Always making something...
« Reply #165 on: January 06, 2012, 03:47:31 pm » |
I found my supply of SCRs... an unopened bag of 200 pieces of part number 519-S401E from Mouser Electronics, and a dozen or so loose parts, all with EC1030 printed on them. Or maybe the last "0" is a "D", which would make then EC103D, which is actually a SCR part number I can find! I could not find any info on the 519-S401E. Looks like Mouser doesn't carry them anymore.
Eindhoven
« Reply #166 on: January 06, 2012, 04:11:20 pm » |
My google-fu brought me to this: http://www.datasheetarchive.com/dl/Datasheets-35/DSA-699163.pdfSeems like an SCR aimed at a bit higher voltage, but it might stay under the switching treshold of the 595. I am looking into the teensy++ as a candidate to drive the matrices. The atmega328 has only 2k of SRAM which is not enough if you want to control 10 8x8RGB matrices. The Arduino Mega is overpriced an unnecessarily big.
« Reply #167 on: January 06, 2012, 05:15:41 pm » |
I hooked up the SCR circuit, with the EC103D, 2 capacitors and 1 resistor. The SCR never seems to trigger.
I tried posting a moment ago with a photo, and the "upload folder is full", and my entire message was lost. Grrrr! Will try again in a moment to get the photo up.
« Reply #168 on: January 06, 2012, 05:17:05 pm » |
« Reply #169 on: January 06, 2012, 05:21:51 pm » |
« Reply #170 on: January 06, 2012, 05:26:58 pm » |
It's times like these I really want to buy one of those extremely expensive wide bandwidth current probes....
I guess I might be able to connect a low-value resistor in series with the 1 uF capacitor on the gate and use differential mode to try looking at the current?
Eindhoven
« Reply #171 on: January 07, 2012, 08:36:50 am » |
Hmm, maybe the current pulse is too short to trigger the SCR?
I'll buy some logic level SCR's and have a go at it myself as well.
« Reply #172 on: January 07, 2012, 09:55:37 am » |
I tried a test pulse, 2 ms low, 20 ms high. The SCR still would not trigger. It might be a bad SCR or other mistake on my part, but the only thing I can confirm for certain is the setup on my desk (same as the photos above, but running the code below) is not triggering. void setup() { pinMode(8, OUTPUT); }
void loop() { digitalWrite(8, LOW); delay(2); digitalWrite(8, HIGH); delay(20); }
Eindhoven
« Reply #173 on: January 11, 2012, 01:25:00 pm » |
 This works, even with a 1 microsecond pulse  Boards will be sent to Laen tonight. Edit: Okay, it almost works. It can get in a stuck in a state where the SCR is half open and the capacitor stays at 1.25V. The drain of the BS250 stays at 0.68V in that case. Suggestions to fix this are welcome. Edit2: Fixed with a resistor from the SCR gate to ground  Boards will go to Laen today!
« Last Edit: January 12, 2012, 08:16:26 am by elcojacobs »
« Reply #174 on: January 16, 2012, 08:29:25 pm » |
Just for fun, I got your library working with Vixen ( www.vixenlights.com). It is working fine on my chain of 56 RGB LEDs except something is wrong with channel 99 but I'll fix it later. Using your library to control a Christmas Light show may be on my list next year.
« Reply #175 on: January 23, 2012, 02:42:40 am » |
Ok, so I don't know if this pertains to the ShiftMatrixPWM, but I need some electrical engineering help. This is my first engineering project period.
To clarify the project a bit, it is a Word Clock with 13 columns * 8 rows = 104 led
All led are RGB.
So far I'm in the led soldering stages. I've attached a rough sketch on how I think I should solder them together(attachment 1). On arduino's site they use a STP16C596 for shifting, with 2 registers they run 16 LED's, but can I would have to divide that by 3 if I'm thinking correctly. Right now I'm asking how to wire them, I could go every separate every led with rgb out, hence if wired like above i could control 5.33 per 2 shift registers. The alternative is wiring series/parallel (attachment 2), but I'm assuming there would be some voltage drop. Please let me know what you guys think.
« Reply #176 on: January 23, 2012, 09:07:06 am » |
That LED connection will work great if all 6 LEDs are red and the power supply is a well regulated 5 volts, and you wire the LEDs always-on connected directly to the power.
Blue LEDs typically have a forward voltage between 3.2 to 3.6 volts. Some green LEDs are about 2.2 volts, but others (the really bright ones) are closer to 3 volts. Check the specs, or just run 20 mA through your LED and measure the voltage. Always remember each color is different.
USB power is typically about 4.9 volts from a PC, or 4.7 if using an unpowered hub. Some USB cables use #24 wire, but others use #28 (the smallest officially allowed by the USB spec) or even smaller. If you draw substantial current, plan on some voltage loss in the cable.
If you want those 6 LEDs to actually turn on and off somehow, they'll need to connect to a transistor, or a chip which uses a transistor to conduct the full current. Mosfet transistors have an on-resistance which will effectively be in series with your LED resistor(s). Bipolar transistors have a minimum saturation voltage while conducting substantial collector current. Either way, the net result is your LED array doesn't get the full 5 volts (or 4.9 or 4.6 or whatever your power actually is). Some is lost across the transistor.
If you plan for things to work properly range of power supply voltage, perhaps 5.2 to 4.6, and you calculate things with the actual LED forward voltage and approximate transistor properties, it may not look as pretty on paper, but you'll probably be much happier when you actually build it.
« Reply #177 on: January 23, 2012, 11:02:47 am » |
They are not all red. I drew the Series/Parallel (figure 2) based just upon the red.
RED: Typical: 2 V Max: 2.4V GREEN: Typical: 3.4 V Max: 3.8V BLUE: Typical: 3.4 V Max: 3.8V
« Reply #178 on: January 23, 2012, 05:14:52 pm » |
Elco, any chance I could talk you into including pinout defs for Teensy boards in your next version? Here's the file. http://www.pjrc.com/teensy/beta/pins_arduino_compile_time.h
Eindhoven
« Reply #179 on: January 24, 2012, 07:10:00 am » |
Hi Paul,
I sent you an e-mail about the Teensy 12 days ago, you must have missed it. I have ordered a Teensy++ to develop the matrix code, so Teensy support will be taken care of.
Elco
