Loading...
Pages: [1]   Go Down
Author Topic: Programming for a Bread Board  (Read 1079 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I'm brand new to the microprocessor field, but I'm looking to get involved.
While this is probably very obvious to anyone who has actually used this before, I'm looking to use the ATMega168, eventually in just a bread board (and maybe PCB in the long run).
Can I use the Arduino Duemilanove to program & test the chip before moving it to my bread board, or will the chip only work when it's in the Arduino environment?
Thanks, I'm looking forward to getting my hands dirty and my wallet empty with this new hobby.
Bruce
Logged
Denver
Offline Offline
God Member
Inactive - PM
View Profile
WWW
Bruce,
Quote
Yes you can. It doesn't need the environment once the sketch is loaded.
You can make your own breadboard - i.e.
http://art364.pbwiki.com/Standalone+Arduino
Or get something like this "really bare bones board"
http://www.moderndevice.com/RBBB_revB.shtml/
Enjoy!
[edit]Changed link to "really bare bones board"[/edit]
« Last Edit: February 22, 2009, 12:25:25 am by BroHogan » Logged
"Data is not information, information is not knowledge, knowledge is not understanding, understanding is not wisdom."
~ Clifford Stoll
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
If developed on the Duemilanove then the 168 chip can be moved to the breadboard and needs only a 16mhz resonator or crystal(with caps) and a pull-up resistor for the reset pin.
Or if you get a standalone USB serial converter cable or module you can actually develop the application while the chip is still on the breadboard. It is only requires that your AVR chip has a bootloader already burned into it, several vendors sell them.
http://store.fundamentallogic.com/ecom/index.php?main_page=product_info&cPath=4_7&products_id=17
 Below is the USB serial module I use to develop programs on the breadboard  using the Arduino IDE software. I've soldered header pins to it and it plugs into the breadboard. It uses the same USB chip that the Arduino modules use.
http://www.sparkfun.com/commerce/product_info.php?products_id=718
Lefty
« Last Edit: February 21, 2009, 03:14:07 am by retrolefty » Logged
MN, USA
Offline Offline
Newbie
Arduino: MCUs made Easy (er)
View Profile
I have yet to find a USB adapter that is geared 100% for Arduino breadboarding like this one:
http://www.dalewheat.com/wp-content/uploads/2011/01/Breadboard-Arduino-2.0-final-014.jpg
Any idea where someone can buy them individually?
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Gravitech:
http://yhst-27389313707334.stores.yahoo.net/arliandpropr.html
Look at the Promini schematic, wire up your standalone chip the same way.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Pages: [1]   Go Up
Print
Jump to:
