Topic: Atmega8 programming error. (Read 1 time) previous topic - next topic
adilmalik
after great failures i was able to burn an arduino bootloader into my Atmega8-8pu, i burned the "minimal arduino bootloader" which uses atmega8's internal crystal, i also uploader the blink sketch and it worked!, but the problem is i can burn any new sketches :( , im using my arduino to upload sketched into my avr, it shows this error:avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x66.
note: my arduino's  avr is also present in it when i use it to upload sketches.
johnwasser
Where did you get the bootloader and the boards.txt data you are using?
Did you implement auto-reset in your minimal Arduino?  Without it you will need to hold the Reset button until the "Binary sketch size:"  message appears.
Are you sure that the bootloader was built to use the clock rate and baud rate  specified in the boards.txt file?   If you are using an 16 MHz bootloader on an 8 MHz system the baud rate will be half what the bootloader was built for.  Try changing the baud rate shown in boards.txt to see if that works.  You will have to re-start the Arduino IDE before the change will take effect.
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
adilmalik
oh ok thank you so much this helps a lot.
atmega8noxtal.name=ATmega8-noxtal @8MHz
atmega8noxtal.upload.protocol=stk500
atmega8noxtal.upload.maximum_size=7168
atmega8noxtal.upload.speed=38400
atmega8noxtal.bootloader.low_fuses=0xe4
atmega8noxtal.bootloader.high_fuses=0xc4
atmega8noxtal.bootloader.path=atmega8_noxtal
atmega8noxtal.bootloader.file=ATmegaBOOT.hex
atmega8noxtal.bootloader.unlock_bits=0x3F
atmega8noxtal.bootloader.lock_bits=0x0F
atmega8noxtal.build.mcu=atmega8
atmega8noxtal.build.f_cpu=8000000L
atmega8noxtal.build.core=arduino
this is the boards.txt part i had to add,
here is the webpage:http://todbot.com/blog/2009/05/26/minimal-arduino-with-atmega8/
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
