Topic: Problems with parallel sram (Read 5903 times) previous topic - next topic
RolfvDam
Hello,
I'm trying to interface an 32k x 8 sram chip with shift registers but somehow it just won't write or read anything. I've tested the shift registers output which seems to be fine.
I've tried the advice given here: http://arduino.cc/forum/index.php/topic,50633.0.html
I've added decoupling capacitors and simplified the reading and writing routine but to no avail.
I've based the shift register setup on this tutorial: http://www.arduino.cc/en/Tutorial/ShiftOut
Here's the code:
Code: [Select]
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
int bytePins[8] = {2,3,4,5,6,7,9,10};
int CE = A2;
int OE = A1;
int WE = A0;
#define CHECK_BIT(var,pos) ((var) & (1<<(pos)))
/* mode: INPUT or OUTPUT
OUTPUT: for writing out to memory
INPUT: for reading from memory
void setBytePins(int mode){
for(int i=0 ; i < 8 ; i++){
pinMode(bytePins[i], mode);
void readBytes(unsigned char * buffer, unsigned short addr, int len){
unsigned char b;
setBytePins(INPUT);
digitalWrite(CE, LOW);
digitalWrite(OE, LOW);
digitalWrite(WE, HIGH);
for( int i=0 ; i < len ; i++){
b = readByte((int)addr+i);
buffer[i] = b;
unsigned char readByte(unsigned short addr){
setAddr(addr);
return getByte();
unsigned char getByte(){
unsigned char b=0;
int state;
for( int i=0 ; i < 8 ; i++ ){
state = digitalRead(bytePins[i]);
if( state == HIGH ){
b |= 1 << i;
}else{
b &= ~(1 << i);
return b;
void writeBytes(unsigned char * b, unsigned short addr, int len){
setBytePins(OUTPUT);
digitalWrite(WE, LOW);
writeByte(b[i],(int)addr+i);
void writeByte(unsigned char b, unsigned short addr){
setAddr(addr);
setByte(b);
writePulse();
void setAddr(unsigned short addr){
doubleShiftOut(addr);
void setByte(unsigned char b){
if( bytePins[i] & (0x1 << i) ){
digitalWrite(bytePins[7-i], HIGH);
}else{
digitalWrite(bytePins[7-i], LOW);
void writePulse(){
delay(10);
  //set pins to output so you can control the shift register
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(CE, OUTPUT);
  pinMode(OE, OUTPUT);
  pinMode(WE, OUTPUT);
unsigned char in_byte[4] = { 0xf0, 0x42, 0x43, 0xf };
unsigned char out_byte[4] = { 0,0,0,0 };
writeBytes(in_byte, 0x0, 4);
readBytes(out_byte, 0x0, 4);
Serial.print(out_byte[0], BIN);
Serial.print(" ");
Serial.print(out_byte[1], BIN);
Serial.print(" ");
Serial.print(out_byte[2], BIN);
Serial.print(" ");
Serial.println(out_byte[3], BIN);
void doubleShiftOut(unsigned short b){
unsigned char b1 = (b & 0xff00) >> 8;
unsigned char b2 = b & 0xff;
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, b1);
shiftOut(dataPin, clockPin, MSBFIRST, b2);
digitalWrite(latchPin, HIGH);
This prints the following to the serial line (which should be what I've written to sram):
1100000 1100000 1100000 1100000
The schematic is attached.
Graynomad
#1
Jul 16, 2011, 02:17 am Last Edit: Jul 16, 2011, 02:46 am by Graynomad Reason: 1
Without looking at the code yet, I would remove ALL those caps and put them in the right places. Most of them go from 5v to VCC ! others go from GND to GND, and some are on data and clock lines.
All you need are caps from VCC to GND near each chip.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
johnwasser
I think part of the problem is that writeBytes() is leaving WE set to LOW (WRITING!).  Keep WE set to HIGH except in writePulse() or you risk writing to  other parts of your memory.
The 10 millisecond delay in writePulse() is probably WAY overkill.  That's like 160,000 instruction cycles for a memory write!
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
RolfvDam
I've removed all the caps and added ones between every VCC and GND pin of the IC's.
I've made sure WE is set to HIGH except for during writepulse (HIGH, LOW, HIGH).
I've removed the 10ms delay.
