Loading...
Poll
Question: Good Idea?
Yes - 1 (50%)
No - 0 (0%)
Don't Care - 1 (50%)
Total Voters: 2
Pages: [1]   Go Down
Author Topic: Interchangeable Barrel Jack Adapter  (Read 776 times)
United States of America, Florida
Offline Offline
Jr. Member
Watching electrolytic caps exploding is one of my favorite past-times.
View Profile
WWW
After searching for an hour or so for a wall wart that was the right size and polarity, I remembered that I had a a Radio Shack wall wart that had different sized barrel plugs, now what if the Arduino had interchangeable barrel jacks.
Logged
Memento Mori
Sola Christus
The Christian Hacker:
https://www.facebook.com/groups/141258275980190/
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Well, you do have access to Vin/Gnd on the Power header, all you need is two wires to connect to whatever jack you want to use...
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Jr. Member
View Profile
WWW
I know but if you do not want to take apart a good wall wart.
Logged
Memento Mori
Sola Christus
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
You can get different sized plugs online that will make with your wallwart. Just need to look around more.
I'd look now, but I'm walking out the door to go home.
5.5/2.1 is the arduino size.
5.5/2.5 is another common size.
Look around, you can find them.
Logged
Offline Offline
Jr. Member
View Profile
WWW
I know, this was just an idea.
Logged
Memento Mori
Sola Christus
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Quote
but using a bad one makes no sense smiley-wink
Check second hand stores, they often hav a big box with different wallwarts for cheap.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Make sure you find one with DC output tho, not AC.
I once bought a Midi sound module via e-bay, the original seller said it turned on, but he couldn't get sound out of it.
Turns it he had a DC wallwart, but this device actually required an AC output module!
For Arduino, make sure to  get DC.
Ijust received these for my '1284 boards.
7.5V DC, 1000mA
http://www.dipmicro.com/store/DCA-07510  plugs right into the Duemilanove jack very nicely!
Figure why make the regulator have to drag 12V all the way down, why not give it a head start and let it run cooler.
barrel jack
http://www.dipmicro.com/store/KLDX-0202-A
I personally just run off 5V wallwarts, and don't even use regulators.
Such as
http://www.dipmicro.com/store/DCA-0510 or
http://www.mpja.com/prodinfo.asp?number=18520+PS
with a panel mount connector on the enclosure wall
http://www.mpja.com/prodinfo.asp?number=18549+PL
Logged
Offline Offline
Jr. Member
View Profile
WWW
But that output is not always clean or exact, I have noticed as much as +6 volts (greater than the output) ripple on wall warts. and a 9 volt  reg being 11.5 volts
Logged
Memento Mori
Sola Christus
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
The 5V switching regulator wallwarts don't do that. They put out rock solid 5v.
Logged
Pages: [1]   Go Up
Print
Jump to:
