLOAD AGAIN
// //day(1-31), month(1-12), year(0-99), hour(0-23), minute(0-59), second(0-59)
//SetTimeDate(9,7,11,9,26,16);
logfile.println(ReadTimeDate());
Serial.println(ReadTimeDate());
delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
if ((millis() - syncTime) < SYNC_INTERVAL) return;
syncTime = millis();
logfile.flush();
int RTC_init(){
pinMode(cs,OUTPUT); // chip select
// start the SPI library:
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE1); // both mode 1 & 3 should work
//set control register
digitalWrite(cs, LOW);
SPI.transfer(0x8E);
SPI.transfer(0x60); //60= disable Osciallator and Battery SQ wave @1hz, temp compensation, Alarms disabled
digitalWrite(cs, HIGH);
delay(10);
int SetTimeDate(int d, int mo, int y, int h, int mi, int s){
int TimeDate [7]={s,mi,h,0,d,mo,y};
for(int i=0; i<=6;i++){
if(i==3)
i++;
int b= TimeDate[i]/10;
int a= TimeDate[i]-b*10;
if(i==2){
if (b==2)
b=B00000010;
else if (b==1)
b=B00000001;
TimeDate[i]= a+(b<<4);
SPI.transfer(i+0x80);
SPI.transfer(TimeDate[i]);
String ReadTimeDate(){
String temp;
int TimeDate [7]; //second,minute,hour,null,day,month,year
if(i==3)
i++;
SPI.transfer(i+0x00);
unsigned int n = SPI.transfer(0x00);
int a=n & B00001111;
if(i==2){
int b=(n & B00110000)>>4; //24 hour mode
if(b==B00000010)
b=20;
else if(b==B00000001)
b=10;
TimeDate[i]=a+b;
else if(i==4){
TimeDate[i]=a+b*10;
else if(i==5){
int b=(n & B00010000)>>4;
TimeDate[i]=a+b*10;
else if(i==6){
int b=(n & B11110000)>>4;
TimeDate[i]=a+b*10;
else{
int b=(n & B01110000)>>4;
TimeDate[i]=a+b*10;
temp.concat(TimeDate[4]);
temp.concat("/") ;
temp.concat(TimeDate[5]);
temp.concat("/") ;
temp.concat(TimeDate[6]);
temp.concat("--") ;
temp.concat(TimeDate[2]);
temp.concat(":") ;
temp.concat(TimeDate[1]);
temp.concat(":") ;
temp.concat(TimeDate[0]);
return(temp);
void error(char *str)
Serial.print("error: ");
Serial.println(str);
while(1);