Now it gives:
0 0 0 0
0 0 0 0
0 0 0 0
Anything else it could be?
johnwasser
Another mistake:
Code: [Select]
if( bytePins[i] & (0x1 << i) ) {   /////// That should be 'b' and not 'bytePins[i]'
}else{
Because digitalRead() returns 0 or 1 and digitalWrite() takes 0 for LOW and anything else for HIGH and 0==false and anything else == true you can simplify the code somewhat:
Code: [Select]
digitalWrite(bytePins[7-i], b && (1<<i) );
unsigned char b=0;
b |= digitalRead(bytePins[i] << i;
return b;
[code]
[/code]
RolfvDam
Quote
Code: [Select]
Oh wow, totally missed that.
Quote
Nice, changed it out.
What I get now is:
1 1 1 1
1 1 1 1
1 1 1 1
When I put the voltmeter on the 5v bus (at the top) I'm only reading around 3.73v when it's operating. When the Arduino powers on it's at 4.8v but quickly falls to 3.73v when the code starts to execute.
Isn't this way too little to properly operate the IC's?
Am I drawing too much power from the Arduino? It's powered by usb.
RolfvDam
I forgot I had taken out the caps for tests.
With caps it still only shows around 4.36v while operating.
johnwasser
I think it's time to post your code again.  I've lost track of what changes you've made.
Also, looks like I missed a ')':
Code: [Select]
unsigned char b=0;
b |= digitalRead(bytePins[i]) << i;
//////////////////////////////////   ^--  This one was missing
return b;
[code]
[/code]
CrossRoads
Post the schematic again too.
CrossRoads
If you had 4 of these to make a 16 counter, it could be preloaded from your shift register, and then just clocked once for the next address to quickly access sequential addresses with having to shift out the address every time.
http://focus.ti.com/lit/ds/sdls198/sdls198.pdf
Am looking for more modern version, or a comparable 8-bit preloadable counter.
This perhaps, use one shift register to load both, one at a time.
http://focus.ti.com/lit/ds/symlink/sn54as867.pdf
RolfvDam
Looks good. I'll see if I can get that for the finished prototype for the thing it's going to be a part of (a gameboy classic rom loader/interface).
Here's the updated code:
Code: [Select]
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
int CE = A2;
int OE = A1;
int WE = A0;
unsigned char b;
setBytePins(INPUT);
buffer[i] = b;
setAddr(addr);
return getByte();
unsigned char b=0;
b |= digitalRead(bytePins[i] << i);
return b;
setAddr(addr);
setByte(b);
writePulse();
void writePulse(){
unsigned char in_byte[4] = { 0xf1, 0x40, 0x41, 0xf0 };
unsigned char out_byte[4] = { 1,2,3,4 };
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Attached is the updated schematic.
johnwasser
If OE was left LOW by something when writeBytes() is running then the memory chip output drivers will be fighting with the Arduino output drivers.  This could cause undue power consumption.   You should probably minimize the amount of time that CE and/or OE are LOW:
Code: [Select]
  pinMode(CE, OUTPUT);    ///  Might want to put a pull-up resistor on this pin to make sure chip stays disabled during reset,
  digitalWrite(CE, HIGH);   /// Add this
  digitalWrite(OE, HIGH);  /// Add this
  digitalWrite(WE, HIGH);  /// Add this
  setBytePins(OUTPUT);   // Don't really need this  readBytes() and writeBytes() both set them properly
unsigned char b;
setBytePins(INPUT);
buffer[i] = b;
digitalWrite(OE, HIGH);    // Add this
digitalWrite(CE, LOW);     // Add this
AWOL
Code: [Select]
I think just one ampersand.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
CrossRoads
On the top '595, is RCK really connected to Gnd? That's not going to work too well.
Why is writePulse seperated from writeByte?  Where else would you use it?
RolfvDam
Quote
I think it was connected through a cap before. I've removed the connection. Updated schematic is attached.
I've removed the extra ampersand.
I've added Johns suggestions to the code:
Code: [Select]
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
int CE = A2;
int OE = A1;
int WE = A0;
unsigned char b;
setBytePins(INPUT);
buffer[i] = b;
setAddr(addr);
return getByte();
unsigned char b=0;
return b;
setAddr(addr);
setByte(b);
digitalWrite(bytePins[7-i], b & (1<<i) );
 //setBytePins(OUTPUT);
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
Still outputs 1 1 1 1 though :(
