Topic: Which kit / board should I use ???   (( HELP )) (Read 5174 times) previous topic - next topic
Snakeeyes
Currently I am researching ways to build a sound activated system.
Type of experiment:  Build a board that controls a paintball loader.
Criteria to be met:
1.  It has to detect sound and activate a 9 volt powered hobby motor that could be found at any radio shack.
2.  Once it has been triggered by sound, the motor will remain active for a solid 1 second interval then stop running.
3.  If the sound is consistent, the motor will continually run until said sound has ceased.
4.  Must be able to use two 9 volts.
5.  Needs to be fairly small.
There are boards on the market sold just for this in the world of paintball, however, I am interested in building my own for use in side projects.
Also the cost of those boards are around 60 bucks, so that's another reason I want to make this work ( hopefully cheaper).
If anyone can think of the simplest and cheapest way to put something together, I would greatly appreciate the input.
        --- Many thanks,
cr0sh
#1
Jan 24, 2011, 06:06 am Last Edit: Jan 24, 2011, 06:08 am by keeper63@cox.net Reason: 1
Heck, you could probably easily do this with a 556, a 2n2222 and a handful of passives (cost - under $5.00)...
;D
/remember - not every problem requires an entire microcontroller to solve...
