Topic: please help with code (Read 2210 times) previous topic - next topic
AWOL
I really don't know - I simply made it up!
just try different values - theones in the original post were written in binary, mine were written in hex, which is easier for me to read.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
liuzengqiang
OK, my guess was correct you don't know how the program works or how to write a program for an arduino. If you know a bit of music, I hope you understand the analogy below:
Each line is like a line of notes now you have four such lines. To play a longer sequence, mimic what is already there, add more lines and experiment with it. The setup and loop are the "piano" that plays the notes so don't pick it apart. You're not a piano repairman. As a composer, you work on the sequence only.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
