Loading...
Pages: [1]   Go Down
Author Topic: Microphone question...  (Read 725 times)
Offline Offline
Newbie
View Profile
Hello all,
I am looking into buying a arduino and I would like to buy a microphone that can plug in to the board. I have looked into some mics and from reviews that I have found online they have not worked very well with the arduino. I would like to build a clapper light switch with the mic and the arduino.
Any suggestions on microphones that I could buy?
Thank you.
Logged
London
Offline Offline
Faraday Member
Have fun!
View Profile
The signal from a typical microphone is too weak to be read by Arduino, you need an amplifier to increase the output.
You can use something like this
edit: fixed the url
« Last Edit: July 11, 2011, 11:02:26 pm by mem » Logged
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
SparkFun has a board:
http://www.sparkfun.com/products/9964
(edited)
Stereo option:
http://www.vellemanusa.com/us/enu/product/view/?id=351278
« Last Edit: July 11, 2011, 11:08:33 pm by Magician » Logged
London
Offline Offline
Faraday Member
Have fun!
View Profile
Hi Magician, that was the item linked in the earlier post,  the url was broken and is now fixed.
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
@cmac678, you are in the US?
I suggest something like a condensor microphone from radioshack.
Power it from 9V battery, connect its ground to arduino ground, and its output to arduino ADC thru an electrolytic capacitor.
Here's one wired up in a box from ages ago, I put a new battery & battery clip on it, thing still picked up nicely with a guitar amplifier!
The output of the capacitor will be at 0V and swing positive & negative - connect two 100K resisters like this: +5V to resister, other side to 2nd resister+capacitor+Arduino input, other side of 2nd resister to gnd. The Arduino input should sit ~2.5v with no mic input.
You'll have to play with the ADC outputs, see if you can get a decent enough readings away fom 2.5V (reading of ~512) to make a decision on.   If not, may have to add some gain using a single supply op-amp and  a couple of resisters.
You'll have to play with the ADC outputs, see if you can get a decent enough level to make a decision on. May have to add some gain using a single supply op-amp and  a couple of resisters.
http://masteringelectronicsdesign.com/how-to-derive-the-summing-amplifier-transfer-function/
Use a circuit like this instead - the capacitor output will be V1 and V2 will be the junction of the 100K resisters. Or a trimpot! Then you can dial in the voltage needed to keep the output at 2.5V while adjusting the gain needed to adust mic sensitivity.
I'll see if I can find you an envelope follower circuit as well, that might come in handy if your ADC sampling loop doesn't run fast enough to see the hand clap with this mic.
Gotta get to bed tho, darn day job ...
« Last Edit: July 11, 2011, 11:59:23 pm by CrossRoads » Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Online Online
Brattain Member
View Profile
WWW
http://en.wikipedia.org/wiki/Envelope_detector
Heck, this will work - put this simple circuit after the op-amp.
Logged
Offline Offline
Newbie
View Profile
Thanks for all the repilies
@crossroads I dont have radioshack where I live, would this work?http://store.curiousinventor.com/electret-condensor-microphone.html
When I build this (http://en.m.wikipedia.org/wiki/File:C_Simple_envelope_detector.gif) where do I attach the to ends to (the mic and the arduino?)
Logged
Offline Offline
Newbie
View Profile
Do I still need to amplify the microphone if I get this board?  http://www.sparkfun.com/products/9964
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Two answers:  The curious inventor mic would work.
The left side, Vi(t) is driven by the output of the op amp circuit.
The right side, Vo(t) goes to an arduino Analog pin, and to ground.
Sparkfun: No, you don't need a seperate amplifier - if you look at the schematic, you will an amplifier design almost identical to what I linked to earlier.
Logged
Montreal
Offline Offline
Edison Member
View Profile
WWW
No, it has mic + amplifier, and it outputs DC bias signal.
As for envelope detector, you also don't have to solder it with external components,
you can do all audio processing in software: rectification, integration, filtering etc.
Logged
SF Bay Area
Offline Offline
Full Member
Arduino rocks
View Profile
Buy it from sparkfun, or somewhere else you can find it.
I just ordered mine from radioshack but I later found it much cheaper on sparkfun. It cost me a little over $12 with shipping for 2. At least with sparkfun, I would have probably ordered some other parts at the same time.
electret mic
http://www.sparkfun.com/products/8635
mems mic
http://www.sparkfun.com/products/10028
http://www.sparkfun.com/products/9868
Logged
Pages: [1]   Go Up
Print
Jump to:
