Topic: Sending sensor values w/ VirtualWire (Read 1 time) previous topic - next topic
inboxjason
Hi all!
I'm working on a wireless sensor comprised of a light dependent resistor and temp sensor using a 433MHZ RF link and virtualwire to send the resulting values.
Got everything connected up but I cannot seem to send an int value using virtualwire.
I'm using the itoa function as I think vw requires the message to be a string.
I seem to be receiving a range of numbers between 0 and 6.
I've included the code below (no temp sensor), and if anyone could point me on the right path I'd be very grateful!
Thanks!
TX Code
Code: [Select]
#include <VirtualWire.h>
int lightVal;
char msgArray[4];
  vw_set_tx_pin(3);
  vw_set_ptt_inverted(true);
  vw_setup(2000);
  lightVal = analogRead(0);      //ldr
  itoa(lightVal, msgArray, 10);  //int to ascii
  char *msg = msgArray;          //can only send chars with VW?
  digitalWrite(13, true);
  vw_send((uint8_t *)msg, strlen(msg));   //send the value
  vw_wait_tx();
  digitalWrite(13, false);
RX Code
Code: [Select]
int i;
    Serial.println("Serial started");
    vw_set_rx_pin(2);
    vw_setup(2000);
    vw_rx_start();       // Start the receiver
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
for (i = 0; i < buflen; i++)
  Serial.println(buf[i]);
PaulS
You can send ints directly using vw_send, by casting the int, as you do with the message, with a length of 2 (2 btyes in an int).
You can also use Serial.print to confirm what you are sending and receiving, to see if the problem is with the communication or the radios.
inboxjason
@PaulS - Could you explain what you mean by casting the int?
I tried
Code: [Select]
int *msg = msgArray;
It generated a compiler error "cannot convert char to int"
Not too sure what I'm doing here!
Thanks for the quick reply!
PaulS
Quote
Code: [Select]
  vw_send((uint8_t *)lightVal, 2);   //send the value
inboxjason
Hi PaulS,
I'm still getting garbage on the RX side. I've posted the code and output again, would you mind taking a quick look at it? I'm determined to get my head around virtualwire - with a little help!
I've commented out the itoa and array elements - is this correct?
TX Code
Code: [Select]
int lightVal;
//char msgArray[4];
  vw_set_tx_pin(3);
  vw_setup(2000);
  Serial.println("Serial started TX Side");
//  itoa(lightVal, msgArray, 10);  //int to ascii
//  char *msg = msgArray;          //can only send chars with VW?
  Serial.println(lightVal);        //debugging
  vw_wait_tx();
TX Output (Serial)
Code: [Select]
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.07.19 22:03:50 =~=~=~=~=~=~=~=~=~=~=~=
108
111
110
107
111
111
109
109
111
111
108
109
111
111
110
106
67
29
15
15
24
33
23
23
23
24
25
22
22
21
25
22
21
22
22
22
27
59
118
118
119
119
119
RX code is the same as above post.
Here is the RX output...
Code: [Select]
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.07.19 22:03:11 =~=~=~=~=~=~=~=~=~=~=~=
þSerial started RX Side
b
b
b
b
b
b
b
b
b
PaulS
Quote
If you change how you are sending data, doesn't it make sense that you need to change how you are receiving it?
AWOL
Code: [Select]
vw_send((uint8_t *)&lightVal, 2);   //send the value
surely?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
PaulS
Quote
surely?
Uh, yeah. I knew I was leaving something out. Like actually trying it.
inboxjason
Right, I finally have it working!
@PaulS - Yes it was a dumb not to change my rx code. Thank you so much for you help, I was going in entirely the wrong direction!
Code: [Select]
Serial.println(buf[0],DEC);
@AWOL Does this create a pointer?
Code: [Select]
vw_send((uint8_t *)
and then create a reference pointing to the value contained in lightVal?
Code: [Select]
&lightVal
Just trying to get my head around exactly whats going on with that line of code.
Many many thanks to you both!
PaulS
A pointer points to an address. The & (address of) operator gets the address of a variable. This is then treated as a pointer. Since all pointers are the same size, a pointer of one type can be cast to a pointer of another type (as long as due care is taken). So, the pointer to int is cast to (treated as) a pointer to unsigned int (8 bit) (also known as byte) data, which is all that the vw_send function knows how to deal with.
It would be nice to see the complexities hidden in the virtual wire library, but for now, you need to make your data fit the methods provided.
inboxjason
Thank you very much, I've got my head around this! I had no idea the solution was this simple! I spent ages trying to convert to char and back again...
AWOL
Quote
Pointers are probably both the greatest strength and the greatest weakness of the C language.
As PaulS accidentally wrote it first time, it would compile (yes, you can cast an integer to a pointer) and stuff would be transmitted - it just wouldn't be what you expected!
inboxjason
TBH I was just poking around in the dark! I tried all manner of things, unaware that the solution was right in front of me. That line of code makes a whole lot more sense now!
