0
Offline
Newbie
Arduino rocks
« Reply #15 on: January 19, 2011, 01:08:05 pm » |
ok, I'll tell you my goal and then maybe you can help best direct me. My goal is to create some sort of electronic that will find the distance between two objects and calculate a degree for a physics project.
For example, lets say I could see a target within 20meters (or so). I want my project to find the distance from where it is and where the target is and then calculate how many degrees (0-90) it is. Then I want to send this information to my computer.
I thought the best way to do this would be to start the stepper at a 0 degrees and then (through my computer and the ardunio) rise the rangefinder/laser to the right degree so that it is on the target. Then if my rangefinder/laser tells me the distance or the hyp. I can find use hyp (and basic trig) to determine how high it is off the ground. I can calculate this with my computer, but all I really need to know is the angle degree and the hyp.
Does this help you understand it more? Thanks again! -James
Logged
Global Moderator
UK
Offline
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #16 on: January 19, 2011, 01:15:27 pm » |
No, it doesn't help - how does the system know what the target is?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline
Newbie
Arduino rocks
« Reply #17 on: January 19, 2011, 01:44:12 pm » |
View this image I drew.
www3.comli.com/project11.bmp
The red line is a visual of the range finders path. I want to be able to be capable of telling the stepper to move up or down through my computer. If that is the case I will be able to keep track of what degree the range finder is being held at. Then I want to forward the distance from the rangefinder to my computer. With this information I will be able to run simulations in my computer.
Is this better?
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #18 on: January 19, 2011, 01:56:00 pm » |
I think what you're describing is a long baseline or parallax rangefinder, but your diagram looks to me to be the wrong way around.
Logged
0
Offline
Newbie
Arduino rocks
« Reply #19 on: January 19, 2011, 02:01:16 pm » |
How is it backwards? (excluding money as a factor) would this project be doable? Like is it realistic?
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #20 on: January 19, 2011, 02:32:25 pm » |
What does the right-angle represent?
Logged
0
Offline
Newbie
Arduino rocks
« Reply #21 on: January 19, 2011, 02:47:25 pm » |
Because I am the information that I will gather from the electronic, and run it into my computer. From there I can use it to run through my simulations.
The red line on the right triangle represents the range finder. I drew a right angle because my goal is to find that hyp as well as the angle.
Logged
0
Offline
Newbie
Arduino rocks
« Reply #22 on: January 19, 2011, 04:47:51 pm » |
To further explain it just think of a telescope. Except instead of gazing at stars, you are finding how far away they are.
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #23 on: January 19, 2011, 04:51:15 pm » |
To find out how far away stars are, you use a long baseline parallax rangefinder. A diameter of the orbit of the Earth is the baseline of choice.
Logged
0
Offline
Newbie
Arduino rocks
« Reply #24 on: January 19, 2011, 04:53:12 pm » |
ok, I'll take the information in dive into some books/sites and see what I can come up with.
Thanks for all the help! -James
Logged
Silly-con Valley, Ca, U.S.
Offline
Sr. Member
Lernin' to tinker
« Reply #25 on: January 19, 2011, 05:02:56 pm » |
With an ultrasonic you get a "cone" of sight.
Logged
10 PRINT CHR$(7) 20 GOTO 10
0
Offline
Newbie
Arduino rocks
« Reply #26 on: January 19, 2011, 06:11:30 pm » |
Now I see what you people are saying. So to be frank it would be impossible to pinpoint position with one of those?
What would I need then that could pinpoint it? Or would nothing exist?
Also do you know of any other methods in which I could use to help me get the measure of the hyp, and the degree angle?
Thanks again.
Logged
Offline
Sr. Member
Lernin' to tinker
« Reply #27 on: January 19, 2011, 07:22:47 pm » |
Would you be allowed to attach a light or LED to the target? If so you might be able to zero in on that.
Logged
0
Offline
Newbie
Arduino rocks
« Reply #28 on: January 19, 2011, 07:48:28 pm » |
I'm just trying to find a way that will work. Will the light help focus the range finder better and give a more precise reading?
If so could I use a weaker range finder?
edit** Also (without LED's or lights) would there be a mathematical formula that I could use to help me center the "cone"?
thanks again
« Last Edit: January 19, 2011, 07:50:20 pm by mrjameslat »
Logged
0
Offline
Newbie
Arduino rocks
« Reply #29 on: January 19, 2011, 08:58:55 pm » |
Just an update, could I possibly use this MaxSonar? http://www.maxbotix.com/MB7076__XL-MaxSonar-WRA1.htmlIt's only good for about 10m, but so far it seems the closest to what I was looking for, plus it allows for a more narrow vision. What are your thoughts and concerns with this? Thanks again
Logged
