Ballston Spa, NY
Offline
Jr. Member
« Reply #15 on: July 12, 2011, 09:48:11 am » |
True, maybe an LED that will light for a unknown ID. Good idea! But as for making my own remote, I could, but i'd rather not.. I'd rather use a keyfob remote from: http://www.linxtechnologies.comAs for collisions, I'll just add the LED for a Unknown ID.
Logged
Global Moderator
Boston area, metrowest
Online
Brattain Member
Available for Design & Build services
« Reply #16 on: July 12, 2011, 09:50:37 am » |
Could always turn on an LED after the button press so they can see a message went out - make it flash or something distracting.
Logged
Global Moderator
Online
Brattain Member
« Reply #17 on: July 12, 2011, 09:53:01 am » |
Those keyfob remotes look good too. Wonder how much.
Logged
Chester, UK
Offline
Sr. Member
Trying to return the love to none logic level MOSFETS
« Reply #18 on: July 12, 2011, 09:53:12 am » |
Let me know on the pricing from Linx. If the can beat $22 each - I'll be giving them a call myself.
Logged
If your system involves lethal voltages/life critical/flamable elements - you probably shouldn't need to ask. The Arduino != PC.
Ballston Spa, NY
Offline
Jr. Member
« Reply #19 on: July 12, 2011, 09:54:34 am » |
I'll let u know once they open in like 10 minutes... I'll be calling them!
Logged
Ballston Spa, NY
Offline
Jr. Member
« Reply #20 on: July 12, 2011, 10:30:27 am » |
MS Keyfob Price: $17.95 Each First Price-break is at 200 Pcs.
Logged
Chester, UK
Offline
Sr. Member
« Reply #21 on: July 12, 2011, 10:58:35 am » |
How much for the receiver?
Logged
Ballston Spa, NY
Offline
Jr. Member
« Reply #22 on: July 12, 2011, 11:03:25 am » |
Not sure, i just sent a email asking... I'll let u know once i know.
Logged
UK - Scotland
Offline
Newbie
« Reply #23 on: July 12, 2011, 05:30:46 pm » |
I have a suggestion for the transmitters I had a similar problem when looking for a pre-made remote's for a Traffic light system I made for loading bays in work, I came across "AM Keeloq" Transmitter's and receivers.
The transmitters are 1-4 buttons, they are Encrypted (keloq) so they cant be copied easily but more importantly they have a unique serial number which the receiver can read via a serial output the transmitter is designed for 4 buttons it has momentary or latch operation, basically a garage door opener, however as I've said the transmitter's have a serial number so it should not be hard to associate a specific transmitter with a specific task in your program.
oh the receiver has built in memory and can store 50 unique remote's (although you wont need to memorise them as you will be using the serial output)
« Last Edit: July 12, 2011, 06:14:40 pm by zx81 »
Logged
Ballston Spa, NY
Offline
Jr. Member
« Reply #24 on: July 13, 2011, 10:06:26 am » |
The receiver costs $9.80 each. That's for the LR Module.
I'm not sure if i wanna go that route.. I don't need encryption, that would be overkill and more complicated for what i'm doing, and i don't have much knowledge in Wireless Technology to begin with.
Logged
UK - Scotland
Offline
Newbie
« Reply #25 on: July 14, 2011, 03:12:35 am » |
The encryption is totally automatic you don't need to do anything the only thing you will be interested in on the receiver is the serial output which gives the transmitters serial number and which button was pushed.
The reason I picked this set-up was because it was cheap £15 for the receiver and £14 for the 3 button remote, the remote's with less buttons were cheaper (£10 I think for a 1 button)
I had a quick look at the receiver's on the Linx website that was linked ..correct me if I'm wrong but if you use those receivers you set the channel by DIP switches or hard-wiring the channel in, so you would need a receiver for every remote ?
zx
Logged
Ballston Spa, NY
Offline
Jr. Member
« Reply #26 on: July 14, 2011, 09:02:59 am » |
No, the price I posted was for the MS Keyfob (which uses a unique serial number)... The regular Keyfob uses the dip switches.
Logged
