Topic: Newbie Troubles (Read 8556 times) previous topic - next topic
AGGGZ
Hello all,
I'm faced with the challenge of building a robotic arm but minimal knowledge about electronics and programming. Now I have an Arduino Duemilanove and 6 4.8 volt servos but I can't find any helpful resources to design and build the arm. Can anyone help me?
zoomkat
Quote
If that is the case, then you are probably not up to the job. Maybe the below will get you going.
http://www.google.com/search?q=robotic+arm+servo&hl=en&num=100&lr=&ft=i&cr=&safe=images&tbs=
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
AGGGZ
Thanks for the help but I still can't find anything...
bneedhamia
When you say you can't find resources to design and build the arm, do you mean the whole project (for example, how to connect the Arduino to the servos, and how to program the Arduino to control the servos), or do you mean just the mechanical design of the robot arm (how to cut out something that will fasten to the servos to be the arm)?
If your question is the second, I can only sympathize that I have similar problems: doing simple mechanical design.
If your question is the first instead, I recommend you start with a little simpler project and work up to the robot arm.  For example: project 1: get the Arduino board to blink an LED; project 2: build a circuit and write Arduino code to play a tone on a speaker (this will teach you the Pulse-Width Modulation (PWM) technique you'll need for the servos); project 3: build a circuit and write the code to wiggle two servos (this project lets you get everything working without having to think about mechanical design); project 4 - finally - mount the servos on wooden arms and program your new robot arm.
jumpjack
Buy Lego Technics!  ;)
AGGGZ
My problem is more with connecting and programming the servos
and no, unfortunately i can't buy lego technics
zoomkat
Perhaps just purchase one.
http://www.lynxmotion.com/c-27-robotic-arms.aspx
Chuckz
AGGGZ4?, What is your situation?  Do you have a time frame to do this in?  Is it for college, school, work or hobby?
One of the things you do is write goals.  Write down the steps you think you need to complete this goal.  Are the steps specific enough?
Have you checked with the society of robots?  They can also help with direction.
AGGGZ
It is for an extra-cirricular program, I must make one myself, it needs to be done within 2 months, and thanks for the advice.
biocow
Would you control it manually with switches or joy sticks or should it move on it's own?
AGGGZ
it should move on its own but it doesnt necessarily have to
AGGGZ
So first I need to know how to properly set up the servos. I have 2 4AAA battery packs and 3 colors of extra wire, but will I need anything else? Such as a bread or circuit board.
