Topic: Arduino Problem - Is it dead? (Read 2516 times) previous topic - next topic
boku
I upgraded my Arduino software to 22, however it appears to have *possibly* killed my Duemilanove (UNO's still work ok)
When I try to do something as simple as load blink using Shift + Upload I get this back...
Code: [Select]
Binary sketch size: 1018 bytes (of a 30720 byte maximum)
C:\Users\Dave\Desktop\arduino-0022\hardware/tools/avr/bin/avrdude -CC:\Users\Dave\Desktop\arduino-0022\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM5 -b57600 -D -Uflash:w:C:\Users\Dave\AppData\Local\Temp\build4572016024545087175.tmp\Blink.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
         System wide configuration file is "C:\Users\Dave\Desktop\arduino-0022\hardware/tools/avr/etc/avrdude.conf"
         Using Port            : \\.\COM5
         Using Programmer      : stk500v1
         Overriding Baud Rate  : 57600
avrdude: ser_open(): setting dtr
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: Send: Q [51]   [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude done.  Thank you.
Thinking I needed to reflash my chip I bought a USBTinyISP (http://www.dfrobot.com/index.php?route= ... uct_id=405)
Because I have Windows 7 x64 I used the DSEO option and F8 booted into Windows the correct way. I tried both drivers from here http://www.ladyada.net/make/usbtinyisp/download.html which installed correctly.
Using both drivers available from Ladyada Website (http://www.ladyada.net/make/usbtinyisp/download.html)
When doing Tools > Burn Bootloader > /w USBtinyISP within Arduino. (usbtinyisp_libusb-win32_1.2.1.0.zip)
When doing Tools > Burn Bootloader > /w USBtinyISP within Arduino. (usbtinyisp w32 driver v1.12.zip)
I get the same message
Code: [Select]
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
Just to reiterate I have selected the correct board from Tools > Board
I'm at my end, I have no idea what else to do, can anyone suggest anything please?
Thanks
BoKu
P.S. My FTDI chip doesnt get hot at all
P.P.S If my crystal was broken how would I be able to tell?
smeezekitty
Very unlikely that a software update would "break" and Arduino.
Be absolutely sure you select the correct serial port (the different Arduinos would probably have different serial ports).
Try the loopback test:
Code: [Select]
Wire a jumper between pin 0&1
Select the correct serial port on the Arduino menu
Open the serial monitor
Hold down the reset button while you type something and press send on the serial monitor
What you type should appear in the receive window
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
boku
Ok just to confirm.
I shorted pins 0 and 1 (RX/TX)
Help and kept held the reset button while in the serial monitor window I typed xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx and pressed send.
On the arduino both the TX and RX flashed briefly and the serial monitor window display the text I just typed.
Grumpy_Mike
Quote
I would go further and say I can't see an mechanism where by that could happen.
That just tests the USB / serial chip, it shows you have the right comms port selected but doesn't say you have the correct board selected. Can you post the error messages you get back from the  "broken" board.
boku
OK, looking at the board it says Arduino Duemilanove, the chip says Atmel ATMEGA328P-PU.
In the Arduino IDE, I only have only 1 com port which appears whenever I plug in the Arduino and disappears when I remove unplug it. This com port has a tick next to it.
The IDE board selected says Arduino Duemilanove or Nano w/ ATmega328
Right now I am just trying to upload this sketch
Code: [Select]
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
  // initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);   // set the LED on
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // set the LED off
My TX and RX blink for a split second four times and then I get this error message
Quote
avrdude: stk500_getsync(): not in sync: resp=0x30
If I press shift and then upload using the same sketch I get this error message (I still get the same 4 brief flashes of the TX and RX LED)
Quote
C:\Users\Dave\Desktop\arduino-0022\hardware/tools/avr/bin/avrdude -CC:\Users\Dave\Desktop\arduino-0022\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM5 -b57600 -D -Uflash:w:C:\Users\Dave\AppData\Local\Temp\build3181651999591619597.tmp\Blink.cpp.hex:i
avrdude: Recv:
avrdude: Recv:
Is that what you are looking for Grumpy_Mike?
Jean-Marie
Hello Boku,
A have a standalone duemilanove on a breadboard. A few days ago, I was suddenly unable to upload the blin sketch. I got the same error message as you. see here: http://arduino.cc/forum/index.php/topic,65545.0.html
I re-flashed the duemilanove bootloader and everything was back to normal.
So, for some unknown reason, the bootloader had been corrupted.
Amicalement, Jean-Marie
boku
Hi Jean-Marie,
I think I actually read that post from you  in fact.
At the moment I'm stuck at trying to re-burn the boot loader using USBtinyISP (See attachment)
So, all I do now is reopen Arduino IDE and (verify the board is still the same one I chose before) there is nothing in the COM port. I have the drivers installed (see post 1) and now I get this message when using burn bootloader
Quote
         this check.
Grumpy_Mike
Thanks, Yes that sounds like not having a bootloader. Why not use the UNO you have to load a new bootloader using the ArduinoISP sketch found under the examples menu?
It works with a UNO despite what it says on the tutorial page. I used this the other day to put a boot loader into a 168 and a 644.
