Connecticut
Offline
Edison Member
RTFD (Datasheet in our case)
« on: July 12, 2011, 09:51:10 am » |
Does anyone know how to remove the ATmega328 from the Arduino? If I try to lift it up with my fingers from the ends, it seems stuk in pretty well. How can I remove it from the DIP IC socket?
Thanks! baum
Logged
I'm not kidding. If I am asking a question whose answer is found within the concerned product's datasheet, shame on me. If I am answering a similar question, shame on you!
Connecticut
Offline
Edison Member
« Reply #2 on: July 12, 2011, 10:02:32 am » |
OK. I'll pick up an IC puller. And to get it back in, I can just pop it in?
Logged
Global Moderator
Boston area, metrowest
Offline
Brattain Member
Available for Design & Build services
« Reply #3 on: July 12, 2011, 10:14:47 am » |
Yes. May need to squeeze the pins a little. Be careful, make sure they are all started a little before pushing it all the way in. Especially new parts, the legs are like spring loaded, you need to lay the part on its side and bend them all in some, but starting close to the body, not just the thin bottom part of the legs.
Logged
Phoenix, Arizona USA
Offline
Faraday Member
Where's the beer?
« Reply #4 on: July 12, 2011, 01:51:16 pm » |
I want to add that this takes a little bit of practice - it is very easy to "screw up" and mangle the pins; you might want to practice on some "throwaway" DIP ICs first. Something else: DIP ICs and sockets are not made to be cycled in this manner (the pins will get weak and stop bending properly, or the contacts in the socket will lose their springiness; either way, loss of connection or intermittents can crop up, pins bent, etc); if this is something you intend to do often, you might want to look into using a 28-pin ZIF (zero-insertion force) socket instead of the regular DIP IC socket on the Arduino. Some of these sockets can fit right into the socket on the Arduino, some can't (some are too big and won't fit, or they have too short of "legs" to fit in the socket, or other issues). It is possible to build a shield or other adaptor to fit a ZIF socket onto a regular Arduino (you could even take it "off board" like CrossRoads - IIRC - did with his 644 "Arduino" hack - by using a 28-pin IDC connector on a ribbon cable to the off-board socket).
Logged
Connecticut
Offline
Edison Member
« Reply #5 on: July 12, 2011, 02:23:36 pm » |
Just checked out SFE's ZIF, in the comments people mentioned that it fit into the DIP socket on the board... so I'll get an IC puller from amazon and put in a zif socket.
Another question:
Let's assume I had an Uno SMD. How could I program standalone chips without messing up the SMD one on the board?
Thanks! baum
Logged
Global Moderator
Dallas
Offline
Shannon Member
« Reply #6 on: July 12, 2011, 02:33:16 pm » |
How could I program standalone chips without messing up the SMD one on the board? This is one way (search for "Circuit (targeting an AVR on a breadboard)")... http://arduino.cc/en/Tutorial/ArduinoISP
Logged
Connecticut
Offline
Edison Member
« Reply #7 on: July 12, 2011, 02:34:57 pm » |
But assume I already burned the bootloader. Can I write programs to the standalone ATmega without removing the main one?
Logged
Offline
Faraday Member
Where's the beer?
« Reply #8 on: July 12, 2011, 02:42:17 pm » |
Another question:
Thanks! baum
Basically - in answer to both questions, you should bring out the ISP/ICSP pins to a standard 5/6 pin header (on your standalone), and use an ISP AVR programmer (which you can turn an Arduino into via a sketch in the examples, btw) to program the 328. This is basically how you install the bootloader onto the Arduino. In fact, by using an external programmer, you will gain 2K of flash space for your program (although, IIRC on the UNO, it has an optimized bootloader that fits inside 512 bytes - so you would only gain that much extra space on the UNO). The only reason the Arduino isn't this way to begin with is because the bootloader makes it easier for beginners to get started (and at the time, you needed to use a "real" AVR ISP programmer - which costs extra). In fact - you might want to just build a standalone ZIF socketed "Arduino" on a "stripboard", bring out the ISP/ICSP pins to a header, then use your Arduino as the programmer as referenced above. That would probably be the simplest solution...
Logged
Connecticut
Offline
Edison Member
« Reply #9 on: July 12, 2011, 02:50:18 pm » |
OK. I'll do that. It will be easiest, as I need to write some code to a tiny2313, also.
Thanks! baum
Logged
Washington
Offline
God Member
Firefox & Arduino rocks
« Reply #10 on: July 12, 2011, 08:22:19 pm » |
Pry it VERY gently with a screwdriver on each side. Do it slowly.
Logged
Avoid throwing electronics out as you or someone else might need them for parts or use. Solid state rectifiers are the only REAL rectifiers. Resistors for LEDS!
Connecticut
Offline
Edison Member
« Reply #11 on: July 12, 2011, 08:23:29 pm » |
When I do that, I hear tiny bits scratching off the casing... No, thank you.
Logged
Washington
Offline
God Member
« Reply #12 on: July 12, 2011, 08:26:02 pm » |
Yeah it tends to scratch it a bit  But just don't put in as tight next time.
Logged
Connecticut
Offline
Edison Member
« Reply #13 on: July 12, 2011, 08:30:03 pm » |
put in as tight next time. Tell that to the Italians who assembled the board. I haven't removed it yet.  Do you think an IC puller is worth it? I can get one for ~$5 from amazon.
Logged
Grand Blanc, MI, USA
Offline
Faraday Member
"We're a proud service of the Lost Electricity Reclamation Agency"
« Reply #14 on: July 12, 2011, 10:05:52 pm » |
put in as tight next time. Do you think an IC puller is worth it? I can get one for ~$5 from amazon. Those inexpensive ones don't look to me like they'd be an improvement over prying with a very small screwdriver. I use a screwdriver that's not quite as small as one that might be used on eyeglasses; the blade is very thin. Not a real fast process, but I've never had a problem or damaged a chip. But I'd like to hear from someone who has used one of those inexpensive extractors. I suppose for $5 or so a person couldn't go too far wrong.
Logged
