Loading...
Pages: 1 [2]   Go Down
Author Topic: Arduino Problem - Is it dead?  (Read 667 times)
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
Using the usbtiny is very simple.
a) use a 'naked' arduino board, nothing connected.
b) plug the 6pin header into the icsp port, red wire towards pin1
c) make sure you have shorted the jumper on the usbtiny to feed power to the arduino
d) use avrdude:
avrdude -c usbtiny -p atmega328p -vvvvv
The green light on the usbtiny should be on as soon as you plug it into your computer. The red light should get on/flicker when you run avrdude.
Logged
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
Washington
Offline Offline
God Member
Firefox & Arduino rocks
View Profile
Worst comes to worst, you can get a new atmega 328 with bootloader. about $5.
Logged
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
Offline Offline
Newbie
View Profile
@madworm
Ok here goes, there is a lot of information to view, I wasnt aware of the 5th v, I've only seen 4 v's before, so thanks for that smiley
I may just end up doing that ... but still, would like to know exactly where this one has gone wrong ...
Too big to paste so its attached...
« Last Edit: July 13, 2011, 10:58:51 pm by boku » Logged
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
If the LEDs behaved as indicated before, the chip doesn't talk back. Either it is damaged, unpowered or doesn't respond due to messed up clocksource settings in the fuse bits.
If the red led didn't come on, avrdude can't talk to the usbtiny.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
