Topic: Trouble writing to SD card inside Interrupt Service Routine (Read 1 time) previous topic - next topic
geekgrrl0
I must admit to being quite new to Arduinos (been playing for about 6 weeks).  One problem I have not been able to solve on my own or with previous forum posts:
I can't seem to write to the SD card within a Timer1 ISR().  Is this not possible?  Or am I missing something?  I am able to write to the card when inside the setup, so I don't believe it's my card or shield.
I'm using the Mega 2560 with the Adafruit Data Logger Shield.  Here is the code that is refusing to work for me :)
Code: [Select]
Timer interrupt.  Using 16bit Timer/Counter 1 for mega 2560
const int chipSelect = 10;
#include <avr/interrupt.h>
#include <avr/io.h>
#include <SdFat.h>
unsigned int count = 0;
SdFat sd;
SdFile aFile;
//   setup()
void setup()  {
  Serial.begin(9600);    //testing
  pinMode(10, OUTPUT);   //SD card pin
  if (!sd.init(SPI_FULL_SPEED, chipSelect)) {
     Serial.println("init error");
    sd.initErrorHalt();
  //***************setting up Timer1******************
   DDRB = 0x01;    //PB0 aka pin 53
   PORTB = 0x00;  //start with all pins LOW
  //setup Timer1 to fire every 250ms
//  TCCR1A = 0x00;    //disable Timer1 while we set it up
  TCCR1B = 0x00;    //disable Timer1 while we set it up
  //reset timer/counter1
  TCNT1  = 0x0000;        //set counter to 0, to count up to Output Compare Register
  TCCR1A  = 0x00;   //Timer1 Control Reg A: Wave Gen Mode normal
  //TCCR1B bits 2:0 clock select bits, 011=clk(io)/64(from prescalar)
  TCCR1B  = 0x03;   //Timer1 Control Reg B: prescalar set to 64
  OCR1A = 0xF487;    //set Output Compare Reg to 62499
  //turn on timer1
  TIMSK1 = 0x02;        //enable output compare interrupt for OCR1A
  sei();    //enables interrupts
}            //************** end setup()
//    main loop()
}            //*********************end main loop()
//        logSD()
void logSD()
      if (!aFile.open("log.csv", O_RDWR | O_CREAT | O_APPEND))
         sd.errorHalt("opening log.csv for write failed in logSD()");
      aFile.println("in loop");
      aFile.close();
}            //*************end logSD()
//          ISR for Timer1
ISR(TIMER1_COMPA_vect)   {
     count++;   //testing
    PORTB= 0x01;   //switch pin 53 to HIGH, PB0
    logSD();
    PORTB = 0x00;    //switch to low
    Serial.println(count, DEC);  //testing
    OCR1A += 0xF487;      //set output compare to next value
}            //*******************end ISR for Timer1
I have tried simply writing to SD card inside the ISR without the subroutine logSD(), but the result is the same either way for me.  Thanks in advance for any helpful suggestions or pointers to places I may have missed with my googling skills.
fat16lib
SdFat was not designed to be used in an interrupt routine.  Writing to an SD with file I/O takes too long to be reasonable in an ISR.
If you need to log data in a timer ISR see the fastLogger examples here http://code.google.com/p/beta-lib/downloads/list.
robtillaart
No definite answer but...
ISR's must be kept short as possible, accessing SDcards might take too long, and you could get some reentry problem.
It might be that for the SPI IO which is used by the SDcard the timer is needed????
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
geekgrrl0
Thank you both.  I think you are correct robtillaart, because it has worked before, but only for one or two writes.  Thanks for the suggestion...I will try it out!
Jon_Chen
Hi, I also facing a same problem with sd card and timer1 interrupts. Any solution figure out ?
fat16lib
The standard solution is to buffer data in the interrupt routine and write to the SD card in the background.
The AnalogBinLogger example shows how to use a queue of buffers.
It is complex because it has a lot of other features but you can see the general idea for buffering in an interrupt routine.
