Topic: ModBus and WiFly ... (Read 1 time) previous topic - next topic
buissonth
I am trying to put in place a ModBus Communication via Wifi thanks to a wifly shield. I am using the ModbusMaster.h library. However it is used to serial communication.
How can I make it with WiFi ?
My code is following :
Code: [Select]
//Librairies
#include "WiFly.h"
#include "Credentials.h"
#include <ModbusMaster.h>
//Parametrage
// WiFly
boolean pWiFly = HIGH;
Server server(80);
long startTime;
//ModBus
boolean pModbus = HIGH;
ModbusMaster node(2);
  // Connection du WiFly
  if (pWiFly == HIGH) {
    Serial.begin(9600);           //Serial.println("Debut du programme");
    server.begin();               //Serial.println("Demarrage serveur");
    SpiSerial.begin();            //Serial.println("Connection au SPI UART.");
    SpiSerial.print("$$$");       //Serial.println("Passage en mode commande");
    WiFly.begin();                //Serial.println("Demarrage WiFly");
    // Connection au reseau WiFi
    if (!WiFly.join(ssid)) {
      while (1) {
        //Serial.println("Connection impossible");
  //Affichage de l'adresse IP
  Serial.print("IP: ");
  Serial.println(WiFly.ip());
  //Connection du ModBus
  node.begin(9600); //Serial.println("Modbus : OK");
  //Envoi des donnĂ©es analogiques par wifi sur une page web
    //fWiFly();
  //Communication Modbus
  if (pModbus == HIGH) {
    fModbus();
//Fonction ModBus
void fModbus() {
  static uint32_t i;
  uint8_t j, result;
  uint16_t data[6];
  i++;
  // set word 0 of TX buffer to least-significant word of counter (bits 15..0)
  node.setTransmitBuffer(0, lowWord(i));
  // set word 1 of TX buffer to most-significant word of counter (bits 31..16)
  node.setTransmitBuffer(1, highWord(i));
  // slave: write TX buffer to (2) 16-bit registers starting at register 0
  result = node.writeMultipleRegisters(0, 2);
  // slave: read (6) 16-bit registers starting at register 2 to RX buffer
  result = node.readHoldingRegisters(2, 6);
  // do something with data if read is successful
  if (result == node.ku8MBSuccess)
    for (j = 0; j < 6; j++)
      data[j] = node.getResponseBuffer(j);
yeti195
I'm wondering if you ever got this to work
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