Jean-Marie
I am a bit lost because I've never used USBtinyISP.
It seems that you are not able to communicate with avrdude.
Reading your first post, I see you've intalled 2 drivers. But according to this page http://www.ladyada.net/make/usbtinyisp/download.html, you should install only this driver : http://www.ladyada.net/make/usbtinyisp/usbtinyisp_libusb-win32_1.2.1.0.zip
Perhaps you could try uninstall the USBtinyISP driver or drivers and re-install the one for Windows 7.
boku
I have tried both at separate times, both with the same result.
However I have managed to get something different this time using WinAVR
Quote
C:\Users\Dave>avrdude -B 25 -c usbtiny -p m328p -t -F
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
Grumpy_Mike
Looks like a broken / un powered / un clocked chip
boku
I got yet even more information (I replaced the files from WinAVR with the ones from Arduino) and got this
Quote
C:\Users\Dave\Dropbox\ARDUINO BOOTLOADER>avrdude -B 25 -c usbtiny -p m328p -t -F
-P COM5 -vvvv
         System wide configuration file is "C:\WinAVR-20100110\bin\avrdude.conf"
         Using Port            : COM5
         Using Programmer      : usbtiny
         Setting bit clk period: 25.0
         AVR Part              : ATMEGA328P
         Chip Erase delay      : 9000 us
         PAGEL                 : PD7
         BS2                   : PC2
         RESET disposition     : dedicated
         RETRY pulse           : SCK
         serial program mode   : yes
         parallel program mode : yes
         Timeout               : 200
         StabDelay             : 100
         CmdexeDelay           : 25
         SyncLoops             : 32
         ByteDelay             : 0
         PollIndex             : 3
         PollValue             : 0x53
         Memory Detail         :
                                  Block Poll               Page
      Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  Max
W   ReadBack
           eeprom        65     5     4    0 no       1024    4      0  3600  36
00 0xff 0xff
                                  Block Poll               Page
      Polled
W   ReadBack
           flash         65     6   128    0 yes     32768  128    256  4500  45
00 0xff 0xff
                                  Block Poll               Page
      Polled
W   ReadBack
           lfuse          0     0     0    0 no          1    0      0  4500  45
00 0x00 0x00
                                  Block Poll               Page
      Polled
W   ReadBack
           hfuse          0     0     0    0 no          1    0      0  4500  45
00 0x00 0x00
                                  Block Poll               Page
      Polled
W   ReadBack
           efuse          0     0     0    0 no          1    0      0  4500  45
00 0x00 0x00
                                  Block Poll               Page
      Polled
W   ReadBack
           lock           0     0     0    0 no          1    0      0  4500  45
00 0x00 0x00
                                  Block Poll               Page
      Polled
W   ReadBack
           calibration    0     0     0    0 no          1    0      0     0
0 0x00 0x00
                                  Block Poll               Page
      Polled
W   ReadBack
           signature      0     0     0    0 no          3    0      0     0
0 0x00 0x00
         Programmer Type : USBTINY
         Description     : USBtiny simple USB programmer
avrdude: Setting SCK period to 25 usec
CMD: [ac 53 00 00] [00 00 00 00]
Reading |                                                    | 0% 0.00sCMD: [30
00 00 00] [00 00 00 00]
CMD: [30 00 01 00] [00 00 00 00]
Reading | #################                                  | 33% 0.02sCMD: [30
00 02 00] [00 00 00 00]
Reading | ################################################## | 100% 0.03s
CMD: [50 00 00 00] [00 00 00 00]
avrdude: safemode read 1, lfuse value: 0
avrdude: safemode read 2, lfuse value: 0
avrdude: safemode read 3, lfuse value: 0
avrdude: safemode: lfuse reads as 0
CMD: [58 08 00 00] [00 00 00 00]
avrdude: safemode read 1, hfuse value: 0
avrdude: safemode read 2, hfuse value: 0
avrdude: safemode read 3, hfuse value: 0
avrdude: safemode: hfuse reads as 0
CMD: [50 08 00 00] [00 00 00 00]
avrdude: safemode read 1, efuse value: 0
avrdude: safemode read 2, efuse value: 0
avrdude: safemode read 3, efuse value: 0
avrdude: safemode: efuse reads as 0
avrdude>
Jean-Marie
It really looks like avrdude is unable to communicate with the atmega through USBtinyISP: no signature read, no fuses read.
I see in the error file that you use COM 5. Is it normal ? Do you already have 4 COM ports occupied ?
Is it the first time you use your USBtinyISP or you already managed to program your atmega before ?
I suppose you don't have any spare atmega ?
boku
Sadly my new Uno hasn't come yet, from Sparkfun to Australia (its cheaper than buying local sometimes!)
I did have another Uno which I gave away which still works and used the same Arduino software etc, although that ran out of the box. I didn't have to avrdude it at all
Maybe I haven't connected my USBtinyISP to my Arduino correctly, I'm sure I read that I WASNT supposed to power my Arduino IF I was using the pin through the USBtiny.
Can anyone confirm?
Jean-Marie
Obviously, how to power up the arduino is very important.
I can't help you with this but it is probably explained in the documentation, or on the website. Adafruit has also a forum that could help wit it.
