Topic: RPM calclater (Read 6816 times) previous topic - next topic
AWOL
Quote
I did changed the baudrate to 9600 and
Don't you want the baud rate to be as high as possible, so that you don't miss too many pulses when you're printing results?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
gshubham96
Quote
i'll change the baud rate, that's not the prob here, the thing is why it is showing RPM = o everytime and i also removed "count = 0"
here is the final code
Code: [Select]
#define IRPIN 5
unsigned int count;  // can only be positive
unsigned long current_time;
int prevState;  //  LOW = BLACK, HIGH = WHITE
int newState;
  Serial.begin(115200) ;
  Serial.println("Start RPM 01") ;
   prevState = digitalRead(IRPIN );   // read the reference state
  current_time = millis();
  //count until 1 minute (= 60*1000 ms, 60000mS) has elapsed
  while (millis() - 60000L <= current_time )  // use L for LONG math !!!
    newState = digitalRead(IRPIN);
    if (prevState == HIGH && newState == LOW)  // this is a transition from LOW to HIGH
      count++ ;
    prevState = newState;
  Serial.print("RPM: ") ;
  Serial.println(count);
robtillaart
#17
Jul 18, 2011, 12:45 pm Last Edit: Jul 18, 2011, 12:57 pm by robtillaart Reason: 1
That is a valid response if the wheel is not moving.
So the question is does the sensor work?
What is the output of this minimal sketch that should detect the pulse..
Code: [Select]
#define IRPIN 5
 Serial.begin(115200) ;           /////////////////////////  fastest baudrate is needed !!
 Serial.println("Start test RPM sensor  0.1");
  pinMode (IRPIN, INPUT);
 if (digitalRead(IRPIN) == HIGH) Serial.println(millis());
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
AWOL
#18
Jul 18, 2011, 12:46 pm Last Edit: Jul 18, 2011, 12:49 pm by AWOL Reason: 1
Well, the obvious answer is that "count" is not being incremented.
Now, I think that pins default to input, but I always like to be sure.
gshubham96
Code: [Select]
2
2
2
3
3
3
3
4
4
4
4
5
5
5
5
6
6
6
6
7
7
7
7
7
it stops when not detecting
robtillaart
#20
Jul 18, 2011, 12:54 pm Last Edit: Jul 18, 2011, 12:57 pm by robtillaart Reason: 1
Quote
AaAAARGHH, pinMode missing error  :smiley-red:
I'll update my sketches above ...
Thanks,
done.
Rob Tillaart
gshubham96
COde: with PINMODE
Code: [Select]
#define IRPIN 5
int newState;
  pinMode(IRPIN, INPUT);
  while (millis() - 60000UL <= current_time )  // use L for LONG math !!!
      count++ ;
  Serial.print("RPM= ") ;
Result:
Code: [Select]
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
Still nothing
gshubham96
@robtillaart
Code: [Select]
#define IRPIN 5
  Serial.println("Start test RPM sensor  0.1") ;
Result:
Code: [Select]
125
125
126
126
128
128
129
129
130
130
131
131
132
132
133
133
134
134
135
135
136
136
robtillaart
#23
Jul 18, 2011, 01:09 pm Last Edit: Jul 18, 2011, 02:16 pm by robtillaart Reason: 1
OK,  PinMOde was very important to get signal working.
seems like 2 rotations per milli = 2000/sec = 120.000/minute ?????
better explanation is that the signal is high continuously...
PLease try this slightly modified sketch, should print 0's and 1's
Code: [Select]
#define IRPIN 5
 Serial.println("Start test RPM sensor  0.2") ;
 Serial.print(digitalRead(IRPIN) );  /// should do 0001100000  or representing low low low high  low low low
-- update --
fixed typo see below
Rob Tillaart
gshubham96
#24
Jul 18, 2011, 01:28 pm Last Edit: Jul 18, 2011, 01:30 pm by gshubham96 Reason: 1
my arduino IDE doen't respond when i run this code..:(  :~
and it should be
Quote
Serial.print(digitalRead(IRPIN)) ;
However if I change baud rate to 9600 i get the desired result
robtillaart
#25
Jul 18, 2011, 02:15 pm Last Edit: Jul 18, 2011, 02:18 pm by robtillaart Reason: 1
Thanks for pointing out the typo,
Why do you insist on using 9600 baud?
You can change the baudrate in the IDE serial monitor (lower right) to 115200.
The higher the baudrate =>  the less time serial takes for communicating => the more time there is for sampling the sensor.
Quote
At what speed does the wheel rotate in  RPM?
and what is the output?
So the sensor is working, time to go back to the bigger sketches;
please run the sketch from post #21 again and post the output.
Rob Tillaart
gshubham96
#26
Jul 18, 2011, 06:04 pm Last Edit: Jul 18, 2011, 06:31 pm by gshubham96 Reason: 1
Quote
60 RPM
Quote
tried at 115200 baudrate, nothing
Output of post #21
Code: [Select]
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
RPM= 0
shall i post pics or vid of my project?
robtillaart
Conclusion: you get no pulses from the hardware .
code #21 checks for a state change, that doesn't occur => RPM = 0
As I quoted earlier "better explanation is that the signal is high continuously..."
So it is time to check the hardware why the signal is continuously HIGH.
- is the wiring OK?
- how is the sensor connected?
- type sensor - datasheet?
- what is the voltage reflected with white.
- and with black.
Rob
Rob Tillaart
Techone
I read the posts here, I was thinking,  The system need to be check. I agree with you robtillart.
A. Check the sensor with voltage to check if it have a 0 V for LOW and a 5 V for HIGH.
    If not well the system will not work.
B. Check the software. Instead of the sensor, connect a push-on switch. Press switch - HIGH  no press - LOW.
    Do it rapidely - Like you press a button on a video game. The software should display the number of
    "Press the button" per second or per minute. RPM - Turn per minute = Pulse per minute.
Just an idea.
robtillaart
Rob Tillaart
