Topic: RPM calclater (Read 5902 times) previous topic - next topic
AWOL
One technique I sometimes use is to turn on a 50% duty cycle PWM pin, and hook that to the input I'm testing.
May be a bit fast for this application, but at least it will show transitions.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
Techone
@ AWOL
Quote
That is  a good idea AWOL, use the Arduino to generate a pulse. Or a 555 astable circuit set the the frequency you want. Or a second Ardiuno.  That way, it will check the "counter program""
@ robtillart
I am interest in this topic because it can be use a way to measure RPM ( ex : on a fan - using LED, Laser LED , IFR LEd ) or frequency counter. I will look at the "Sampling Routine" how you do it.
PS : This Forum is an exellent place to share ideas.
gshubham96
#32
Jul 19, 2011, 06:51 pm Last Edit: Jul 19, 2011, 07:12 pm by gshubham96 Reason: 1
Quote
A. Check the sensor with voltage to check if it have a 0 V for LOW and a 5 V for HIGH.
    If not well the system will not work.
The output voltage of the sensor is 2.5V.
Is that the problem?? :~ :~
robtillaart
Quote
Is that the problem?? smiley-confuse smiley-confuse
yes, there should at least be 2 voltages one for LOW and one for HIGH. and if 2.5V is the HIGH it might be well too LOW.
amplify the signal with a transistor ...
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
retrolefty
Quote
How are you measuring that, while the signal is actively changing and using a DVM meter? If so that's not a true representation of the signal, use of a scope would be the only method to determine the active low and high voltage levels if the signal is changing.
Lefty
