Loading...
Pages: 1 ... 4 5 [6] 7   Go Down
Author Topic: Open Source Data Logger Project Using the Arduino?  (Read 14541 times)
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Attach what you like to the bus. But, then, it isn't inherently part of the Arduino.
The Arduino ADC is 10 bit.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
We need additional electronic anyway to handle all of our inputs. So maybe we are designing a shield for that.
As it looks the arduino mega fits pretty well.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi
New to the forum, new to Arduino
As the Science director in a UK High School, what we need is not another data logger that is either too expensive or too complex -- but a data acquisition tool that "just works".
A basic box that had say:
a) 4 channels
b) RTC
c) Sample frequency from ms to daily
d) Basic LCD feedback
e) Minimal memory (cheapest possible) USB or SD Card
As far as schools are concerned, the logger is just a "black box" and it's the sensors that you plug in that make them useful.
A version that I decribed above should only cost $40 (ish) to make -- If such a device existed, they whould sell bucket loads in the UK.
This is the basis of my interest and research into the Arduino.
Cheers
G
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Glen,
Have you seen the Logomatic II?
http://www.sparkfun.com/commerce/product_info.php?products_id=8627
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
No....
x8 Analog / Digital inputs -- wrap it into a neat box with some control circuitry -- might be just the job.
Still -- I'll press on with the Arduino -- makes an interesting project.
Good feedback - thanks
G
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
Glen, please check out the Duino644 board, Arduino-compatible:
http://timewitharduino.blogspot.com/2009/09/introducing-duino644.html
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hey Guys
i've been working on an online data logging system built on google's app engine and i've pretty much decided to go open source with it. I'd really appriciate some feedback from Arduino users and perhaps even some help.
I've worked with data historians for 12 years and i wanted to write my own.
The system i built allows you do log time series data over a rest web service and your data is stored on google's infrastrucutre. I wrote a .net sdk and an way to view/record data on an android phone.
i'm release the code soon under the MIT licence.
I posted some code in my blog on how to wire devices into the web service - it works great, you can see values change in spread sheets and diagrams.
Anyway - i would really appriciate any feedback - you can contact me at bsautner@ (google's free email server)
thanks!
Ben
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Sorry, the web site for my data logging system is  http://www.nimbits.com
The source code will be posted on Google Code:
http://code.google.com/p/nimbits/
I spent 6 years working on this thing, so i hope it can be a good starting point for a cloud based data logger.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Getting back to issues involved in developing an open source data logger based on the arduino:
It seems to me that the development of a shield to handle analog signal conditioning is a key step in making the data logger a broadly appicablel tool.  The ten bit resolution of the Arduino A/D converter (ADC) is not an issue as long the signal from sensors is relatively linear and varies so that the voltage change covers a large fraction of the 0 to 5 volt scale.  However, in many cases, the range of sensor outputs will vary over a much narrower range, and programmable gain amplifiers will be needed to adjust the dynamic range of voltages that are presented to the ADC. (e.g. resolution of the ADC will not be adequate if sensor output voltages range from 0 to 0.5 V).  Also, as many sensor's output varies logarithmically or exponentially with respect to the  stimulus, an exponential or logarithmic conversion will be needed to prevent loss of resolution at the low end of sensor input.   Based on my limited knowledge of OP amps, it seems that a shield to handle this kind of basic signal conditioning might not be too expensive to make. Of course this leaves out some more specialized signal conditioning needs (e.g. cold junction compensation for thermocouples), but if the shield could handle simple variable gain amplification and logarithmic transformation, it would allow the Arduino's 10 bit ADC to serve adequately for many, many data collection situations.
T
Logged
cernusco s.n.
Offline Offline
Jr. Member
Arduino rocks
View Profile
Hi, I am new in this forum. I am very interested to invest my time and some money in a data-logger development based on Arduino. I think that the problem must be divided into some steps:  how to interface sensors to arduino input, that can be solved with easy electronic circuits;
how to get arduino writing data on a SD card or USB pen drive;
how to get enough power autonomy for long data logging (months).
In fact I think to use this sort of device to monitor slow environmental phenomena (i.e. wine cellar temperature  smiley).
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I can recommend the GHI uALFAT Module for data storing. Its working pretty well.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Ben,
had a look at your nimbits stuff - I like the idea of using google as a data store.
Do you have some sample arduino code that you would use ? I'd like to test the idea with some temperature logging...
Thanks
Siegfried
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
instead of trying to make a "one size fits unknown" datalogger
I think the first thing would be to list all the sensor types likely to be hooked to this datalogger and from that determine what input conditionning will be required at minimum for more kinds of sensors
so at least it's known which input conditionning facilities should be on a standard datalogger and which type can be left off a add-on adapter board
also someone should do an inventory of all open source datalogger project that can be found and enumarate their features and scan them for "good ideas" to incorporate in this design
datalogger are often needed but they come in so many brands and model and industries because the people who measure temperatures over weeks don't know about the people who measure fuel/oxygen ratios during minutes and they don't know about the people who measure viscosity over months but they can all benefits from a single common datalogging core with just add-on for their specific application
datalogging for most is an expensive and R&D intensive affair that has no re-use value that's why people pay 500/1000/2000$ for a datalogger that have specs all over the place and there's a reason for that , there's big money to be made in keeping each project unique and personnalised and impossible to compare/shop around for
and lastly the most important of all, this project needs a good name that clearly indicate what it does to people who need it yet don't know what it is yet and it should be easy to find so that the next time someone needs to log the humidity of their bathroom over the next year they don't re-invent the wheel again !!!
Logged
0
Offline Offline
Newbie
View Profile
in the event of the Internet connection going down is there anyway to save the log updates and sync them when the connection is restored?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Siegfried, i think you found these already - but here is the blog posting on how to connet arduino to nimbits.
http://nimbits.blogspot.com/2010/07/data-in-connect-arduino-to-nimbits-data.html
tublar - check out www.nimbits.com, there is a lot of client code both .net and java - it'd be pretty easy to make a buffer in your code on the lan if the internet connection dropped. I may just add that to the code library since it's a pretty basic need.
- Ben
Logged
Pages: 1 ... 4 5 [6] 7   Go Up
Print
Jump to:
