Loading...
Pages: [1]   Go Down
Author Topic: Arduino Uno Power  (Read 1214 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
How much power would an Arduino Uno board draw if its clock cycles were being maxed out (and it had no external peripherals attached to it)?
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
The 328 datasheet would be the best source for that kind of information. http://www.atmel.com/dyn/resources/prod_documents/doc8161.pdf
In the electrical section they show this data:
Quote
Parameter Condition Min. Typ.(2) Max. Units
ICC
Power Supply Current(1)
Active 1 MHz, VCC = 2V 0.2 0.5 mA
Active 4 MHz, VCC = 3V 1.2 2.5 mA
Active 8 MHz, VCC = 5V 4.1 9 mA
Idle 1 MHz, VCC = 2V 0.03 0.15 mA
Idle 4 MHz, VCC = 3V 0.18 0.7 mA
Idle 8 MHz, VCC = 5V 0.8 2.7 mA
Not sure how one would extrapolate that out to 20Mhz @ 5v, but you can certainly see the trend.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
This is meaningles in the context of a micro controller, it is always running flat out.
Logged
Austin, TX
Online Online
Faraday Member
CMiYC
View Profile
WWW
The current of the micro-controller is only part of it.  Arduino is a system.  So you have to account for the 8u2, power LED, and regulators.
Which if there are no inputs or outputs connected, would be a steady state current.
« Last Edit: January 20, 2011, 03:31:47 pm by cmiyc » Logged
www.cmiyc.com - A guide to being an Enginerd
Pages: [1]   Go Up
Print
Jump to:
