Offline
Newbie
« on: July 15, 2011, 10:03:50 am » |
Hi everyone, I want to make a project that control a robot wirelessly, and I decide to use xbees. But I never use it before, it seems xbee can't directly embedded on an arduino, do I need some adapter or breadboard or something like that?
Can someone tell me what exactly I need and give me the link to buy them?
Many thanks.
Logged
Massachusetts, USA
Offline
Tesla Member
« Reply #1 on: July 15, 2011, 11:33:26 am » |
When you want a board that plugs directly into an Arduino the term used is "shield". A search for 'Arduino xbee shield' should turn up all sorts of possibilities.
If you don't need it to plug directly into an Arduino but want the essential support circuitry and an easy way to connect to the signals the term used is "breakout board". A search for 'xbee breakout board' should turn up plenty of choices.
Logged
Offline
Newbie
« Reply #2 on: July 15, 2011, 12:15:33 pm » |
Thanks for your advise, I need one to connect to the arduino and another to the PC,so that I can communicate the arduino with the PC wirelessly by using xbees. Sorry I'm a newbie and could you tell me which type I need?
Logged
Greenville, IL
Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
« Reply #3 on: July 15, 2011, 01:15:24 pm » |
Going by what you have said I think this is what you need. http://www.sparkfun.com/products/9897Mark
Logged
Massachusetts, USA
Offline
Tesla Member
« Reply #4 on: July 15, 2011, 01:28:04 pm » |
He's right. That's exactly what you need. Two XBee's, a shield for the Arduino, and a USB-to-XBee adapter for the PC.
Logged
Offline
Newbie
« Reply #5 on: July 17, 2011, 08:45:17 am » |
Thank you very much, I have ordered one.
Logged
Offline
Newbie
« Reply #8 on: July 18, 2011, 01:44:31 pm » |
If I want to buy these separately, what exactly do I need? Could you give me the links to buy them?(on Farnell or Radionics) Thank you very much!
Logged
Greenville, IL
Offline
Edison Member
« Reply #9 on: July 18, 2011, 02:54:50 pm » |
The link you provided is not what you want to connect to an Arduino. I looked over the Radionics site and did not find a kit that has what you need. They do have Xbee transmitters and receivers but, not the parts to connect directly to the Arduino. Can you state what country you live in? Maybe someone from your area can give you the best place to look. Mark
Logged
Offline
Newbie
« Reply #10 on: July 18, 2011, 05:14:07 pm » |
Mark
Can I use this shield to connect to my Arduino, http://ie.farnell.com/arduino/a000021/board-arduino-xbee-shield-w-o-module/dp/1848697and buy the link provided above?
Logged
Greenville, IL
Offline
Edison Member
« Reply #11 on: July 19, 2011, 12:14:21 pm » |
Mark
Can I use this shield to connect to my Arduino, http://ie.farnell.com/arduino/a000021/board-arduino-xbee-shield-w-o-module/dp/1848697and buy the link provided above? The farnell link shows what MIGHT be the shield you need for the Arduino. You will still need 2 Xbee's and some way to connect to the computer. I would like to help you more but, I am not 100% certain on what parts you need from Farnell and I don't want to cost you extra money if I am wrong. Mark
Logged
Offline
Newbie
« Reply #12 on: July 20, 2011, 10:29:49 am » |
Thank you Mark,could you have a look at this: http://ie.farnell.com/digi-international/xa-a14-ce1p/adapter-xbeepro-2-5-802-15-4/dp/1690793 will this be suitable to act as a adapter to the computer? The link you provided is not what you want to connect to an Arduino. I looked over the Radionics site and did not find a kit that has what you need. They do have Xbee transmitters and receivers but, not the parts to connect directly to the Arduino.
Mark
Logged
Greenville, IL
Offline
Edison Member
« Reply #13 on: July 20, 2011, 05:04:07 pm » |
Logged
Greenville, IL
Offline
Edison Member
« Reply #14 on: July 20, 2011, 05:05:55 pm » |
Logged
